It does unscrew from the shaft. The Torx screw holding it is hidden and doesn't come out of the housing once it is loosened. It is screwed into the end of the shaft. You will have to keep the engine from turning to loosen it. Pull spark plug out and move piston to bottom of stroke. Put some nice, soft, clean rope in the cylinder and let the piston compress it when you turn the Torx screw in the clutch rotor housing.
