Is my toshiba 32hfx71 a HD tv? - Televison & Video
    Genius:
  • Televison & ... Master
  • 1,689 Answers
According to the spec sheet it is an HDTV.
The site link below has a spec sheet towards the bottom of the page:
http://www.dealtime.com/xPF-Toshiba-32HFX71
Jerry G.
Posted on Apr 16, 2008
White lines at only the top & botom of the picture
Vertical retrace line fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
May 27, 2014 | Toshiba 32HFX71 32" TV
Toshiba 32hfx71 grey scale off. i need codes to change background color
I hope you find the screen and drive controls if they are located on the CRT PCB.
Dec 12, 2012 | Toshiba 32HFX71 32" TV
No signal with remote control (the remote control work good with our other toshiba tv) but with Toshiba 32HFX71 32" it does not working so we change chanel and other fonctions manualy. Help??
Hello, you need to make sure what is broken, the remote control or the TV. To check the integrity of the remote control, you need to broadcast from the remote control while he aimed at the video camera. If you see a flicker of light through the camera it shows the integrity of the remote control. In this case the infrared receptor need to be replaced, he is placed near the stand by light.in a rare case the problem is at the 5v voltage that goes to the receptor. more rare is the possibility that something is wrong at the microprocessor circuit. . If the remote control out of order, can be opened carefully by a thin screwdriver, usually the causes to the error are loose components or contacts that are supposed to weld back into the board.
i hope it was helpful!! Let me know if you need further guidance
Aug 13, 2010 | Toshiba 32HFX71 32" TV
TV images have gone green
power might be to low for it
Apr 16, 2010 | Toshiba 32HFX71 32" TV
Can you hook up a PC to a Toshiba 32HFX71 TV
yes if the computer has the proper outputs. you need either composite. those are the yellow, red, and white. componet those are red, green, blue. video, and red and white audio. s-video. most of the tvs. with the exception of lcd and plasmas wont sync to the standard vga input on the tv.
May 31, 2009 | Toshiba 32HFX71 32" TV
TV Stand for Toshiba 32HFX71
Amazon.
Toshiba TV Stand 62HM196
Jan 20, 2009 | Toshiba 32AF41 32" TV
Toshiba 32hfx71 / 36hfx71 remote control only sensing at one inch distance
Since the problem is common on two remotes, the source of your misery has to be inside your set, not with the remote. The receiver in the set may not be positioned as it should be since it is rare to have either end go 'a little bad.' They generally will fail totally instead. Any shop that services TVs will have a simple pen-like detector that will tell you if the remote is putting out enough signal to work as it should.
If your set has ever been repaired, the main board may not be sitting in the slots that act as supports.
You might try to hold the remote in several different positions; holding it below the IR window and pointing it upward, the same for each side and then above the window. If it seems to respond better from one or the other angle, then the receiver is not sitting square behind the window.
Oct 28, 2008 | Toshiba 32HFX71 32" TV
Sound help
model number please ?
Oct 03, 2007 | Toshiba 32HFX71 32" TV
HD channels screw up when there is text or graphics on the Screen
100% this is a signal fault. it might be due to 1 you are getting weak signal 2 cable wire quality is poor 3 tuner portion of your tv might be a problem that is loose contact or tuner it self defective. 4 also there might be a problem in aft section in your tv(if all are normal)
Sep 20, 2007 | Toshiba 32HFX71 32" TV
32HFX71 Blinking Pwr Indicator Light
Not likely convergence because it's simply a direct view TV. Could be vertical, a common problem with that unit is the vertical output IC Q301 and poor solder connections of the link off R305. This could be enough to put the unit in shutdown. And it could also be SMPS, possibly regulator or horizontal output transistor - you would need to test these to be sure. The HOT, if shorted, will have continuity E to B or E to C.. If you're not sure you're up to this take it to a reputable shop. What I've described above isn't too serious and a good shop can having back to running good as new in a couple of hours. One tip I might add, take to the shop yourself it will save a few bucks. Good Luck Bill
Jun 14, 2007 | Toshiba 32HFX71 32" TV
Televison & Video Logo
150 people viewed this question
Top Televison & Video Experts
