Question about Acer Aspire 3680 Laptop
Thanks, but I have the background showing on the tv screen and that's it. I can't seen to get anything else would it have to do with NTSC or something I forgot to click on in the display screen.
    Genius:
  • 1,027 Answers
NTSC is the standard display for tv's in the US
this site
Posted on Apr 16, 2008
Audio is okay-blue screen will show on no input-audio can be heard but dark screen when any input has a signal. It is detected as 480 but no video,,,no raster on rf inputs Have electronics background can...
the problem is solved by expert electronic, because your tv have cpu program and need reconfiguration this program,
And other question is you check cable conexion
you check conexion
you check format/image programing (NTSC/PAL) if in the setup or menu have the best configuration, no all problem is the component electronic...
oh, you read manual step by step...
bye
Mar 07, 2010 | Mitsubishi WS-55807 TV
I just purchased a dvd player and it's showing vertical lines.
PLEASE CHECK PAL AND NTSC SELECTION....IF YOUR REGION IS PAL SELECT PAL IN DVD SETTINGS....OR IF YOUR REGION IS NTSC THAN SELECT NTSC IN DVD SETTINGS....ITS NOT A PROBLEM...JUST TRY TO SWITCH PAL AND NTSC IN YOUR DVD SETTINGS....U WILL DEFINATELY GET THE RESULT
Nov 08, 2009 | Televison & Video
Very faint vertical bar moving across plasma screen.
OK... Left to Right is weird. I'd say one of two things.
Refresh Rate might be to low or to high, but i doubt this to be the cause. I'll put my money on external interferences. Something like another PC screen? TV? anything magnetic and I've even in some cases noticed PC side panels too close to a screen can cause this.
Dec 29, 2008 | Computers & Internet
Lcd hdtv is hooked up to laptop but it is every 10 sec gos black
if theres nothing happening on ur pc like same as tv its probably the tv config ...
check tv setup
check tv screen saver..if it disabled it would explain why screen black...
could try checking power settings in pc(screensaver properties)
Dec 10, 2008 | HP Compaq Presario V6000T Notebook
Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Green Cloud show close to mid lower left center on most black screen
you will need the optical unit cleaned, if that does not resolve then the optic unit needs replacing
Jun 18, 2008 | Sony Grand WEGA KF50XBR800 50" Rear...
Compatibility problem
You will need a NTSC-PAL TV signal standards converter. You can often find these at tourist-y camera shows (look in the window for "PAL" and "NTSC") if you live in a metropolitan area.
Apr 04, 2008 | Sony PlayStation 2 (PS2) Console
Screen losing color.. turning black and white
Your TV goes black & white, because your Wii could be NTSC or PAL which. If your Wii is PAL and your TV is NTSC then the TV will show a blac and white color. Since NTSC is for North America and PAL for Asia
Jan 13, 2008 | Nintendo Wii Console
PAL, NTSC
Can you somehow press on "DEFAULT SETTINGS"? Do you have manual for your TV? Which model you have?
Sep 28, 2007 | Mintek DVA-8700 System
Acer Aspire 3680 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
