Question about Vacuums
Shop vac QPL625 on off switch stays on. - Vacuums
  • 7 more comments
  • Anonymous May 19, 2008
    Had the same problem, removed an cleaned the on/off switch with electronic contact cleaner but problem came back. Unable to find a replacement switch anywhere.
  • Matt000001 Oct 22, 2008
    imported switch = short life. remember the old AB switch that you could count on for years. not made in China...
  • Anonymous Nov 04, 2008
    no power - one side of switch has failed -need part number
  • jeffh814 Nov 13, 2008
    my QPL 625 stays on all the time, i have to unplug it from wall outlet to stop it. need a replacement switch but cant find one. why doesnt SHOP VAC offer a part. i guess they want you to buy a new vac vs buying a $3.00 part.
  • Woodboy303 Dec 03, 2008
    Same problem with switch - please let me know if you find one.
    Scott
  • randerson143 Dec 08, 2008
    Still trying to find the part. 10 year old son thinks it is a shame you can't get the part. What we need are 10 year old engineers!
  • One49er Jan 05, 2009
    Thanks a bunch. Have been "pulling the plug" for years. :-)
  • churchill345 Mar 15, 2009
    I have had the same problem for several years except that I took the switch out, lubed it w/ WD40 and re-installed it. It worked fine for about 2 years then after a prolonged use, it totally died. I just ordered 3 from the website above. Thanks feckzar and nminadeo!!
  • Brian Shaw Mar 24, 2012
    I just ordered the switch from Digi-Key, thank you so much!! Yanking the plug out of the wall has been such a pain!
Contact Digi-Key 1-800-344-4539 or 218-681-6674 ask for part number EG1505-ND.
Cost is about $2.00 plus shipping.
See http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=EG1505-ND for part details.
You want a D.P.S.T (On/Off) mini-rocker switch.
Posted on Jan 05, 2009
  • MrHaz Nov 23, 2010
    WHAT A CROCK!!! I've been using Shop Vac for years, and we've all had the same or similar problem. One NUTJOB can't install the switch correctly and gets hurt, so the rest of us can't order a replacement switch from Shop Vac.
    Your link worked perfectly. I selected 1st Class Postal Service for the delivery and they didn't add shipping. Don't know what that'll do to my order, but this feels like progress! Thanks SO VERY much!!!
I also had a switch go bad on a shop vac-- wouldn't turn off. For less than $4.00, I got a replacement mini rocker switch from Digi-Key www.digikey.com. item # EG1505 Problem solved. My shop vac works like new.
Posted on Nov 20, 2009
I have the same problem...thanks nminadeo, I ordered the switch from Digikey and installed it...works perfectly. Thanks again! I sent ShopVac an email of how disgusted I was at them for trying to gouge people to buy the whole power unit.
Posted on Feb 03, 2009
Digi-Key is a great sourch for the switch but the EG1505-ND is only rated for 8A and the vac draws more than that. For about 40 cents more order a 1091-1062-ND. It's rated for 15A.
Posted on Jun 20, 2012
  • 1 more comment
  • Russ Blakeman Mar 31, 2013
    15A at 250V is actually a 125V 20A rating so even better yet. The 8A 125V will fail in a short time
    Also David is right on using the 1091-1062-ND 15A/250VAC switch instead of the 8A/125VAC one originally mentioned. I just replaced the switch in my 20 yr old Shop Vac and the old switch is 12A/250VAC or 15A/125VAC. Mine worked some times, had to smack the unit to get it to work. Found a rocker in my junk box that came off an old PC power supply (the good ones that actually have a rocker on back) that was same size and is 15A at 125V. Wires were soldered but removed those and cleaned the spade terminals and it works like the day I got it 20 yrs ago. Best part is I bought it as a factory refurb from Big Lots for around $20. All I've had to do to it is clean and lube inside and finally I got tired of the flakey switch and replaced it. Some knob on eBay is selling the 8A model as a Shop Vac replacement - for $12 (wow - it's a $2 switch).
  • Dan Warren Aug 15, 2013
    Hmm.. an old PC power supply... good idea.
Thanks for the info - my switch for my ShopVac went bad as well. And found out ShopVac for some unknow reason does not offer it as a "part".
Posted on Jun 21, 2010
  • Lindsey
    Lindsey Apr 23, 2014
    Thanks Steve & David. The DigiKey 1091-1062-ND is perfect. Replacing just requires removing the two screws from the handle and pulling off the cover to access the switch.
2 Suggested Answers
  • 120 Answers
SOURCE: burned out motor on QPL625 Shop Vac
well if you can find the motor ( find a place that deals with the manufacturer directly so you get the right part ) and it isnt to expensive, most shop vacs are pretty easy, if you look under the top you should see about four screws, remove those and the top should come of giving you access to the motor, take note about the wires and what they hook up to. i doubt the motor is fastend down other than that.
Posted on Sep 18, 2008
Shop vac doesn't work. Does my shop vac have a thermo fuse?
Contact the manufacturer of device. They may help you. If not, make sure that current is reaching the on/off switch and that the power is reaching the motor - if power gets to motor and still nada then the issue is probably with the brushes not making proper contact with the commutator.
Dec 23, 2016 | Shop Vac Vacuums
Our BLB500, 12 gallon, 5.0 peak HP, Shop Vac won't come on.
From what I have heard, the switch on these units can sometimes be defective. Also, looking closely at the the AC cord may help determine if there is damage to it that should be repaired.
Jan 08, 2016 | Shop Vac Vacuums
I have a shopvac model#86776-24. The toggle switch went bad and I'm looking for a replacement switch
I got a replacement switch at a local electronic supply store: Philmore Miniature Rocker Switch part number 30-043. Shop vac changed the switch recently to two push buttons from the old rocker style. This update works a lot better.
Oct 25, 2009 | Shop Vac 285-00-10 Back Pack Vac Wearable...
Vacumm wont stay on
it is either the on and off switch. or electrical issue -
we reccomend a repair shop.... preferably a vacuum shop that does
"free estimates".Like we offer : Here is our email vacs.etc@live.com
Oct 16, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Need new switch for Shopvac QSP Pro 10 gallon unit
I just went through the same problem with a Shop Vac. The switch is easy to replace but not easy to find. After removing the switch, I found a match made by Sigma Switches. They directed me to contact a local RV dealer and look in either their Coast Supply or Stag/Parkway Supply catalogs for the appropriate switch (an H2-28 in my case for a QPL45 Shop Vac). After ordering the switch and $5 later, it snaps in like the original with no problems. Certainly beats $70 for a whole new motor assembly.
Dec 28, 2008 | Shop Vac 285-00-10 Back Pack Vac Wearable...
Shop vac
is the filter in place and in good condition. To find the filter just unhook the top and lift it off.
Nov 01, 2008 | Shop Vac (464-38-10) Canister Wet/Dry...
MY SHOP VAC STOPPED WORKING AFTER USING IT FOR A WHILE
If by stopped working you mean that it no longer has any suction, then check the hose for a clog and also clean all the filters.
If you mean that it literally stopped running, then the most common cause is a faulty switch. If the machine is still under warranty, contact Shop Vac for a replacement motor, Switches for shop vacs are not available, only replacement motors. If the machine is not under warranty you can either replace the motor or the whole machine.
Oct 22, 2008 | Shop Vac Vacuums
Burned out motor on QPL625 Shop Vac
Sep 17, 2008 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Vacuums Logo
10,147 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
