Question about Sony Handycam CCD-TRV318 Camcorder
I have a Sony Handcam Vision Model #ccd-trv318 ntsc and I would like to know how to connect this to a computer. It appears the camera doesn't have a usb jack on it.
  • nahom2-s Apr 29, 2009
    how can i copy the video from my handycam to pc tell me the software
Buy an a/v cable($15-30) and a dvd recorder($50-100).
Some dvd recorders allow you to change type of recording.
Then you can play, record or copy your dvd on the computer.
there are also free conversion programs you can download, to convert to different types of video.
pc - beach city texas
Posted on Nov 23, 2008
    Genius:
  • Sony Master
  • 1,673 Answers
I don't know this exact model, therefore this will be generic.
There should be an A/V output on your camera. You will require an A/V capture card and software installed on the computer. You will need the A/V cable set that is compatible to go between the computer and the camera.
If the camera has a fire-wire output which most all the new ones now have, you will need to install a fire-wire card and the necessary software on to the computer to read videos from your camera.
If your computer is too old, or too slow, or does not have adequate resources and RAM's, it will not be able to handle the video from your camera. Make sure your computer will be compliant before running out and buying the extra hardware and software to do this with your computer.
Jerry G.
Posted on May 02, 2008
Its an old video camera. i want to put these videos from my sony handycam vision ccd-trv43 ntsc hi8 camera onto my computer. Please help!
You you need to transfer then through the dv jack, so you will need a d8 sony camcorder, or similar. Larry's Electronics
Apr 26, 2010 | Sony Handycam CCD-TRV43 Camcorder
Sony ccd TRV108 NTSC does sound recording only black screen in viewfinders and lens cap is off. thanks battery charged dclee4@telus.net thanks
On these camcorders the "RCA" video jack is a switching jack. This is so the cam will record from an ext video source instead of live video. Try exercising this switching lack by repeatedly plugging in and unplugging an rca video cord. This may be a solution to your problem.
Cheers
Feb 20, 2010 | Sony Handycam CCD-TRV318 Camcorder
I have a sony Handycam videoHi8 camcorder, my problem is that it
Try using different tape or a new tape in the Camcorder.
Clean the video heads using the Sony V8-25CLD cleaning cassette.
You may also try pressing and holding the Reset button for 30 seconds to reset all the settings in the unit to the factory defaults.
Good luck!!!!!!!!! !!!!!!!!!
Sep 19, 2009 | Sony Video Cameras
Sony handycam CCD-TRV318 NTSC Telephoto/wide
Tele-wide switch is fauly.(technical name is SWITCH BLOCK CONTROL).repalace by expert.
Jun 20, 2009 | Sony Handycam CCD-TRV318 Camcorder
Sony Handycam Vision videoHi8 will record sound, but no picture.
It is known problem of bad ccd imager in camcorder and requires replacement of that part.
Sony will repair CCD-TRV318 Free of Cost in ccd imager problem.
Please click Sony CCD Imager Support for details.
Good luck.
Jan 27, 2009 | Sony Handycam CCD-TRV318 Camcorder
Sony CCD-TRV318 Hi-8 How do I connect it to a MAC?
you probably cannot connect you camcorder, you can just use video capture software when you play the dvd on your mac.
there are 100s of free to use capture software, just google & choose the one you like.
May 23, 2017 | Sony Handycam CCD-TRV318 Camcorder
Picture shakes when I zoom
I don't know how you can easily tell the spec for the anti-shake is working on your camera. There is a specific specification for how much it can compensate. There is a factory spec that specifies that with a specific lens magnification ratio, the camera can be moved a specific number of arc-seconds and display within a specific amount of movement error. At home it would be impossible to do a technical evaluation of this feature.
What you can do as a user is to read the instruction manual about the option and see how to make sure that it is turned on in the camera's menu section. It is possible that your model may not have the feature. This you have to check in the spec sheet that came with the camera.
When the anti-shake is turned on, you should see the picture appear to be more stable than when it is turned off. With high zoom settings, it will be less stable looking than with wider angles of zoom. It does have its limitations.
Professional photographers normally don't like the anti-shake feature for shooting videos. For still pictures it is a good feature if you want this type of performance. This is because with moving video taping when the camera is being panned in small motions, the smoothness of the pan is taken away. The stabilizer starts to work at the beginning of the pan and then it gives out in sort of stepping actions. This can create a sort of jerking type of pan motion in the pictures.
Jerry G.
May 02, 2008 | Sony Handycam CCD-TRV318 Camcorder
Sony CCD-TRV318 Hi8 Handycam
My TRV 318 will not record video but will record sound.HELP
Jan 15, 2008 | Sony Handycam CCD-TRV318 Camcorder
Sony Handycam CCD-TRV318 Camcorder Logo
294 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
