On my archos 705 the background colour is purple on photos and also on videos? is it possible the tube has gone?
No. There is no tube in LCD.
Posted on Sep 09, 2008
The colour has gone green and purple
I will start with a simple deduction that one primary colour has gone, the set has three Red, Green and Blue with this and our easily tricked eyesight we make other colours.
To me if this was a hulking glass tube type TV I would think one of its tube guns has stopped working this can be the chroma drive IC or more likely an out put which is mostly transistors mounted on the tube base gone bad or dry joints in this area. A tube can go but they mostly age and go off colour over time, I have also seen sets have power supply troubles which causes a low supply rail this results in some very strange events. A hoover started up in front of the screen can magnetise it as can a child with a strong magnet moving it around on the glass, a set will try to cure these last two each time its switched on (degauss) though the magnet one will be harder to cure! I am afraid it would need a service call to determine if its a joint or small part it may then be worth it, while a tube problem forget it. Also if this is a flatscreen then its possibly not worth it anyway, if its the screen+output IC set up, a screen is about 66-75% of a flatscreens build cost. On the other hand if its the main circuit board all an engineer can do is replace it with a new one (if around) because they are made in such a way with machines a man with a soldering iron stands No Chance. Hope this helps.....
Feb 15, 2015 | Televison & Video
WHEN PLAYING DOWNLOADED VIDEOS ON MY ARCHOS 705 THE SOUND IS BARELY AUDIBLE CAN I FIX THIS?
The videos you are watching have bad audio guality, you need to get a video with good enought audio.
Apr 17, 2008 | Televison & Video
My archos is hanging every time i use the video
YOU MAY BE STORE MORE DATA. DUE TO THAT SOMETIME MEDIA PLAYER WILL HANG.OTHER YOU RESET UR ARCHOS.I THINK THAT MAY BE SOLVE THE PROBLEM
Feb 15, 2011 | Archos 705 WiFi Portable Multimedia Player
Can you advise where I can buy a replacement screen for my Archos 705
Hi
You can order the screen for the Archos 705 from this link---
Archos 705 replacement screen
Link 2
Hope this helps...
Daniel
Aug 28, 2010 | Archos 705 WiFi Digital Media Player
I am unable to play you tube videos on my archos 7 . keeps showing flash payer 9 needed help
Archos 43 Internet Tablet requires YouTube2.4.4.apk to play youtume videos.
The original version is obsolete anf the new version is incompatable.
Download the YouTube2.4.4.apk at
http://www.ads-ent.com/archos43/YouTube2.4.4.apk
Jun 07, 2010 | Archos 705 WiFi Digital Media Player
Just got Archos 5 goes into error 101...
Hi there, these instructions are for the archos 705 but they are the same for the 605.
A) Download the firmware from Archos and save it to your desktop (Make sure the file name on the desktop hasn't changed from the original download file name)
B) The Archos 705:
1- Connect the unit to its power source.
2- Start the unit in recovery mode: Press the TV button first then the power on/off and keep pressing TV button (do not release it)
3- The recovery mode will start (the screen that asks for repair or format etc…)
4- Select "Repair" by scrolling up and down with the TV Button (it is all explained to move through the menu at the top of the Archos screen) (Do not press "Format" at any time)
5- Now that you are on "Repair" select it to validate your selection
6- The unit will go to "Plug the unit etc…" plug it with the USB cable to the computer
8- Wait until Pc should recognizes your Archos (around 5 seconds)
C) Computer
1- From your computer select the firmware file you downloaded from the net and put it in your Archos (in the root folder, nowhere else, where it has the folders, music, videos, pictures etc… as a file)
D) On the Archos 705:
1- Select "Ok" on the Archos (on & off button) shortly to select and confirm the file is now on the Archos
2- you are done! The Archos 705 should now read through the file you have transferred and repair the system
3- DO NOT DISCONNECT the power cable until the process is finished
4- When done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
5- Press on/off button to reboot
Your unit should restart with a fresh repaired, updated system like day one.
Jan 21, 2009 | Archos 605 WiFi Digital Media Player
Battery difference between archos 704 and 705 (wifi) ?
I use the same batteries in both units. The only difference is the colour of the back plate and the label on the inside. Clone and extended batteries are different backs anyway.
Nov 17, 2008 | Archos 605 WiFi Digital Media Player
 Grubhead
Grubhead
