Question about Radio Shack Cinego D-1000 Multimedia Projector
Unit overheats and cuts off
I read about a similar problem and the solution was to clean the filter. My question is how do I clean the filter and where is it located. My unit seems to throw off a lot of heat...is that a problem?
It is a D-1000 Cinego projector
Posted on Apr 19, 2008
  • 563 Answers
Hi Harmonie
You will have to give me the make and model of your Projector before I can be of any help at all , because no 2 Projectors are the same.
Posted on Apr 17, 2008
How to unclog vacum. overheats and cuts off
Check all the filters, put a new bag in or wash the cloth bag, check the outlet filter (if it has one) is also clean. If it still cuts out , there could be a problem with the motor. If the unit has a hose, take the hose off and try it again, the hose may be blocked.
Nov 20, 2016 | Vacuums
Have a Husqvarna 23 hp cutting grass overheats shuts down won't start till it cools down
Check/change oil. It provides some cooling. Make sure the cooling fins are clean as well as the fan on the top of the engine.
Aug 16, 2016 | Husqvarna Garden
Why did SPT Portable Air Conditioner stopped blowing cold air?
Unit needs to be taken apart and washed out , also check to see if motor turns freely by hand , clean base of unit fans / blowers and drain ports / channels . Check outdoor motor to see if bearings are tight or fan overheats and cuts off if so replace outdoor motor .
Oct 04, 2014 | Heating & Cooling
Control flashes oh
This code is for an OverHeat situation.
This could happen for a number of reasons. The most likely are either a clogged impeller inside the circulation pump, or a clogged cartridge filter.
Even if the filter looks clean, they only have 6 months recommended use in a residential hot tub before invisible debris start to clog them. Once the filter is clogged, the flow of water is greatly reduced. Once the water flow is reduced, the water flowing through the heating element starts to OverHeat due to being in contact with with the heater for too long.
Cut the power to the spa off, remove the filter element, reapply power to the spa, and check for the code. If it does not reappear, simply get a new filter element.
If the code reappears, clean out the pump impeller. and reset power again.
As a last resort, you might have to check the thermistor. Its rare, but a thermistor can fail and show a false high temp reading.
If you need more assistance, contact me @ adamh@newconceptchem.com
Feb 23, 2011 | Dream Maker Spas Dream Maker Ez Spa Hot...
Vacuum shuts off after short run time . it will turn back on after about 5 minutes but then dies again
This is overheating and tripping the thermal cut-out on the motor.
You need to strip off all filters, clean or replace them (if caked solid). Very often panel filters can be cleaned by knocking them on an outside wall, then a good blow to clear loose dust.
Dyson's often overheat if the filters are not cleaned.
Make sure belts are in good condition, and beater brushes only contact the floor slightly. You need to adjust this hight for different floor surfaces - or it will overheat on thick carpet.
Sep 22, 2009 | Vacuums
Lg dle3777w dryer filter light remains on and dryer is not working even after cleaning the filter.
I'm sure you solved the problem but as i had the same problem on my electric LG front loader and saw no response i figured I would leave one for anybody else in the future. My girlfriend told me the dryer would not start and as i looke i saw the panel would not power up, I unplugged the power cord for 5 minutes and the LG reset and the panel was on and reading clean filter after checking the filter which appeared clean I tried to restart the dryer at which time it powered off. I again unplugged the dryer and replugged it and again the display read clean filter. I then gtabbed a phillips #2 and unscrewed the filter lint sceen which had a total of 4 scews in the interior of the dryer holding the filter housing unit. Youll see a piece of the housing unit remains screwed into the washer hooked up to two electrical plugs. Seperate both plugs from the unit and unscrew it and remove the unit youll notice two silver strips on the unit and I'm guessing will be covered with a small amount of lint. Clean the unit with a brush and damp cloth inside and out reattach the unit screw first and housing unit and turn on. If the dryer again turns off unplug and youll see the clean filter light. Simply push the custom program light or anything similar and the panel should start working again. I hope this helps someone.
Aug 08, 2009 | LG DLE3777 Electric Dryer
Machine cuts out due to getting hot
most vacuums have a heat resister in when they overheat they cut out, this is normally because they are full up, got a blockage or the filters need cleaning, suggestions are, clean filters, empty and check for blockage.
Jul 13, 2009 | Dyson DC07 Allergy Blue/Turquoise Bagless...
Infocus lp600
Clean your air filters. The unit will shut down if it overheats. Ensure that all the filters are cleaned and replaced regularly.
Oct 04, 2008 | InFocus LP 600 Multimedia Projector
173 people viewed this question
Top Radio Shack Office Equipment & Supplies Experts
jasbo
jasbo
xxxxxx xxx
Pie-man
Level 1 Expert
Are you a Radio Shack Office Equipment and Supply Expert? Answer questions, earn points and help others
