Have a panasonic hd 53'' & it opens but no sound & image...& also the red led is blinking; what can I do?
    Genius:
  • Televison & ... Master
  • 1,673 Answers
The set needs service. This can be a failure in part of the power supply, or one of the boards has a defect that is pulling too much current.
With the proper service procedure and troubleshooting the fault can be found, and service can be done.
Jerry G.
Posted on Apr 16, 2008
Panasonic TX-L42E5B blinks 3 times which board is faulty
When an abnormality has occurred to the unit, the protection circuits operate and set the unit to stand by mode. At this
time the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
Fault maybe on the A board 3.3V SOS give me your email & i send you the full timing chart.
Apr 04, 2016 | Panasonic VIERA TX-L42E5B 42" LED TV...
Panasonic pt53wx42f
This sounds like a main power board issue. After you unplug it, it will work? Are you planning on trying to service it or having it serviced?
Thanks,
Lee
Jul 13, 2008 | Panasonic PT-53WX42 53" Rear Projection...
When i turn on the tv ,it have 1 blinking light( the red light )and tv open and close open and close and so on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
Jan 01, 2016 | Panasonic TCP55VT30 55" VIERA 3D HD Plasma...
Power would not stay on red led flashes
I do not think we will get a response from person asking but you are correct, number of blinks indicates where problem is, the two most common are either a sequence of 3 blinks or one of 5 blinks.
Hard to help unless blink count is known.
SD TECH
Oct 23, 2011 | Panasonic PT-53WX42 53" Rear Projection...
Hello, I have a 53-inch Panasonic PT-53WX42F TV, and it refuses to turn on. No picture, no sound. All it does is the tiny red power light blinks 3 times repeatedly. Can I fix this myself? What parts do I...
Thats a convergence failure when the led blinks 3 times. Your model uses the PT47WX42 convergence repair kit available from www.tvrepairworld.com the kit contains the parts and the CD with instructions for the repair.
Jul 16, 2010 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic cinema vision pt-53wx54j does not turn on. red power led blinks 3 times.
Hi
Thanks for using FixYa. 3 blinks means convergence output failure and to resolve this you’ll need to change the convergence chips which are located behind the black heat sink; you can see once you open the back off the TV. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 07, 2010 | Panasonic PT-53X54 53" Rear Projection...
Tv not coming on and red led blinking on front panel when I try to power on
the blinking led is a error code. Let me know the number of blinks and I will assist you.
Nov 24, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Red led light flashes 6 times and tv won't turn on
Hi friend,,,,,,
it is an indication of an error code ,,,,,,normally 6 blinking code refers to an power set up problem,see incoming voltage with an multimeter.......
thank u,,,,,,,,
May 03, 2009 | Panasonic PT-53WX53 53" Rear Projection...
3D image on panasonic 53''
Sounds like the red and green images have shifted.
In your settings menu there should be an option for it to self adjust or manual adjust of the red and green images alignment.
Apr 02, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic projuction screen tv.
3 blinks is the error code for the convergence ICs. You need to replace both STK392-110 convergence ICs. You can get replacement ICs at the following link and they provide installation instructions with pictures.
http://servicemanuals.vstore.ca/
Oct 12, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
