Question about SanDisk Sansa E280 MP3 Player
Corrupt files When I open my files in Music, playlist, pics etc. I am seeing a ton of files that appear to be corrupt. For example, when going into my playlist I see folders that are titled by letter only and when I am clicking to view the contents of the folder they appear to be empty. I have attempted to delete and some appear to allow me to delete and pop right back up. Others say that could not be delete and equipment seems to have disconnected which is not the case. When I attempte to reformat it says that it can not reformat at this time. Just curious if you have any idea of what I should attempt next.
  • woodsman5150 Apr 20, 2008
    exact same problems
  • tangou May 04, 2008
    Hi, can anyone help me with this pls. I have a sandisk e280, a week ago, my screen said "bad track" and would freeze so I'd have to let the batterie die. When I plug it in my pc and open the music folder, there was alot of folders that were named after 1 letter and could not be opened or deleted, it says the equipment as deconnected but thats not the case. randomly, my mp3 emptied on its own or something, it says 0 songs, but they were all in my music folder when i pluged it in. I tried updating the firmware from sandisk website, but all the weird folders are still there, I've tried adding 3 songs to try my mp3, they would transfer into my music folder, but only 1 appears in my mp3?????, I've tried putting all my library on my mp3 wich is 674 songs, again only 1 would appear on my mp3 after I unpluged it??? I go see in info and they tell me I have 4023 MB left of space, but I have no songs on it!!!!!, and I would like to format it but I dont know how, they don't give me the option to do so, in the settings on the mp3. pls help me, this is frustrating, and don't know what to do anymore pls e-mail me back at sporty_2811@hotmail.com thanks
  • 758 Answers
I feel that the problem you are having is because the firmware that is currently on the device is corrupted...i would recommend you to go to the sandisk websitecorrupt files - 1.gif to get the latest firmware upgrafe for your device..the link for the firmware upgrade is below..I hope that helps...if you have any more problems please contact me....
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
Please rate accordingly
Thank You
Computerrep
Posted on Apr 22, 2008
  • Jean Sintulaire Apr 29, 2008
    Go to the System folder and delete PP5000.DAT. This is the database. The player will then rebuild the database without the deleted files.
I am having problems sorting my music out on my ipod and syncing music from PC to ipod. I think there was a disc when I first brought ipod but have since moved, brought new pc and left disc back in other...
open up Itunes in the top left hand corner select file from the drop down list select library then you will have options toback up to disc organise library export library import playlist and export playlist
open Itunes in the top left hand corner select file from thdrop down list you will see Library click to open then you should see back up to disk then more options back up entire library to disk
also here are a couple of programs that might help
http://download.cnet.com/iPod-Folder/3000-18545_4-54014.html
  • Detects the iPod music structure
  • Calculate the iPod music file size
  • Counts folders and displays folder size
  • Copy all songs into a folder (on any volume)
What
Jun 06, 2011 | Computers & Internet
I have a slick 4gb mp418c-4. i have been trying to make use of the playlist files but can't seem to get it. how do i create playlists in my files?
How to make a Playlist --- Listen to the song you want to add to a Playlist. While the song is playing, press & HOLD the [MENU] button for a couple of seconds. Another screen will appear with the following options. 1. Music Playback -- Normal / Random 2. Select EQ 3. Lyric Display -- Enable / Off 4. Add to MyList 5. Delete the File Move to #4 and press the [SELECT] button. Playlists will appear. Choose which one you want to add songs to and press the [SELECT] button. A check-mark will appear, meaning song has been added to PlayList. Press [MENU] button to get out. To DELETE songs from PlayList --- Go to options list when you first enter Music file and scroll down to 'My Music List'. Press [SELECT] button, Highlight the PlayList you want to delete songs from and press [SELECT] button. Highlight the song you want to delete, press and HOLD the [MENU] button for the delete screen to appear. 2 options on that screen - OK & Cancel Hope this helps Andrew
Apr 29, 2011 | Audio Players & Recorders
Make a new playlist?
To create an M3U playlist On your PC, create a new empty .txt document using word pad, type nothing but save the file as a .txt. go in to my computer -->> explore and find the file and rename the .txt document so it has an m3u file extension (example: my_list.m3u). Open the m3u file with wordpad, notepad, or a text editor. In the first line at top of the page type #EXTM3U. After the first line, start listing your music files, copy and paste the song names , (with extension ie .mp3). One music file name each line. Exit the text editor and save the m3u file once you are finished. Drag and drop the M3U playlist to the player's MUSIC folder, your done.
Apr 09, 2010 | Apple iPod nano 3rd Generation
How do you set up a playlist and sucessfully transfer it to the sansa fuze
To create an M3U playlist On your PC, create a new empty .txt document using word pad, type nothing but save the file as a .txt. go in to my computer -->> explore and find the file and rename the .txt document so it has an m3u file extension (example: my_list.m3u). Open the m3u file with wordpad, notepad, or a text editor. In the first line at top of the page type #EXTM3U. After the first line, start listing your music files, copy and paste the song names , (with extension ie .mp3). One music file name each line. Exit the text editor and save the m3u file once you are finished. Drag and drop the M3U playlist to the Sansa player's MUSIC folder, your done if it works.
Apr 07, 2010 | SanDisk Sansa Fuze MP3 Player
I cannot figure out how to make playlists and store them on my Sony mp3 player. I have workout music and study music and I cannot figure out how to make them so I can listen to the playlists separately.
The easiest way (though tedious when you start) I found was to just sync all my music, etc. through Window Media Player, then open the Walkman in Windows Explorer. Open the music folder and create a file for the music you want on the playlist. Copy all the songs you want the select the songs in the file, right click and create a playlist. Double-click on the playlist and put them in the order you want them. Click OK. Whan you disconnect the walkman, your playlist will be there. This is the only way I have found to actually have my playlist show up in the Playlist feature on my Walkman in the order I want the songs.
Oct 10, 2009 | Sony Walkman Video NWZ-A815 Digital Media...
Files in Iriver H10 not appearing in music.
try this...
connect your h10 to the pc using the ums trick with the usb connection..
For 20 GB MTP Models
  • Make sure your H10 is turned off and disconnected from the computer.
  • Poke the "reset" button with a paperclip.
  • Turn on the hold switch (so that you don't accidentally turn the H10 on all the way).
  • Plug the H10 into your computer.
  • Turn on the H10 while holding the "O" button.
  • You will see the message "Emergency Connection" if you have done everything correctly. You can now let go of the "O" button.
download and run EASYh10 software (free playlist maker). It will scan the files in your music folder and build/save a playlist to your h10.
disconnect player and give it a try...
Mar 13, 2009 | iRiver H10 MP3 Player
I am trying to sync my player with windows media player so I can modify my playlists. Media player says my player is full, but is not recognizing any files located on the player.
My windows media player does the same thing, I just don't use it now
Go to "My Computer"
You should see your Coby device on there
Open it up, you will see the categories where your files are (like Music, Videos, etc..)
Now just simply click and drag ;)
PS: Same with playlists, create one and save it, then find the file and click and drag into playlist folder on Coby
Dec 25, 2008 | Coby MPC-848 MP3 Player
Phillips 4gb Go gear playlists
ok heres what ya do.
connect to laptop/computer.
go to "computer"
find the player -- open it
internal storage -- open it
playlists -- open it
right click any of the playlists and click properties.
click the references tab.
go back to the folder called music in the device.
click and drag the songs into the window called references.
when finished click ok.
should work!
Nov 30, 2008 | Philips GOGEAR SA6045 MP3 Player
Coby mp705-4g playlist help needed
Hello Simone, the interesting thing about the Coby MP705 is that the company decided not to reinvent the technology that already exist, but to use the Windows technology. The best way of creating a playlist is by first connecting your MP3 player to your computer. After the computer recognizes the mp3 player double click “my computer” after that double click on the icon that shows “Coby MP705” and if “internal storage” appears also double click that icon. You should now see a series of folders double click the music folder. All your music folders will now appear. Go on any music folder and right click it. You will see an option half way down that say “create playlist” by selecting this option you create that folder as a playlist. If you want to make a playlist with a compilation of assorted music you must first create a folder with all the music you would like in that playlist then follow the instructions on how to create a playlist hope this helps.
Sep 09, 2008 | Coby MP-C7085 MP3 Player
Problem playing the tracks in gallery !
Both of u , when u open tracks there a processing message will appear , then u will wait after that open tracks also check now tracks are going directly into web .
May 02, 2008 | Nokia N72 Cellular Phone
SanDisk Sansa E280 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
