Back to:
Tags:
Maytag Neptune MAH5500B Front Load Washer
Neptune top load holes in clothes (by 2 users)
posted by oakekroke on Apr 16, 2008
lots of small holes in clothes after washing them
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Maralal, posted on May 04, 2008
Our front loader also puts small holes in our clothes.
Solution #1
posted on Jun 15, 2008
Not Rated (0)
Lumpy816
Rank:Guru Guru
Rating: 92%, 140 votes
You may have something between your basket (the area where you put your clothes) and your tub (the part that holds all the water in. Check all of the holes in your basket to see if you have something sticking/ protruding out of one of them. You might also have a hole that has been bent casuing a rough edge. Next pull back the edge of your boot (the gray ,rubber part in the front) Do you have any forighn objects in there? Finnaly for the washer, check the bottom of the door. A rough area on the bottom can cause the same problem. You might also want to check your dryer. Over time the seals (the gray rings in the front and back when you look in your dryer can be worn or have a forign object caught in them. Both will cause clothes to snag and tear.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on neptune top load holes in clothes:
I don't want to Accept this solution
Can you Help with these Washing Machines problems?
Washing Machines
the belt on the washer broke it is a whirpool GHW9400PL4 I...
Washing Machines
my maytag washer fills up with water but won't agitate,...
The softener dispenser flushes the softerner solution out...
How can I open up my machine to clean out gunk in soap...
step by step on how to install door boot.
Loading problems.
Repair Service
Find Washing Machine Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
