Question about HP Office Equipment & Supplies
49.4C02 - HP Office Equipment & Supplies
  • Anonymous Aug 21, 2008
    i print document in PDF, and my HP show me this error in display!
    Someone, give me help in this trouble?
This is supposedly a problem with postscript level 3 by adobe acrobat (which is default there). Try to print either as "bitmap" or use the postscript level 2 setting in acrobat and the printer driver.
With PDF at PS3 setting, the PCL6 drivers often fails printing all the features of PDF Documents. Latest PS driver is recommended.
Another problem causes the formatter of many printers to crash occasionally which has to do with the new "calibri" font in office 2007. This font has no embedded equivalences on the machine. Recommendation: Set the "TTF printing as bitmap" option to enabled (on PCL drivers) to avoid this problem. On PS, the font should be downloaded to the printer where necessary (font download option enabled).
Posted on Nov 06, 2009
Update the lan card firmware and the printer firmware with webjet admin hp software.
Regards
François
Posted on Feb 16, 2009
It's a document pb ... cancel this job in progress in properties of printer and restart printer
Posted on Nov 10, 2008
I Have Fault Codes on the Display.
Problem solve someone tried to print a PDF file which lodged the fault our It Dept deleted the print spool and Re-set the printer all ok.
Jan 14, 2010 | HP Color LaserJet 5550hdn Printer
49,4c02 error to continue turn off then on
I would try clearing your print que as it could be a corrupt print job and disconnecting your network cable and reboot the printer, make sure you have the latest firmware. hope this helps
Nov 24, 2009 | HP LaserJet 4700 Printer
Hp laserjet 4650n
Hi 123sha:
49.XXXX
PRINTER ERROR
To continue
turn off then on
A critical firmware error has
occurred that caused the
processor on the formatter
to abort operation. This type
of error can be caused by
invalid print commands,
corrupt data, or invalid
operations. In some cases,
electrical noise in the cable
can corrupt data during
transmission to the printer.
Other causes include poorquality
parallel cables, poorconnections,
or home-grown
programs. On rare
occasions, the formatter is at
fault, which is usually
indicated by a 79 Service
Error.
1 Press CANCEL JOB to
clear the print job from
the printer memory.
2 Turn the printer off and
then on.
3 Try printing a job from a
different software
program. If the job
prints, go back to the
first program and try
printing a different file. If
the message appears
only with a certain
software program or
print job, contact the
software vendor for
assistance.
4 If the message persists
with different software
programs and print jobs,
disconnect all of the
cables to the printer that
connect it to the network
or computer.
5 Turn the printer off.
6 Remove all memory
DIMMs or third-party
DIMMs from the printer.
7 Remove all EIO devices
from the printer.
8 Turn the printer on.
9 If the error no longer
exists, install each
DIMM and EIO device
one at a time, making
sure to turn the printer
off and on again as you
install each device.
10 Replace a DIMM or EIO
device if you determine
that it causes the error.
Try new network card
pdouglasss
Jun 18, 2008 | HP LaserJet 4650 Color Printer Manual...
2,889 people viewed this question
Seeker5211
Seeker5211
