Question about Samsung SyncMaster 753S 17" CRT Monitor
Another 753s controller problem !!
Yes another prob.!! my tube is 5 years old. my remedy is darn strange!
after initial boot and the "locked/ unlocked" window is flashing, I go play
about four games of "free cell" cards whilst holding in the EXIT button.
This seems to negate the disabling effect of the controller and then I can adjust the display to full screen etc. by the use of all the other buttons. It's a bit of a pain in the **** --- but it seems to work !!!!
A fair dinkun Aussie.
  • Anonymous May 03, 2008
    Moniter is displaying ' Control Lock '
  • 180 Answers
Check the ( 78L05) 5v not less than 3v.
Posted on Apr 18, 2008
Give it to repair by a specilist moniter repair ..., if u use Fixya resolutions u might lose ur moniter!!
Posted on May 07, 2008
Miele CVA 4066 stopped frothing milk
It sounds like the venturi tube is blocked. Have you ever removed the frothing unit and cleaned in manually? I have a model 4085 and I can reach under where the milk exit tube comes out, twist anti-clockwise (if you are looking up at it) and the whole assembly with the inlet and outlet tube comes out. These pieces can then be individually taken apart and rinsed thoroughly with warm water. If you put it back together (don't forget to twist the connector that locks it back in) and the milk still doesn't froth, take it out again and use a small needle to clear the top of the clear venturi tube which sucks air in to do the frothing. If it is really badly gunged up it might need to be replaced, but mine is 5 years old and still going with regular rinsing. My whole brew unit had to be replaced after 4 years at a cost of about GBP 200, but that's another story.
Nov 21, 2012 | Miele Coffee Makers & Espresso Machines
The freezer part of the fridge used to work so well n ice would form in a few minutes of switcfhing on the fridge. but now, ice rarely forms and ice cream simply melts. what could be the prob
Cause of that problem is a clogged in the tubing system, if your refrigerator is 5-10 years old it is a candidate for that problem. But if the refrigerator is newer, few years old then be sure the evaporator has no small hole or punctured cause by sharp object when removing frozen thing on it. Inspect it visually if you haven't found hole in evaporator then a system is clogged.
Thanks for asking.
Sep 01, 2011 | Refrigerators
Unit is 5 years old and the espresso grounds holder has become VERY difficult to align and insert up into the machine.
After 5 years, the plastic has become warped by the heat of being used. The warpage could be in the holder, in the slot it slides into, or, most likely, both. If you can't handle the difficulty, then it is time to replace the unit. Actually, 5 years on any appliance is darn good service.
Feb 05, 2010 | Briel Sintra ED-132 Espresso & Coffee...
Power supply done but display is not
Symptom : No Image on the screen. I cannot turn on the monitor.
Checklist 1 : Is the power connected properly ?
Action : Check the power cord connection and supply.
Checklist 2 : Can you see "No Connection. Check Signal Cable" on the screen ?
Action : Check the signal cable connection.
Checklist 3 : If the power is on, reboot the computer to see the initial screen ( the login screen), which can be seen.
Action : * If the initial screen (the login screen appears, boot the computer in the applicable mode (the safe mode for Windows 98/95) and then change the frequency of the video card.
* Note : If the initial screen ( the login screen) does not appear, contact a service center or your dealer.
Sympton : I cannot see the ON Screen Display.
Checklist : Have you locked the On Screen Display (OSD) Menu to prevent changes ?
Action : Unlock the OSD by pressing the MENU button for atleast 10 seconds.
Hope this helps.
Have a good day.
Dec 08, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
I have a 3-year old GE Profile gas range. Yesterday after cooking for about an hour at 350, and after the over was turned off, the "locked door" light started flashing and the door lock hook moved so that...
hi
This is a Door lock malfunction. you will need to replace the door lock mechanism. it is faulty.
Test the door lock mech for its operational value to be sure.if the door mech test is good, replace the control(ERC/Clock)
OR
check the connections that lead form the door lock mechanism to the control board. if the wiring harness is in good condition and, the connectors are not corroded, simply replace the door lock mechanism(assembly)..
hope ur prob will b sorted out
do let me kno
regards
Jun 12, 2009 | Ovens
SyncMaster 753s G2 voltage.
Dont worry chayan ghosh +500 is the correct voltage
Take Care
Bye
Apr 01, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung 753s monitor problem
try to check the B+ line voltage. Check the FET and resistors on this line.
Mar 17, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung SyncMaster 753S 17" CRT Monitor Logo
129 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
