Question about Thermador SMW272 Electric Double Oven
Dimming temperature and clock light on display window
The light on the display window indicating temperature has become steadily dimmer and is now almost unreadable. Clock lights are also dimming. The oven reaches the desired temperatures, so the thermastat and oven function are OK. We have recently been baking bread at temps of about 550 degrees. Could high heat have affected the lights? Oven instructions do not address replacement of bulbs on the display window. Display lights dimmed and then dissapeared. Everything functions, I'm just flying blind. Can we fix it ourselves? Identical problem
  • 1 more comment
  • Ballet66 Apr 17, 2008
    Where is the panel board and how do I access it?
  • Ballet66 Apr 18, 2008
    Thermador SMW272 single electic oven. Upon touching the "bake" pad: "bake" does not illuminate in the display window; current time remains displayed; bake temperature can be entered but does not display in the dispay window; oven turns on and tone sounds when temperature is achieved; at no time does oven temperature display.
  • Ballet66 Apr 20, 2008
    Thank you for the suggestion. I tried this as it was the easiest. Did not make any difference.
  • Thermador Master
  • 19,396 Answers
It is not heating damaging the display, if is a factory fault that affects all Thermador owens.
To fix it you will have to get a new display/relay board package, which cost is about $200/250. If you decide to have it repalced by a service company, the total will start from around $400. The display is really easy to change by itself, but you must change the realy board with it, which has about 40 different wires going to it. If you draw a diagram as you take the wires off, and label them carefully, it isn't that hard to do the whole job.
Being a reccurrent problem with this brand you can try calling thermadore and see if they are willing to at least send you the replacement parts with no additional cost.
In fact if you search inside thermador owen problems, you will find that 80% of posts are regarding same display problem.
here ar
Posted on Apr 18, 2008
  • 156 Answers
Remove the cover and unplug and replug ever connection you can find. Sometimes the slightest bit of corrosion will cause a voltage drop across a connector. That drop is all it takes to cause problems downstream. By disconnecting and reconnecting these plugs you burnish the contacts, that removes the corrosion reestablishing a good electrical connection. Sometimes it works.
there may be a short circuit or power bleed somewhere, If the first trick doesn work, I think there is nothing more you can do, you should perhaps take it to the technician...
  • 563 Answers
Hi Ballet66
As far I know , you have to replace the whole panel once this happens.
It is quite a job , so I would suggest you to rather take it in for repair.
    Master:
    Sergeant:
  • 461 Answers
Reset your oven.
1. Turn it off. Remove any power supply from the oven including removing the power Plug off the main supply socket.
2. leave it off for at least 30 min.
restart your oven......
    Sergeant:
    Champion:
  • 304 Answers
Check for the fuse on the panel board.
Posted on Apr 16, 2008
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
How do i operate the self cleaning function
Hello - Before using the self-cleaning cycle of the appliance, remove the broiler pan and any utensils stored in the appliance. Also remove any excess spillovers in the oven cavity. Allow the oven to cool before cleaning. During the self-cleaning cycle, the outside of the wall oven can become very hot to the touch.
Typically to set the controls for a self-clean the first step is to confirm that the clock shows the correct time of the day. Press CLEAN. "---" appears in the display. Press the UP ARROW or DOWN ARROW once. "3:00" appears in the display for a 3 hour cycle. To change to a 2 hour cycle press DOWN ARROW"2:00" appears in the display. As soon as the controls are set, the motor drive lock will begin to close automatically and the "LOCK" indicator light will flash. DO NOT open the oven door while the light is flashing (it takes about 15 seconds for the over door to lock). "CLn" will appear in the display during the Self-Clean cycle and the "LOCK" light will glow until the Self-Cleaning cycle is complete or cancelled and the oven temperature has cooled.
When the Self-Clean cycle has completed, the time of the day or "End" will appear in the display window and the "Clean" and "LOCK" light will continue to glow. Once the over has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. If "End" is the display and the Clean indicator light remains ON, press CLEAR/OFF. The time of the day will appear in the display.
If it becomes necessary to stop or interrupt a Self-Cleaning cycle, press CLEAR/OFF. Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. Restart the Self-Clean cycle once all conditions have been corrected.
Oct 19, 2012 | Frigidaire GLEB27S7A Electric Single Oven
Fault codes F1 and F2
Just two work there:
1.- Replace the touchpad or the clock (ERC) if the code "F1" is displayed. Disconnect the ribbon connector to the touchpad. If no code is displayed after an hour, replace the touchpad. If the code displays again, replace the clock.
2.- Replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
Parts replacement coudl look in www.repairclinic.com
Hope helps.
May 02, 2011 | Magic Chef Ovens
Display too dim to see
I purchased a new clock module off the internet to try.
Mar 22, 2009 | Jenn-Air JJW9530C Stainless Steel Electric...
Display light faded and now gone
Supposedly the electrolytic capacitors on the display board need to be replaced. See: http://applianceguru.com/forum1/18842.html
Jan 15, 2009 | Thermador SC302T Electric Double Oven
Display panel
Dim display indicates a "failing" electronic oven control. It will continue to get dimmer and dimmer until it fails completely. You need to replace the "clock" (sometimes called the ERC <---Electronic Oven Control)
This is a tricky repair. Be sure you have the power off (at the breaker box) before attempting this.
Tracy
Oct 28, 2008 | Jenn-Air WW27430P Stainless Steel Electric...
Lighted clock and controls intermittently not working. Oven still heats
HI thanks for the question. its a common problem with the clocks. first it goes a little dimmer. then a little more till it goes so dim you cant even see the temperature that you have in the oven. the clock has to be replaced. or. buy a cheap oven thermometer. and hang on the middle rack, and adjust the temp setting to match the oven temp . save a lot of money this way. thanks. please rate my answer. thanks
Oct 09, 2008 | Jenn-Air Ovens
Dim LCD's on DCS Double Wall Oven
Had the same problem last week - called DCS (which automatically transferred me to Fischer-Paykel) and was able to order the part from them.  They knew exactly what it was, and shipped to me in CA from CA, it was less than $90.  Just installed it, and the new one works swell.  One suggestion - I drew with a Sharpie on one side of each of the three parts that plug into the board to help align the new one, and to install the wide ribbon cable (not really a cable, but you'll know what I mean), pull up on the two side pieces and the ribbon pulls right out.  Keep it up and slide the new one in and then push the black piece down.  That was the only part that took me a minute to figure out.
Jul 07, 2008 | DCS (WOTD-227) Double Oven
Thermador oven display is dimming
replace the capacitors on the display unit. Just did this and it now works
theblog
Nov 29, 2007 | Ovens
I found capacitor c3 (68 uf 35 volt) had leaked and dried up, causing the display to fail. I unsoldered and tested c1, c4, c7, and made sure they were good, using a digital multimeter with the ability to test capacitors. C3 also had visible signs of leakage. Works like a charm again, and the display is bright like new!
Dec 30, 2006 | Thermador SC272T Electric Double Oven
Thermador SMW272 Electric Double Oven Logo
515 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
goober123
Level 1 Expert
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
