Question about Canon PIXMA MP780 All-In-One InkJet Printer
Paper Jam I have a jam message. Paper went in (4x6), didn't come out. Can't see it. How do I open to clear it?
  • Anonymous Apr 17, 2008
    The printer swallowed a pile of paper
  • 202 Answers
Hello vidalia
(01) You can find support and downloads for your Canon Pixma MP780 AIO (all-in-one) HERE.
(02) You can find Canon's support and services for this device HERE.
(03) You can find drivers and manuals for it HERE.
(Select your computer's operating system under Drivers/Software selection and the appropriate downloads will appear)
(04) For instructions on clearing a paper jam, download the USER'S GUIDE (it might take a little bit. It's pretty extensive).
(05) Then double-click on the file name: (depending upon the operating system you selected, it will be something like: PIXMA_MP780_750_UG_WIN_EN.EXE)
The file will extract to a folder (in the same location w/ the same name as the file)
(06) Double-click on the folder.
(07) Double click on the file named "TOP" or "TOP.htm"
This will open the USER'S GUIDE for you.
(08) Now, in the left column, click on TROUBLESHOOTING
(09) Then click on the link immediately below TROUBLESHOOTING called "Paper is Jammed"
(10) Follow the instructions provided for clearing a paper jam.
Please, let us know if you have any questions at all, etc. We'll continue to work w/ you on this problem until it is resolved.
Thank you
BJ @:)
If the information I provided enabled you to resolve your problem, kindly take a moment to rate my solution w/ a "FixYa" :)
Posted on Apr 16, 2008
  • B Joan Rapier
    B Joan Rapier Apr 17, 2008
    Hello vidalia,
    Since you assigned a rating and closed the problem, I'm assuming that you've been able to clear your paper jam message and get your printer behaving nicely again.
    That's terrific! I'm really happy you were able to find the support you needed here on
    and resolve your problem.
    Please, come back anytime you need help or have questions. We're here to help.
    Thank you v-e-r-y much for the FIXYA rating, too! :)
    Have a beautiful day
    BJ @:)
Printer jam
If your paper is jammed inside, open the printer and gently pull the paper back out to fix the problem.
May 23, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Paper jams at toner cartridge, printer service maintenance kit installed
Paper Jam clearing: copy and paste the link in your web browser...I used to work with these printer's..when they work great, when they don't, not so great..
Clearing Paper Jams If the printer's control panel displays a paper jam message, look for paper in the locations indicated in Figure 22, then see the procedure for clearing the paper jam. You might need to look for paper in other locations than indicated in the paper jam message. If the location of the paper jam is not obvious, look first in the top cover area.When clearing paper jams, be very careful not to tear the paper. If a small piece of paper is left in the printer, it could cause additional jams. If paper jams are a recurring problem, see page 78.(A paper jam message might also display if the rear door is open.)
The top cover of the printer must be opened and then closed to clear a paper jam message.Paper jams can occur at the following locations:Output areas(top and rear)Go to page 75.
Loose toner might remain in the printer after a paper jam, but thetoner should clear after a few sheets are printed.
Jan 31, 2018 | HP LaserJet 5000n Printer
Repeat paper jam
there likely a jam in there your not seeing or feeling
Jan 26, 2013 | HiTi P510L Digital Photo Printer w/Breeze...
MP 640 paper jam message that wont clear
door. 3 Push down on the green lever. 24x Paper Jam, Check Tray 1 Gently open the ... Jam, Check MP Feeder Gently pull the jam straight out of the multipurpose feeder. 202 Paper Jam, Open Rear Door 1 Open the ... side to locate a green lever. Note: To clear the Paper Jam error message, you must remove ... above Tray 1 when the duplex function is in use. To clear this type of jam, follow the instructions under the appropriate paper jam message. Lever 4 Gently pull the jam toward you. 5 Insert the tray. Note: Make sure... under the print media is locked down. 23x Paper Jam, Remove Tray1, Pull Down ...
Jul 29, 2012 | Canon MP640 All-In-One InkJet Printer
I have a paper jam and need to open the back door of an HP 6200 Printer. Do I need a screw driver?
Hello and Welcome to FixYa!
No, you didn't need any screw driver for clearing a paper jam. But yes, if it is more mess than just a simple paper jam, then it depends.
For Paper Jam issues, kindly go through this document.
Concerned, Nooh.
Aug 04, 2011 | Office Equipment & Supplies
Network Printer 12 paper jam
In order for a jam message to reset to READY, the printer logic is looking for an "06 COVER OPEN" message. The top cover of the machine must be opened to clear the jam message. If the top cover interlock switch is stuck closed, the printer logic never clears the jam message, even after all the paper has been removed. The printer appears hung with the paper jam message and can only be made READY by powering the printer Off and back On.
Jun 16, 2009 | IBM Network Printer 12 Laser
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
228 people viewed this question
old marine
old marine
