Question about Nortel Norstar 16-Line PBX Speakerphone
Changing the time on a Nortel networks phone
I found the feature button. I don't see a time button.
The feature button is the same as the direct to voice mail button. I tried
Feature ** and hit the show time button - it displays the current time with out the ability to change it. This is not a Norstar phone. The pull out directory says I need a code. what is the code to change the time.
  • 1 more comment
  • crystalarrow Apr 17, 2008
    Thank you for this reply. I found the feature button. I push it then push ** (I don't know where the time button is) There is a button that says show time and when I push it - it clears the feature ** and displays the incorrect time.
  • Anonymous Mar 27, 2014
    im trying to set up voice mail to answer calls and a mail box... but every button i push says inactive fuction... please help
    no one in our office has a mail box.. this is the first time setting it up.. all buttons say inactive feature..help
Feature **time (type out time on the dialpad.)
Posted on Apr 17, 2008
  • Anonymous Apr 17, 2008
    I thought you would figure it out...
    1. Press FEATURE (Your feature
      button may look like a globe with a ring around it). "Feature:"
      will be displayed on the LCD.
    2. Press * * 8 4 6 3 (If
      "invalid feature code" or another error message is displayed, you will
      not be able to use this programming method. Skip down to method
      #2, below).
    3. "Password:" will be
    4. Press 2 2 7 4 2
      -- If "Hour:01" is displayed on the LCD, skip to step 6.
    5. If "RETRY" is displayed on
      the LCD, press 2 3 6 4 6
    6. Press the CHANGE softkey
      button underneath the LCD window.
    7. Using the keypad, enter in
      the hour, using two digits. Example: 2 PM would be 02
    8. The LCD changes and shows
      AM. If you need AM, press the OK softkey. If you need PM,
      press the CHANGE softkey and then press OK.
    9. Press the NEXT softkey under
      the LCD window.
    10. "Minutes:00" is displayed on
      the LCD window.
    11. Press the CHANGE softkey,
      then using the keypad, enter the minutes.
    12. If you are only changing the
      time and not the date, press RLS button (your RLS button may look like a
      telephone handset with a down arrow under it)
    13. If you need to change the
      time, press the NEXT softkey.
    14. "Year:00" is displayed.
      Press the CHANGE softkey.
    15. Using the keypad, enter the
      two digit year. Then press the NEXT softkey.
    16. "Month:01" is displayed.
    17. Using the keypad, enter the
      two digit month. Then press the NEXT softkey.
    18. "Day:01" is displayed.
    19. Using the keypad, enter the
      day.
    20. You're finished. Press
      RLS button (your RLS button may look like a telephone handset with a
    21. "End of Session" is
      displayed on the LCD window.
  • 104 Answers
The system gets the time from the CallerID - if the line has that feature and you have a caller-ID-capable line card. If not you must set it locally. Feature**time or Feature**config then follow the menus, depending on the software version you have.
Posted on Dec 03, 2014
    Problem Solver:
  • 6 Answers
If you are on a Nortel PBX you cannot change the time on the phone. It is actually getting the time from the phone system. You know if this is the case because all phones show the same time. An administrator will have to adjust that in the system. Contact your administrator or whoever services your phone. This can usually be adjusted remotely, they may not even have to come to your office.
Posted on Oct 05, 2014
  • mistym Dec 03, 2014
    The top specified that this is not a norstar phone. The pbx does not use set programming so the feature ** is not an option.
When I press memory buttons on one particular telephone in our office they all dial reception. How do I fix this?
PDF]Telephone Features Programming Guide - Avaya Support
https://downloads.avaya.com/css/P8/documents/100142941 AvayaNORTEL NETWORKS is a trademark of Nortel Networks. ... All other trademarks and registered trademarks are the property of their ... One-line and two-line displays . ...Memory buttons . ... Call anomalies for telephones without line buttons . .... Select how you dial your calls . ... Receive a busy signal on an internal call .
Norstar How to program phone how to program voice mail ...
www.phonserv.com/1_PDF_user_guide_meridian_norstar_phone_syste...
Nortel Networks Meridian Norstar How to program voice mail phone feature codes ...Modular ICS KSU must be programmed with an M7310 or a M7324 telephone. ... Lift handset, press Voice Call key or press the Feature button, then press 66 2. .... At the LOG: prompt, enter your mailbox#(extension #. and your password all ...
[PDF]N QRTEL NORSTAR
Jan 18, 2016 | NorStar M7324 Telephone
How to I turn the universal volume on a Norton Networks T7316E Phone?
Have you tried to call the phone and adjust the volume on the set while the call is coming in? I think the only way you can adjust the ringer volume is if the phone is ringing.
Jun 25, 2015 | Nortel Networks T7316E Telephone Platinum...
How do you transfer a call on a Nortel t7208?
This is usually programmed as one of the 'soft' buttons down the right hand side of the device - subject to the programming of your phone / and the system.
Usually the T7208 is connected to the BCM range of PBX systems - in which case, to transfer a call, you'd use Feature 70. You could, of course, program this into one of the buttons yourself, so you only have to press one button to do so.
Hope this is of use to you. :)
Oct 29, 2013 | Nortel Lands Phones
New phone - plug in, know what the extension is, how do I know what the direct line is?
If you want to know the extensions number of your phone of any information about the programed feature on any button you just click on feature (button with nortel logo) then * then 0 then the button and it will give the information about the button. For extension you should use the intercom button which is normally last button on the buttom of your rigth hand side.
Jan 07, 2013 | Nortel Norstar 16-Line PBX Speakerphone
Need to reset the time on a client's nortel phone.
It depends on which Nortel System your client uses, and which level of software they have in the system. You can try "Feature * * T I M E" (Feature, star, star, 8 4 6 3). If that doesn't work, we'll need more info about the system. Good Luck!
May 20, 2010 | Nortel Norstar 16-Line PBX Speakerphone
Forwarding Calls to Outside # for Nortel T7316
You can set divert for the calls to another number. Do check for the call settings and activate the divert based on situation like.. When busy. Not reachable.
Aug 19, 2009 | Nortel Norstar 16-Line PBX Speakerphone
Nortel t316e phone only rings 2 times
You could have a CICS, and MICS or a Nortel BCM. Which do you have?
You will need to access admin programming, do you know how?
Jun 26, 2009 | Nortel T7316E 2-Line Corded Phone
How to change time on my T7316E Nortel phone
Step 1
Press the FEATURE key followed by **8463
Password Retry Step 2
Press 266344 on the dial pad buttons to enter the DEFAULT password. Your password MAY BE DIFFERENT! The display will show the following options:
Hour: 01 Next Change Step 3
Select CHANGE - the display will show the following options:
Hour: __ Cancl Step 4
Use the dial pad buttons to enter the hour. You must use two digits for all hours (i.e. "08" for 8 o'clock). You will be prompted to enter AM or PM. Select CHANGE and OK to choose PM. AM OK Change Step 5
After you have entered the hours, select NEXT. The display will show minutes as 00. Use the dial pad buttons to enter the minutes. If you are just changing the time, press the RELEASE (RLS) button to end your session. The time will be changed and the date will remain the same.
If you want to change the date, select NEXT.
Minutes: 00 Next Change Step 6
The display will show 99 as the year. Using two digits, enter the year using the dial pad buttons (i.e. "05" for 2005).
Select NEXT, and repeat to change the month and the day.
Year: 99 Next Change Step 7
Once you have entered the day, press the RELEASE (RLS) key to end your session. This will save the changed time and date.
Mar 11, 2009 | Lands Phones
Changing names on Extensions
Press "Feature **ADMIN", go to NAMES, Then go to Sets, and from their its just like texting
Aug 05, 2008 | Nortel Norstar 16-Line PBX Speakerphone
Changing name in nortel T7316E handset
We would like to change the name displays on our phones
Mar 05, 2008 | Nortel Norstar 16-Line PBX Speakerphone
Nortel Norstar 16-Line PBX Speakerphone Logo
11,059 people viewed this question
Top Nortel Lands Phones Experts
george  peters
george peters
David Burbee
David Burbee
Shehu Pro
Shehu Pro
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
