Question about Jensen VM9020TS Car DVD Player
My head unit wont play dvd's wile im driving
I need to know the codes i have to put in my haed unit do i can dirve and watch movies email me at tyrrel420@aim .com thanks tom
  • 1,586 Answers
There is no e-brake override code. You have to hardwire it to bypass the e-brake. Take the peach-colored wire and ground it to metal inside the dash. Put a toggle switch inline on the wire and mount it somewhere you can reach it. When you get the blue screen when starting a movie, open the switch for 3-5 seconds, then close it again to reapply the ground. Your movie will start up, and you can then drive away with it playing.
Posted on Oct 08, 2008
My PC wont play album I requested.
You only need compatible dvd player software to listen to movie dvd disks. For playing standard audio cd disks, nothing is needed since this support comes built in-to the OS, (Windows XP or higher)
Apr 24, 2014 | Computers & Internet
Usb to watch movies on television
You need some sort of computer to watch a movie through the media station of the L2320A. The USB ports on the unit are a USB hub (one connection to the computer, two for devices); without a computer they are useless. Some of the media players (DVD/Blue-ray/media streaming units) that can play a movie from a USB drive without additional computing power. The format of the movie on the drive will limit which device can play the movie.
I wish that I had better news for you. Retrevo has a link to the manual for the L2320A here: http://www.retrevo.com/support/LG-L2320A-Monitors-manual/id/440ci363/t/2/ . You will need to enter a code to access the file.
Nov 13, 2012 | LG Flatron L2320A 23" LCD Monitor
1. How do I watch the same movie on both screens on the Philips PET9422 37 9 in. Dual screen DVD players? 2. I bought a refurbished model but did not get a user's manual. How do I get one?
hi,
You can do the following to watch the same moving in both the screen.
1.Connect the AV out of both the unit together. with supplied av cord
2. If you want to watch the movie played on the first unit then put the DVD/AV IN switch of first monitor to DVD and the DVD/AV IN switch of second one to AV IN.Now you can watch the movie played on the first monitor on both monitors.
3. IF you want to watch movie played on the second unit then put DVD/AV IN switch of second monitor to DVD and the DVD/AV IN switch of the first monitor to AV IN. Now you can watch the movie played on the second monitor on both monitors.
I have the manual of the same . As it is large pdf file can't sent through fixya. If you can sent your email id through fixya will sent you the manual
ok
Jun 11, 2011 | Televison & Video
My blue ray bd 21 wont play some movies im told
My advice is to contact the company that makes the unit and ask them if it requires an upgrade. Let me know what they say so i may advise further. Thanks.
Apr 16, 2010 | Sharp BD-HP21U Blu-Ray Player
I have a 2006 cadilliac cts that came with a factory dvd player. i can watch movies until i put it in drive. when i put it in drive the scree goes blank and i can only hear the movie. Is there a way that i...
You can try the procedure for the VM9311TS model (the one I have) - I don't know if it'll work but it's worth trying. Put in a DVD, and let it start playing. Then hit STOP on the remote twice, and enter the code 1264. If you were able to see the actual movie at this point, you'd see a menu pop up. Push down twice, then ENTER. At this point the blue screen should clear and you should see the movie itself. You'll have other options on that menu, like a macrovision option to allow you to see burned DVDs. Set what you like, then on the remote, hit SYS SETUP twice to lock in your choices.
Nov 14, 2009 | Jensen VM9510 Car DVD Player
ANOTHER BROKEN XBOX 360
replace heat pads they are so cheap. wrap pennies in electrical tape and put it on were the heat pads were. use Heat Sink to glue it on
Oct 01, 2009 | Microsoft Video Game Consoles & Games
Pioneer dvd r/rw wont play a dvd
If your computer recognizes a disc in the drive and operates normally, Id assume you would need a DVD player or codec to be able to actually watch the DVD. PowerDVD rings a bell.
Have you tired that? I know Windows Media Player by default wont let you watch a movie without first downloading a codec.
Mar 19, 2009 | Pioneer (DVR-K15 BLACK) DVD RW Dual Layer...
Jensen double din dvd monitor uv8020
Here's what you need to know: DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On the Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In mine, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in the manner of the e-brake cycle I mentioned earlier.
Sep 11, 2008 | Jensen VM9510 Car DVD Player
I have the vm 9311ts how do i bypass to watch movies while i drive
I have the same head unit in my Audi. Here's what you need to know: DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On the Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
Sep 04, 2008 | Jensen Car Audio & Video
Venturer cd/dvdcar head unit
Ground the brake wire(light green) to the frame. Goodluck.
Mar 07, 2008 | Car Audio & Video
Jensen VM9020TS Car DVD Player Logo
193 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
