Question about Palm LifeDrive Mobile Manager Handheld
Palm LifeDrive not charging
My LifeDrive was not keeping a charge and then not charging and I replaced the battery with a new one. Now, after the battery has been changed, it continues to not charge above 33% and it almost seems like the unit does not charge, even if the charging light is on, unless I "jiggle" it to get the lightning bolt to appear. This happens consistently even when I plug it in to 3 different charging units that I have (a Palm LifeDrive stand and two other portable plug-in cords).
Is this a battery problem or a problem with the physical place where the charging cord is to be plugged in? I do not get any error messages or other alerts.
Mark
  • draymac Aug 05, 2008
    I too have been having the same problem. It seems that the charging plug area on the lifedrive itself is not making good contact anymore with the charging cords. I have opened it up and all cords, connections look to be in place. HELP!
  • 1,606 Answers
I had the exact same annoying problem. Easy fix though. Get the palm universal cradle. The power connector is either worn or loose and making partial contact. So when you use the normal adapter there might be a position that works but generally it won't. When you use the cradle the weight of the LD presses the contacts more and it will behave.
I went through a couple of chargers before getting the cradle and fixing it once and for all.
Posted on Jul 15, 2009
I have a one lifedrive with two batteries and two harddrive but it still doesn't work Help Please
HI,
Normal 0 The best thing to do is to go to the free palm chat service they offer. I have used this and it worked good for me. Here is a link to the free chat service. Scroll to the bottom of the page and you will see a Palm Chat. From there click on the link that says Chat Now and follow the online prompts. Best wishes...I hope this will help you.
Now for the link....
Normal 0 http://kb.palm.com/wps/portal/kb/na/lifedrive/lifedrive/unlocked/supportservices/page_en.html
Nov 25, 2009 | Palm LifeDrive Mobile Manager Handheld
My palm doesn't seem to be charging at all. The
The clicking noise usually indicates a hard drive problem. There are replacements available. You can get a replacement hard drive or a flash card drive. Of the two the flash drive is by far the better choice.
Nov 06, 2009 | Palm LifeDrive Mobile Manager Handheld
It wont power on how do i get the palmone lifedrive to come on it dont even come on even when begin charged
Usually those symptoms mean a motherboard problem or a battery problem. Both are replaceable and worth doing if you use your LD.
You can try a power reset. Plug the LD in and hold the 5 way button down then reset the Ld using the reset button. You may need 3 hands to do this. Sometimes this will reset the power section and get you running.
Jul 17, 2009 | Palm LifeDrive Handheld
Is palm lifedrive compatible with vista
Yes, you can use it but DO NOT INSTALL "Documents to go". The version of this software is not compatible with Vista and Sync will hang at it.
If you have already installed it, just -> remove programs -> uninstall "Documents to go"
or:
Disable (do nothing option) sync of "Documents to go" using the application, not from HotSync Manager.
Jan 20, 2008 | Palm LifeDrive Handheld
Lifedrive won't power on
When you plug the unit into the wall to charge, poke the reset hole in the back of it at the same time. This should reset the internal recharging mechanism in the Palm. Let it sit for a couple of hours and then see if it will come on.
Jan 03, 2008 | Palm LifeDrive Handheld
Palm Lifedrive failure
I found this on the Palm website about the frozen Palm Logo screen
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=97,E=0000000000825271086,K=7324,Sxi=2,Case=Obj(26419)
Dec 03, 2007 | Palm LifeDrive Handheld
Battery not holding a charge, maybe...
The only thing close that I can recommend is doing an in cradle reset. Palms site says it only works on certain models, but hey it's worth a shot.
Nov 26, 2007 | Palm LifeDrive Handheld
Palm LifeDrive dead
You may be stuck in a loop-
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=2,E=0000000000825355002,K=8658,Sxi=6,Case=Obj(26419)
After you do a hard reset, try naming the palm something other than what the name was before hand and see if that profile works.
Oct 24, 2007 | Palm LifeDrive Handheld
My Lifedrive wont turn on...
get a new charger..or return it..hopfully you got extended warranty. mine did the same and it took like 20 minutes just to have enough energy to restart.
Oct 21, 2007 | Palm LifeDrive Mobile Manager Handheld
Dead LifeDrive
I would guess you bought a dud micro drive or its been cleaned off. You could try a hard reset and see if it fixes itself. Perhaps the fellow cleaned off his information but hopefully he left the restore partition alone. You can rebuild that if you extract the files from the 2.0 upgrade and so on. There are a few tutorials on how and what to do on some of the hardcore LD sites.
Hopefully you didn't harm the board itself with a static discharge. I've seen a few guys do the swap and end up with a dead LD but usually they don't see anything at all.
May 22, 2007 | Palm LifeDrive Mobile Manager Handheld
Palm LifeDrive Mobile Manager Handheld Logo
289 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
