Question about DISH Network 311 DTV Receiver
One T.V. snowy on Sat., clear on local channels, others are fine?
We just changed from Direct tv to dishnet, now one bedroom tv is very snowy on sat. channel and gone when we turn another tv on. But on local channels it is clear. Even if we unplug every other tv it still acts the same way.
  • 51 Answers
The television itself needs to be on channel 3 or 4 to get picture through coax. input 1 or 2, av 1 or 2 if rca (red white yellow connections) issue is definetely between the television and receiver...
Posted on Aug 29, 2008
  • 78 Answers
If you recently got dishnetwork call the company that installed the system for a repair person, they HAVE to fix it. if you put it in yourself it sounds like the lnb is bad or the dishnetwork splitter is bad or not hooked up right. this kind of problem is a reminder that paying an extra $5 a month for service warranty is a good deal. if something is wrong with anything then, a phone call to dishnetwork will get new equipment sent to you or a service tech sent to fix it. i don't presently work for dish or direct or a cable co but i know that's how things work.
Posted on Apr 29, 2008
Added a 322 reciever to my lake house to be able to watch tv in 3rd room i had 2 standard recievers before. i installed a dish pro quad lnb & reciever had a separator w/it says dp plus 123254 tuner 2...
Is TV 2 off the 322 receiver being back fed from the receiver or do you have a direct connection to the 3rd room? If it is a direct connection, you would screw the coax from the 3rd bedroom directly to the TV 2 Home Distribution channel 21-69 out port.
If you are back feeding, you need 2 diplexers that connect 1) by the receiver and 2) between the receiver and the 3rd TV. The back feeding will use the same cable coming from the dish to the receiver.
If you have any other questions, please don't hesitate to ask.
Jun 26, 2011 | DISH Network 322 DTV Receiver
I am plugging in a cable from the dishnet satellite in to the antenna port in back and i can't get it to work. But my other tv's work fine doing the same thing
you usually cant go directly from the dishnet sat antenna to the tv without convert (dish box) i would try put it in the cable port and run from the menu options channel scan. do tht as well with the antenna port.
Mar 22, 2011 | Vizio VW37L 37 in. LCD HDTV
We lost local tv from Dish on one of the local channels. We want to use the TV (model LC-46D85U) to view the local channel. How do we get the TV to view in local over the air instead of the satellite. ...
Connect air antenna to RF(coax) input of tv. Go to the menu and look for channel setup.Select antenna and auto scan. When done scanning you should have whatever stations you are able to pickup. Connect Sat reciever to one of the other input on the tv. Then go to INPUT or SOURCE on remote and select tv for local and what ever input you sat box is connected to for dish.
Mar 07, 2011 | Sharp Televison & Video
I chose the wrong channel on remote it took me to a Dish site whcih I chose to exit - when I did that my picture totally disappeared - could not get it back. It is fine on my other tvs - so I need to get...
Guest
Are you getting a snowy/blue/black screen on your TV? To get your picture back, you need to get the TV back to the correct channel or input. If the receiver is in the same room as this TV, the TV should be on channel 3/4 (normally 3) or an input setting depending on the TV. TV 2 (away from receiver) would be on channel 60/73. If you have the TV remote, put the TV on one of those channels. If you get a picture when the TV is placed on the correct channel, press and release the SAT button. This puts the remote back in SAT mode and will now operate the receiver.
If you don't have a picture, unplug the receiver for 10 seconds from the electrical outlet and plug back in. This will cause the receiver to reboot and re-acquire Satellite signal. i hope this helps.
Ray Calo
DISH Network
Jun 30, 2010 | DISH Network IR Remote Control
Tv has only snowy screen. Used the remote to
What to do if you have an all snowy picture (blue screen or the TV displays unusable signal-no signal or no sync)
1 – If you are using a digital cable box or satellite receiver (make sure it’s on) and be sure your TV is set for either CH3 or CH4 (which ever you usually view it on). If you usually view it through video inputs (video1 or 2 etc.) make sure the appropriate input is selected.
If you still don’t get a signal see if you get picture using the DVD or VCR (if available) if you do than plug the satellite or Dig. Box temporarily into the place of the DVD (unplug DVD) you may have to use some A/V cables (RCA yel./red/wht like the ones on the DVD) to hook to the tv from the sat./dig. box. If you get a signal then the sat./dig box is ok. If not the Sat./dig box is not sending a signal and is either defective or needs to be rebooted (unplug wait 5 min try again).
2 – If you are using standard cable or antenna (source) if possible check that the source is good by connecting to another TV. Otherwise try running the source into a VCR and then out to the TV using video inputs (RCA yel./red/wht like the ones on the DVD) and then selecting the appropriate input. Try seeing if the VCR plays using standard CH3 (or CH4)
If the VCR plays on video input but not when connected to CH3 (CH4) then the tuner of the TV may be defective – see if you can use the VCR to change channel using the VCR remote.
Be sure to vote/rate me if this helped Thanks!
Nov 24, 2009 | Toshiba 32AV502U 31.5 in. LCD HDTV
I have 3 digital tv's one in the lounge/bedroom and kitchen for some reason last night, the tv's in the bedroom and kitchen lost all digital channels and the analogue channels were very poor to view snowy...
Loosing digital channels is equivlent to a snowy analog channel, check you cable connections, and splitters to the tv, since you have two of them out, it does not make sense that it is your tv. It is a conneciton in your cable line somewhere.
Sep 02, 2009 | Televison & Video
Speaker distortion on SHARP 37" Aquos Hi Def
When you are changing channels you are using the tuner of the sat reeiver. the tv does not know you are changing a channel . It is just receiving a constant signal from the SAT receiver. I would suspect a problem with the receiver. Try another one first .
Apr 24, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Direct tv on universal remote
For this type of problem you will need to call the RCA customer support at this telephone number 1-800-645-4994. Give them the model number of your remote control and ask them for assistance with your problem. Thank you for using FixYa and have a nice day!
Apr 04, 2009 | RCA 3-Device Universal Remote with...
Snowy screen just pops up
Bad tuner in tv....might be possible to solder bad connect in
tuner...........T.
Dec 14, 2007 | Hitachi 43FDX01B TV
Hitachi screen goes snowy and sound is totally distorted
Sounds like bad solder connect in tv tuner....can usually be
repaired or replaced.......................T.
Nov 30, 2007 | Hitachi 43FDX01B TV
DISH Network 311 DTV Receiver Logo
248 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
