Question about Xerox WorkCentre Pro 555 Plain Paper Laser Fax
Cannot Send Faxes
We receive an error code in the status report called "NG BO." We receive faxes but cannot send them. We have never had this problem in the past. We checked the phone line and it appears ok.
  • Sarah K Apr 21, 2008
    It seems that your solutions are very good, but I am a bit unfamiliar with your terminology. Can you tell me what "Main PWB" means? Also, what is the ETI 170535? Finally, what is the V34 Modem? Is it just the modem for the fax machine?
    Thanks for all the help,
    Sarah K
    Yes, it is 100 percent of the time that I can't fax. I have tried several different numbers. Thank you for all your help.
    President:
  • 2,072 Answers
Problem:
Not sending to long distance and government sites with encyrptor. Note: NG is not actually part of the Fault Code. NG stands for No Good on the Activity Report. Cause:
Not enough time to hand shake. Another cause of B5 can be a faulty Main PWB. Note: Should you wish to change the Main PWB, consult the following ETI 170535 to insure that you are selecting the correct part number. Solution: Cannot Send Faxes - thumbsup.gif Fixed! thumbsdn.gif Did not fix. On speed dials and one touch numbers that the Customer is having problems with, you will have to modify the number to be dialed. What you have to do is add pauses to the end of the number. (example 555-5555 does not send to, error B0 (that is B Zero ) every time / then start adding pauses at the end of it until it works. Example 555-5555#. in some cases in Winnipeg and surrounding areas we have had to put up to 6 pauses to get a successful send. Note 1: These were to Fax Machines with encryptor devices and long distance...Avoid Call Backs. Inform the Customer of this. LEAVE instructions on how to do this. This will save your and your Customer some headaches. Note 2: Some success has been found by turning off the V34 Modem
Posted on Apr 17, 2008
  • 2 more comments
  • Rick Kasper Apr 17, 2008
    I will look up more in the morning, when I am around my actual manuals
  • Rick Kasper Apr 21, 2008
    Sorry,
    I just posted the engineering notes. Sometimes they speak a different language.
    The main board, would be in a fax the equivalent of the processor in a computer. It is the circuit board that operates the machine.
    The ETI is a reference to an engineering tip. and V34 is an adjustment you can find in either the fax or advanced fax setup on any machine. Yes that is the modem speed, in some insane software designers mind LOL.
    You could have a phone line issue also. Sending and not receiving is a more unusual issue, and most of the time is the receivig fax machine issue. I would not eliminate static, and lower phone line voltage.
    It can be a machine modem issue, but not likely.
    Sorry for the confusion.
    Can you not fax 100 percent of the time? Or just one or 2 specific fax machines? They may have their ECM. Error Correction Mode turned off.
    Hope this helps
    Note: You will be altering binary bits during this process in step 14. The binary bits count from left to right They lay out as shown in the brackets below:
    [ 7 6 5 4 3 2 1 0 ]
    The following process will turn ECM OFF both and V34 Communication speed OFF as well
    1. Enter Service Mode by turning the Machine OFF
    2. Hold down the 1 & 3 Keys while the machine is being turned back ON
    3. Press Menu
    4. Press 5
    5. Press Enter followed by 0 & 7
    6. Machine Display will now reveal Errorcorrect - ECM and the current setting will be either 1. ON or 2. OFF
    Note 1: The objective will be to insure that it reads 2. OFF.
    Note 2: Should it read 1. ON go on to step 7 & 8.
    Note 3: Should it already read 2. OFF go to step 9 next.
    7. Down Arrow to change the reading to value of 2. OFF
    8. Press Enter to lock the new setting in as being ECM 2. OFF ( The Display will read Completed)
    9. Press Stop
    10. Press Menu
    11. Press 6 & 5
    12. Press Down Arrow ( The Display will read Set Function )
    13. Press Enter repeatedly until reaching FUNC27
    14. Press Right Arrow until Bit 1 isunderlined. * See Note at Top.
    15. Make the underlined Bit read 0
    16. Press Enter
    17. Press Stop 2 times
    18. Power the Machine OFF and then back ON
    19. Now try sending to the problem Machine. It should work now.
    ETI v1.3.20.0
    166892.Error Codes B0 D0 50 2003-11-15 19:04:24
    The information below is Generic and applies to most Fax Machines.
    There are some common Customer Adjustable features that could induce the symptoms:
    Note: Not all machines have all of these features.
    1. Distinctive Ring may be turned ON. This feature is looking for a particular variety of ring tone to be present, or the Fax unit will not answer.
    2. The Machine may be set to Manual Receive. This condition would be waiting for the Customer Operator to take an action to start the process.
    3. Junk Mail (caller Junk Fax Barrier on some machines) may be turned on. The Machine will usually ring once. Then the Fax unit compares the incoming caller Fax Machine ID with ones listed in the Dial Directory. When not finding a match, the Fax Unit hangs up the line.
      (This last point is Customer phone line related.)
    4. Low Ring Voltage may be enough for the ringer to function, but not strong enough to enable the Fax Unit to pick up the line.
    Solution:
    Fixed! Did not fix.
    Note: An Analog phone line that is required for the Fax to operate will have 2 to 4 wires in the (RJ11) jack feeding to the Fax unit in the wall. Digital phone lines will have 6 - 8 wires in the jack feeding to the Fax unit in the wall. Digital lines do not support proper Fax operation
    ETI v1.3.20.0
    Solution:
    Fixed! Did not fix.
    Note: An Analog phone line that is required for the Fax to operate will have 2 to 4 wires in the (RJ11) jack feeding to the Fax unit in the wall. Digital phone lines will have 6 - 8 wires in the jack feeding to the Fax unit in the wall. Digital lines do not support proper Fax operation.
    1. Make sure the Fax has Distinctive Ring turned OFF if the Fax unit has this feature.
    2. Make sure that the Fax is set to Auto Receive.
    3. Make sure that Junk Mail feature is turned OFF if it has this feature.
    4. Only 2 wires are used in the line feeding voltage to the (RJ11) Connector Block where the Phone line plugs into the wall. The center 2 leads (called Tip and Ring) feeding to the Fax should be monitored for Voltage The following Table may help uncover a problem:
    2. Power the Machine OFF
    3. Hold the 1 & 3 Keys down while performing the next step
    4. Power the Machine ON
    5. [Fax Features] is on the display
    6. Arrow Down to Self Test
    7. Press Enter
    8. Arrow Down to Maintenance
    9. Press Enter
    10. Arrow Down to Set Function
    11. Press Enter
    12. Press Enter repeatedly until UAD1 is on the display
    13. Arrow Right and change bits 5 4 3 to a value of 1 on each of them
    14. Press Enter repeatedly until UAD3 is on the display
    15. Arrow Right and change bits 5 4 3 to a value of 1 on each of them
    16. Press Enter
    17. Power OFF and then back ON
My faxes are going through but I get error tx reports. Why is this?
because the fax is not going through as transmitted
the fax report will have OK if it was sent and received correctly
call the recipient of the fax direct and ask what the fax looks like or if they got it alright
Oct 24, 2016 | Office Equipment & Supplies
We recently switched our phone line carrier to Comcast. Since then, some of customers (but not all) cannot send faxes to us or receive faxes from us. Specifically, we can't communicate with ANY customer in...
Start with COMCAST. They are your service provider, and if everything was working well before you switched then they need to make it right. Since you are using the word customer, this means that the service disruption is affecting your business. Call customer support now.
Mar 18, 2015 | Canon FAXPHONE L170 Laser Fax - 0815B002AB
Receiving faxes, won't send faxes. Comes up line
Your fax machine thinks everything is OK. If you can receive you can send.
call the failing fax number with a regular phone and listen for fax tones.
Feb 01, 2010 | Sharp UX B700 Plain Paper Inkjet Fax
Fax series 920, can receive but not send faxes, error code 344*
Do you have or are you sending a fax to a party that has a DIGITAL PHONE SERVICE?
Jun 04, 2009 | HP 920 Plain Paper Fax
Status NG BO
POWER OFF THE MACHINE PRESS 1 3 *(star) together. switch on machine while holding this three sw.
machine will rest.
May 05, 2009 | Toshiba e-Studio DP170F Plain Paper Laser...
I can receive faxes but cannot send them
Check your fax speed settings, also, make sure you get a good clear dial tone on the line. Sometimes it wont send if it detects line noise.
May 01, 2009 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Hp photosmart 2610 all in one series. I can receive faxes but can't send them
First, in the FAX mode, scroll to PRINT REPORTS on your HP's display. You can then print out all fax activity, including failed SENDS. There should be an error code associated with the failure, and this may help to point you in the right direction. Using the HOOK button on your fax, call your cell phone. If your cell rings, answer it, and listen for the FAX TONES. If your cell does not ring, press the MENU button on your HP, and scroll to either FAX SETTINGS, FAX SETUP, INITIAL SETUP, or FAX SEND MODE. Try changing , one-by-one, any settings related to sending faxes. Be sure to write down the original setting before you change it.
Sep 10, 2008 | HP Office Equipment & Supplies
SEND ERROR
please you should ok the printing error page selection it is OFF
Xerox WorkCentre Pro 555 Plain Paper Laser Fax Logo
1,968 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
