FixYa.com
Tags:
Lexmark X73 All-In-One InkJet Printer
Won't print (by 3 users)
posted by lambeauleap on Apr 16, 2008
I have a Lexmark73 printer/scanner/fax and it will no longer print. When I try it sounds like it's slipping gears and the paper starts to feed but will not go all the way down. I have tried 1 piece at a time as well as a stack of paper to no avail. I'm guessing the rollers or wheels or whatever that pull the paper down to the printing heads have worn out and I will probably need a new printer It's about 5 years old. Thank you, Mark
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by RJeanK, posted on Apr 22, 2008
I have the same issue. Recently, we had a paper jam and now the printer won't print much of anything at all. It doesn't pull the paper through properly, and if it prints anything at all it's not spaced properly and prints line upon line.
Comment by marg42, posted on Apr 21, 2008
Same thing I just put in new cartiages and when I tried a test print it was like it printed on top of the print. then when it tries to spool the paper out it jams. Tried different paper weight.
Can you Help with these Printers problems?
lexmark5495 printer
I have tried everything I know... Answer This...
Lexmark x7350 will not scan,...
My printer suddenly stopped... Answer This...
printer won't print
I have installed two new ink... Answer This...
X73 found loose spring
My x73 wasn't feeding paper and... Answer This...
clicking printer
It seems that I'm having the... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
