Question about Toshiba Satellite A10-S100 Notebook
Toshiba Satellite Pro A10
What is the maxium size hard disk I can use in my laptop. Currently I have a 20Gb 4200rom IDE UDMA 100 drive installed. My drive is model: IC25N020ATCS04-0
Thanks Peter
  • IFBEAR Apr 17, 2008
    Okay thanks for that info. So the BIOS is not a limiting factor then? The BIOS is very baisc and does not allow me to enter sectors etc. I will see what is available in my local computer shop, on line here in the UK and at computer fairs. Thanks again.
  • 71 Answers
Well if you got the money to spend then you can probably stick at least a 250 gig (probably even more than that) hard drive in it. Reason i say 250 gig, cause i noticed this here - http://www.newegg.com/Product/Product.aspx?Item=N82E16822136159 - if that's too pricey then almost half that price will get you 120 gigs here - http://www.newegg.com/Product/Product.aspx?Item=N82E16822136130 - but whatever you get you should be good to go with as long as it's ATA and not SATA cause your laptop works with ATA only. And go with 5400 rpm's for sure (if you can find you a 7200 rpm then your really in business) I would go with a Western Digital or Seagate because they are more reliable. Hope this helps you and good luck.
Posted on Apr 17, 2008
Installed new WD HDD (160Gb) into Toshiba Satellite A10-S167. Entered BIOS edit, but can't get laptop to recognize the new HDD (which replaced a smaller, failed HDD)
Shouldn't have any problems on the A10 series working with a 160GB drive, so long as it's an ATA/IDE type with a 44-pin connector. If it's not recognizing the drive, could it be that the pins were not precisely lined-up with the IDE connector? I'd remove the drive, make sure the pins are still all straight, reinsert it into the HDD compartment and see if it makes a difference.
Aug 31, 2011 | Toshiba Satellite A10-S167 Notebook
How do I remove the hard drive in Toshiba SatellitePro A10 EN? (Removing the plastic cover exposes only the end of the hard drive. I'm reluctant to just start pulling on it!
  • The original Toshiba Satellite Pro A10 HDD is fitted into a Toshiba Satellite Pro A10 Hard Disk Drive cradle - Toshiba Satellite Pro A10 HDD caddy.
      • Gently remove the cradle from the laptop, yes pull on it
      • Unscrew the original Toshiba Satellite Pro A10 Hard Disk Drive & remove it from the cradle.
      • Screw the new Toshiba Satellite Pro A10 Hard Disk Drive into the cradle & refit the cradle into the laptop.
      • Re-install XP or Vista
          Aug 21, 2010 | Toshiba Satellite A10 Notebook
          Hard drive specifications for Toshiba A10 laptop
          IDE is the flat 40 pin cable about 2" wide.  Other than that it could be SATA, which is a small, plug.  About 3/4" inch by 1.8".  Take it apart and see what cable it has.  Pretty much any hard drive will fit providing it has the same cable attachments.
          Mar 03, 2009 | Toshiba Satellite A10 Notebook
          Hard disk capacity increase
          yeah you need to replace the old hard disk to new IDE 120GB hard disk.
          Jan 20, 2009 | Toshiba 100GB Laptop for Satellite 2400,...
          Hard drive and memory
          the laptop should pick up a 20gb or 60gb ide hard drive with no problem
          Memory Upgrade for Toshiba Satellite 2775XDVD Laptop, the Toshiba Satellite 2775XDVD Laptop takes the PC100 SDRAM SODIMMs Memory Type, and comes installed with 64 MB (non-removable) of Memory. You can upgrade your Toshiba Satellite 2775XDVD Laptop to up to a maximum of 192 MB Memory, the system has 1 socket to install Memory, already with 64 MB (non-removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
          Choose the following Memory Upgrade for Toshiba Satellite 2775XDVD Laptop
          Dec 01, 2008 | Toshiba Satellite 2775XDVD Notebook
          Hard disk
          not too hard..should be a couple of small cross screws under the bottom, just remove them, and slide out the old drive..
          May 12, 2008 | Toshiba Satellite A10-S100 Notebook
          Need information please
          This mainboard supports UltraDMA 66/100. UDMA is a technology that accel-erates the performance of devices in the IDE channel. To maximize performance, install IDE devices that support UDMA and use 80-pin IDE ca-bles that support UDMA 66/100.
          Feb 25, 2008 | EliteGroup K7S5A Pro Motherboard
          I need to replace my hard disk notebook with a bigger capacity hdd
          Toshiba is rather secretive with their documentation. It is hard to find. Google TOSHIBA SATELLITE A10 SERVICE MANUAL and check the available offerings.
          You now have a 5400 RPM, ATA 100 drive. You should not have any drive size restrictions. Shops are advertising many large drives as compatible.
          I suggest that you purchase only a 7200 RPM drive. The faster speed will perk your machine right up.
          I have not worked on Toshiba machines but suggest you have all restore disks and passwords at hand.
          Feb 18, 2008 | Toshiba Satellite A10 Notebook
          Open Questions:
          Toshiba Satellite A10-S100 Notebook Logo
          138 people viewed this question
          Top Toshiba Computers & Internet Experts
          Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
