Question about Fuji FinePix S3100 Digital Camera
Fuji FinePix S3100 won't turn on
The camera said that the batteries were low, so I replaced the batteries with newly charged NiMH batteries. Nothing happened. So I replaced those batteries with different NiMH batteries. Nothing. The camera is dead. Fuji wants me to send it to them for inspection. It is 3 years old. I really like the way this camera feels in my hands and all of its' functions. Is there an internal battery inside the camera that needs to be replaced? I don't know, what do you think. I'm good at fixing older stereo gear with discreet circuits, but am out of the loop when it comes to integrated circuits being used nowadays.
  • wyogram Apr 29, 2008
    I have exactly the same problem. I have changed the batteries out twice and nothing happens when I turn it on. Is there an internal power source I am missing? Help would be appreciated. Wyogram
  • hrdlick Jul 27, 2008
    my opinion is that the problem lies with where the batteries "touch" the leads on the camera. the lid part of the camera where the batteries go in look to me like the residue that forms around a cars battery terminal after a long time. ugly acid appearing stuff. I thin kthis interferes with the power somehow
There is a option in the menu that turns the camera off after 2min. and then after that it is hard to get started.I took out the rechargable batteries and installed new duracell batteries,and it started and then I went to the menu and disabled the powersaver option.
Posted on Jul 28, 2008
Where is the fuse located in a Fuji s3100 camera?
Sorry, did did not put in any fuse in this camera. When it does not start up, check the battery, if it still holds some charge and the contacts, both on the battery and in the camera. All contacts should be clean and shiny. Only clean with a dry cloth or cotton swabs. NO SHARP tools.
Jan 30, 2015 | Fuji FinePix S3100 Digital Camera
My focus lens is stuck in the open/out position. i cannot take photos, the screen says unable to focus. help!
It sounds as though the battery is low and the camera is faulting and has become "stuck" because of it.
I would suggest you try this first to see if it is.
Turn the camera off, take out the batteries and then re-insert with new ones or charge the old ones before you re-insert them. Make sure the batteries are fully charged.
This "should" jumpstart the camera back to the original configuration.
If this doesn't work please post back.
Hope that helps!
Nov 09, 2009 | Fuji FinePix S3100 Digital Camera
FUji FinePix s1000fd, camera will not power on with new batteries, when it powers on it goes off in a few seconds or minutes indicating battery low, i have used fully charged batteries, ordinary batteries...
I have same problem as edmoze mentions above - batteries went dead. I first tried to use regular Duracell AA and it would still not come on. Went to internet & it recommended getting the Duracell rechargeable NiMh which I did. Got the charger & last nite they charged overnight. Today the camera did come on & I was able to download what I had taken. But what concerns me is that the low battery light is still flashing after a night of charging. What's up? Should I expect this kind of battery problem to continue? Seriously considering getting a Nikon Coolpix.
Sep 02, 2009 | Fuji FinePix S1000FD Digital Camera
Fuji finepix e510 won't turn on
If your Fuji e510 battery system is like the Finepix S3000 or the S3100 take a look at the following postings: Finepix S3100 (Camera power does not come on...) by banobo of Feb 07,2008 and check out solutions #2 & #4, (Mine is #4), Also see posting by "tomawamba for Fuji S3000" and my slightly differently worded solution.(Only one posted). May be best to get camera working before connecting with anything else. Good luck, be patient.
Jan 18, 2009 | Fuji FinePix E510 Digital Camera
Fuji FinePix S3100 will not turn on.
Sorry, no real solution. My friends have one that would not turn on and they left it without batteries for a month, then put the batteries in and it worked. Mine has failed and will not turn on. I have left the batteries out but nothing has miraculously fixed itself yet. May have to send it in to Fuji.
Apr 29, 2008 | Fuji FinePix S3100 Digital Camera
Lens does not retract
It could be that your batteries are low. Try replacing the batteries.
Mar 15, 2008 | Fuji FinePix A350 Digital Camera
Camera power not coming on
well hard to answer but i suppose you use nimh batteries if now work vist your nearest service center also clean the contacts inside
little help i hope thx ake
Feb 07, 2008 | Fuji FinePix S3100 Digital Camera
Fuji FinePix A400
Take the batteries out and clean the contacts
Those at the bottom of the battery compartment you can clean with the eraser at the end of a pencil
do the same with the lid.
Make sure the batteries are fresh/charged
When you close and lock the compartment lid squeeze it shut then turn on- it may be a contact problem.
If this fails then it will be a repair shop job
Dec 07, 2007 | Fuji FinePix S3100 Digital Camera
Fuji Finepix 50i won't switch off & has frozen.
There are a few things you can try. I had a fuji that would sometimes do this also. I found low power was one of the main issues. First try a new set of NiMH as alkalines just wont cut it specualy with these older cameras. Next check the memory card door. There is a little tiny switch on the memory door that will turn the unit off if the door is opend. Make sure the door is fully closed and maybe even hold it down tite while you try and use it.
May 03, 2006 | Fuji FinePix 50i Digital Camera
Fuji FinePix S3100 Digital Camera Logo
136 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
