Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Tredmill error code
Horizon fitness treadmill model T71, auto-calibrate, treadmill will stop, then display E1, whats wrong? and what does this mean?
  • 2 more comments
  • Anonymous Aug 20, 2008
    i have same problem please advise
  • Titonton Oct 02, 2008
    My Horizon Fitness Advance 300 Treadmill is showing an E1 error.
    I haven't used it all Summer. The other day I tried to use it and it gave me that error. Can someone help me please ?
    my email is : tibobouss@yahoo.com
    Thanks !
    Nick
  • 195871 Jan 19, 2009
    Bowflex - TC1000 TreadClimber error message ( E1) I wonder if the speed sensor is bad and causing the machine to shut down
  • Gary Davd
    Gary Davd May 11, 2010
    so what is the problem with your washer??
Moat likely a problem with the motor control board. See treadmilldoctor.com
Posted on Nov 17, 2008
  • jlam247 Oct 09, 2010
    Your problem might be that a magnet has fallen off from within the treadmill. Here's an illustrated guide that should make fixing it easy:http://fixmytreadmill.blogspot.com/2010/...
    Good luck.
Why does my treadmill stop after a few seconds then error code E1 displays. What do i do?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
True Treadmill Errors and Service Messages
  • The True 600, 700, 725 and 750 series treadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
  • The error messages that may be displayed by the built-in diagnostics are as follows:
    • E1:INCLINE
      • This means that the incline is moving when it has not been commanded to.
    • E1:MINIMUM
      • This is a minimum incline calibrating error that can be cleared by calibrating the incline.
    • E1:RANGE
      • This means the difference between the treadmills zero position and maximum incline is not sufficient.
    • E1:STALL
      • This means that the incline is not moving when it has been commanded to.
    • E2:OVERSPEED
      • This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
    • E2:CAL
      • This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
    • E3:EEPROM
      • This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
    • E5:SENSOR
      • This error occurs when there is no speed or RPM feedback detected from speed sensor.
  • The service messages that may be displayed by the built-in maintenance reminders are as follows:
    • S1:LUBE
      • This service message displays when it is time for inspection of the deck lubrication system.
    • S2:CLEAN
      • This service message displays every 500 miles and is your prompt to clean the treadmill.
    • S3:MOTOR
      • This service message displays every 2500 hours and is your prompt to check the motor brushes.
  • This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
Errors for True Treadmills E5 Sensor E2 Cal S1 Lube and more
Oct 12, 2015 | Exercise & Fitness
SOLUTIONS TO E1 PROBLEMS IN TREDMILLS
Dear Sir:
adjust the speed sensor, clean, and tight very well.see the diagram attached
2) Test the input voltage motor, if there are THE MOTOR need repair
3) Tes the output voltage in the main motor board , if there are Not, the board is faulty.
Of course run the software calibration aftr you fix it.
sincerly. God bless you
Apr 24, 2012 | Bh Fitness X8 Treadmill
My Horizon fitnessT101 is brand new and i put it all together.Than i used the magnetic key and started it and the treadmill didn't start it just displayed E1 on the monitor.
Had same problem. I called horizon and after troubleshooting, they could not solve and replaced the entire circuit board. I was under warranty , so i was fortunate to not have to pay for one.
Sep 09, 2011 | Horizon Fitness Horizon T101 9 Program...
After starting the treadmill 10 seconds later E1 apears on the display
Your problem is that a magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Sep 16, 2010 | Horizon Fitness Merit Fitness 725T...
E1 error on display
E1 code means an elevation problem but I am not familiar with the new Spirit models. Been trying to set up with Spirit now that I am getting calls on them again. Its been 5 years since my last call, best thing to do is get in contact with Spirit and they will direct you on what to do or give you phone # to call a service provider. The older units had a calibration sequence for such a problem.
Customer Service and Parts Departments
800-258-4555
May 27, 2010 | Spirit Esprit ET10 Folding Treadmill
Tredmill error code e1
Trimline treadmill starts up then code E2 comes up, and the display shuts down.
Any ideas???
Apr 02, 2009 | Nautilus Tr300 Treadmill
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
1,499 people viewed this question
Dan Webster
Dan Webster
Sal De
