Is laptop fan suposed to run all the time - Computers & Internet
  • tedkelly Apr 17, 2008
    it starts to run when first started for about 30 seconds then stops then starts to beep continualy for about 60 seconds, unless i press lots of keys over and over, then it stops beeping
  • tedkelly Apr 18, 2008
    yes it boots up and runs ok.just this long continual beeping when it first starts to boot, once beeping stops every thing ok. cheers
  • 51 Answers
Usually it only turns on when the CPU is used alot or when it starts to warm up. But are you saying that it runs when it's shut off? Then no.
Posted on Apr 16, 2008
  • Michael Morlan
    Michael Morlan Apr 17, 2008
    Will your computer even boot up?
Fan keeps running
never seen or heard a microwave that the fan is suposed to keep ruinning on after timer gives up , im in the suspicion that there is an failure inside the appliance to cause this , due to extreemly !!!! high voltage (ten times whats in your house) inside a microwave i dont suggest a consumer open the case for a look tooo dangerous!!! refer this to a repair center
Feb 10, 2015 | GE Microwave Ovens
Why is my laptop unable to run off battery power, even though battery shows fully charged and AC is unplugged
It's time for you to replace your battery.
how old is your laptop? and how do u use it - do u leave it plugged into the wall socket all the time? It's common for batteries to die out after a couple of years. however, if the computer overheats or if you leave it plugged in all the time, it's life cycle will decrease. Charge - discharge cycles. That's how you are suposed to do it.
Jul 17, 2014 | Lenovo IdeaPad U550 Notebook
When replacing 2004 Kia Optima 2.4l engine timing bely there is a second belt behind the main belt what is this belt called and are there suposed to be teeth on the belt mine has none?
drive belt.
Below is the master help link provided to go through belt routing diagram:---Timing belt, drive belt, serpentine belt, accessory belt, fan belt, engine belt routing diagrams for all types of car models?
Click the link below: ----
http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
----------This will help. Thanks.
Feb 04, 2012 | 2004 Kia Optima
I BROUGHT A ASPIREONE D257-13478 DOES IT NEED A COOLIN FAN PAD? OR FINE WITH OUT ONE AND WHAT TPYE BEST IF NEED?
laptops isn't suposed to be on your lap if you like it there the cooling pad is a nice item to have.
It's not needed but if you play games, do graphic design or make music it lets your computer run faster the more cooling you have. if your computer runs hot it will start lagging, and if it gets to hot it will restart.
get one with a big fan it makes less noice, then check if it's comfortable in the store.
i have one my computer gets to hot for me to have in the lap so i jsut had to get one.
Aug 24, 2011 | Acer Aspire One PC Notebook
Cooling fan wont come on when suposed to, i replaced thermostat, relays & temp sensor, fans come on only when car is off & whit ac on
Ive run into this a few times,you have a bad coolant fan sensor, this car uses two one operates the fans when the key is off and the other operates them when the car is running, theres one sensor in the front cooling housing and the other on the rear housing, replace the other coolant sensor and that will solve your problem, take note theres two sensors on that rear housing one for the fan and one for the computer. hope this helps.
Oct 09, 2010 | 1992 Acura Legend
Fan continues to run
I don't think a Mercedes coolant problem will fix your laptop. The fan on most laptops runs all of the time. Many are sensor driven and the fan speed will increase with processor activity. If your fan seems to be running okay, and is not making too much noise, you may just need to take the unit apart and clean out the dust bunnies. They will greatly affect the heating properties. If you need a service manual for disassembly, it is available at mpcdrivers.com
Mar 05, 2008 | Gateway M280E
Computers & Internet Logo
David Payne
David Payne
