Tv problems need help
I have a 42" lcd tv when the screen is white or light colored it has little quarter sized dots purple and pink in color when the screen is dark the dots dont appear what do you think would cause that
I had same problem
Posted on Apr 16, 2008
SOURCE:
I have a 70 inch Bravia XBR 70X850B which up until yesterday green/red/pink vertical line that runs across the middle of the screen.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Nov 17, 2016 | Sony XBR Televison & Video
Insignia 42 lcd hdtv purple pink screen
If DVD input works likely a issue with the signal.
If using a cable or sat box or even a receiver inline--unplug each and after several minutes plug back up to allow each unit to try to reboot.
If using component connections from box or receiver they may be the issue or not. In that case if a box is feeding signal via component or even HDMI the box (if reboot does not fix this) may be bad.
Another simple test if cable is used with a box is disconnect cable going to the box and connect directly to set--that way you will know if box is or is not the problem.
May 22, 2012 | Insignia 42" LCD Flat-Panel HDTV
Have sharp quos 52" screen went pink. Can still
Hi, My guess is your daughter messed it up. Go to menu and color and reset to default should fix it.
You may have to adjust color for your best viewing. Good luck.
Sep 27, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Samsung LCD Flatscreen only shows lines of color or purple dots
If you wish to get some details; visit the site linked here. Pull up older posts.
Jun 18, 2017 | Philips 42HF7444T 42 in. Plasma TV
I need help I don't know what color wires go to what wires on my sterio deck
I have a radio wire connector on a 1994 Toyota Camary and the color don' match your list, here is my list.
2 reds, one silver dot, one double silver dot.
2 blacks, same as above,
2 greens, same as above.
2 whites, same as above.
2 browns, same as above,
1 white w/green stripe, two silver dots
1 black w/red stripe, one silver dot.
1 yellow, two silver dots.
1 blue, two silver dots.
the numbers on the connector are A02 16 14 11264 9 8.
I'm clueless which wire are which.
Oct 30, 2009 | 1994 Toyota Camry
Insignia NS-PDP32-09 Purple Dots
Its hard to say this but your tv has a bad PDP Panel unfortunately the panel is not available for the tv. If not in warranty see if your home owners insurance will cover it.
Mar 18, 2009 | Televison & Video
42 plastma problem
Bad Capacitors in Power supply. IF doesnt help changing Capacitors Replace Power Supply Board
Feb 28, 2009 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Pink highlights on LCD screen
IT SOUNDS LIKE THE MAIN BOARD IS BAD. THERE IS 2 DIFFERENT VERSIONS FOR THIS SET .AM02 UNITS OR VERSION 0001 UNITS. THE PART NUMBER IS BN94-00695E. THEY BOTH ARE ABOUT $210 + $50 CORE.
DON..
Jun 02, 2008 | Televison & Video
Televison & Video Logo
133 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
