Question about Biostar P4M800-M7A Motherboard
Biostar P4M80-M7A motherboard
I bought this new motherboard everything starts and runs but it won't read a monitor.. Help if you can
  • Anonymous May 22, 2008
    I have the Biostar p4m800-m7a. it will not POST with a P4 651 however it comes up just fine with the original Celeron D.
  • justinatodd Aug 22, 2008
    My computer was working but then it started to turn off on me. After it started to do that it would only boot up to bios then it would turn off on me again and now it will not show any video. I have tried everything that I could think of. Then I even tried having a tec look at same problem they said my motherboard is probably bad and that I would need to get a new one. But the problem with that is so far no sell it any more. So can you help me??
    President:
  • 2,351 Answers
You're board does not use an integrated graphics card.
Monitor does not have video display. There can only be four reasons why.
1. The monitor's video cable is not connected correctly at each end (Video card & Monitor) or cable is bad.
2. The monitor’s power cord is not plugged into a good power source or cable is bad.
3. The monitor may be bad.
4. * The AGP graphics card is either not seated correctly in its AGP slot, (remove/clean copper contacts with alcohol/allow to dry & reseat snuggly), or graphic's card is bad.
Monitor’s power cord can be switched with the PC's power cord.
The video cable & monitor can be swapped by borrowing from a friend.
(Just make sure their stuff is working first).
Never open the PC case without unplugging the power cord first.
Luck!
Mike
Posted on Apr 17, 2008
Onboard video on Biostar P4M80-M7A V7.X P4M80-M7A
Go into BIOS Setup, set the graphics to OnBoard.
Biostar Support > P4M80-M7A Version 7.X mobo > Main Support page,
http://www.biostar-usa.com/mbdetails.asp?model=p4m80-m7a+v7.x
(MOtherBOard)
To the upper right is the - Product Support - heading in a purple banner.
Click on the purple - Manual - in the list underneath.
Under the second purple subheading - Docs - (Documents), click on
p4m80-m7.pdf in Red.
[ Ignore if you are aware;
This is a PDF file. The computer you are using now has Adobe Reader on it; which uses PDF files.
After you click on the above file name it may take up to 30 seconds, before the first page comes up.
(The file is downloading in the background, and you will be looking at a blank page until it fully downloads.
Hover your mouse cursor at the Bottom/Middle of the page.
The ghosted out navigation guide will appear.
Go to the far right, and click on the Adobe PDF icon.
When you hover your mouse cursor over it, - Show Adobe Reader tool bar - will briefly appear.
Use the Zoom Out icon ( - ) at the top to decrease the view size.
Use the Zoom In icon ( + ) to increase the view size.
You can use the Down Arrow to go page by page, to the page you want;
Or,
If you know the page you want you can do this;
1) Put your mouse cursor in the Adobe Reader page number box.
(Box to the right of the Down Arrow.
2) Left-click once. (Anything in the Adobe Reader page number box, is now highlighted in Blue)
3) Type the page number you want.
4) Press the Enter key
The Adobe Reader page number, and the actual manual page number, are NOT the same ]
Page 9 FOR the actual manual page - Motherboard Layout
The Clear CMOS jumper is right above the Front Panel header.
(Clear CMOS Jumper = M; JCMOS1
Front Panel header = L; JPANEL1
Clear CMOS procedures - Page 16. (Actual manual page)
Wonderful manual (?)
Doesn't give BIOS Setup info. I don't see a separate manual listed for it, either.
Hmmm,.....
I'm going to need your eyes to look into BIOS Setup for me.
Use the Clear CMOS jumper, and procedures, then if it doesn't work post back in a Comment.
Regards,
joecoolvette
{Not only will it clear CMOS Error Codes, but it will also set BIOS Setup back to the factory default settings.
One of which is the motherboard is set to use it's OnBoard Graphics.
(Integrated Graphics)
Regards,
joecoolvette
Dec 22, 2012 | Biostar Computers & Internet
I need VGA driver
Hi friens ,
just follow the link and seclect OS
http://www.biostar-usa.com/mbdownloads.asp?model=p4m80-m7a+v7.x
Hope it will help you.Please don't forget to vote me
Nov 30, 2010 | Biostar P4M890-M7 (P4M890-M7 PCI-E)...
Can biostar k8m800 m7a 754 run windows 7
The processor will run windows 7 but may not be very fast.
Look for the correct driver for the m/b at BIOSTAR.com
Dec 27, 2009 | Biostar K8M800-M7A Motherboard
Nobody has a list of cpu's that will work with this mobo. Biostar P4M800-M7A Ver. 7.0. It was sold as compatible with dual core cpu's, but no-one has a list of which intel 775 dual cores. Did New Egg lie?...
P4TAW Extreme 1.0 925X Socket 775 Pentium 4 3.6GHz I915P-A7 1.0 915P Socket 775 Pentium 4 3.8GHz Celeron D 3.06GHz I915G-M7 1.0 915G Socket 775 Pentium 4 3.8GHz Celeron D 3.06GHz I86PE-A7 1.0 865PE Socket 775 Pentium 4 3.8GHz Celeron D 3.06GHz I865G-M7 1.0 865G Socket 775 Pentium 4 3.6GHz Celeron D 3.06GHz N4SIE-A7 1.0 NF4 SLI Intel Ed. Socket 775 Pentium 4 3.8GHz Celeron D 3.06GHz P4M80-M7 1.0 P4M800 Socket 775 Pentium 4 3.6GHz Celeron D 3.06GHz
Dec 08, 2009 | Biostar P4M800-M7A Motherboard
New agp video card won't work.
The only way to tell if it is the connection or the card is to try a different card. Take it back to the place you bought it from and have them swap it for a new one.
Sep 14, 2009 | Biostar P4M80-M4 Motherboard
My current graphics driver is VIA/S3G UniChrome Pro IGP 6.14.10.0243-16.94.44.23...........how can i get the latest version?? my mother board is P4M80-M7A
1.Start
2.Control Panel
3.Switch to classic view
4.Device Manager
5.Display Adapters
6.Select your display adapter by double click
7.Driver Tab
8.Update Driver
9.Search automatically for updated driver software.
Your computer will check your hard drive then the internet for the new drivers and it will install them too good luck hope it helped
Sep 06, 2009 | Biostar P4M800-M7A Motherboard
Windows xp won't load on new biostar motherboard, please help
go to biostar web sight and download sata driver. You may need to run disk that came with motherboard first. Driver may be located on the disk. if not get it from biostar.
Jun 21, 2009 | Biostar K8M800-M7A Motherboard
I have a p4m800-m7 a mobo, and the computer starts up.. then....
Here is the download website for your particular mother board. Download the manual and it has very good on the connections as well as other useful information and drivers for the onboard properties.
http://www.biostar-usa.com/mbdownloads.asp?model=P4M80-M7A%20V7.X
Nov 07, 2008 | Biostar P4M80-M4 Motherboard
Dispaly driver vga vr.1.0
what comp[atible video driver for toshiba dynabook satellite 2270 because i dont know what compatible driver for this
Apr 13, 2008 | Biostar K8M800-M7A Motherboard
Biostar P4M800-M7A Motherboard Logo
197 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
