Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
F02 code on duet/ht washer
By bigred92766 on Apr 16, 2008
f02 code on duet/ht washer
Same Problem
Apr 26, 2009
-   Fridgedaire front load Galler Series washer hs F 03 error message.
What does that mean? -   Stan1951
Mar 20, 2009
-   Thank goodness for the internet. same problem here, but with the kenmore front load equivalents. took me all but 10 minutes to remove 3 torq screws then unscrew the pump filter.
note: it's going to be NASTY smelling. have towels and lysol ready!
-   toere player
Nov 03, 2008
-   I have a Whirlpool Duet Model GHW9100LW1. It is giving me an F 02 code at the beginning of the rinse cycle. The clothes in it have not rinsed and when I press CANCEL it tries in vain to drain the water in the washer and it makes an unusual grinding sound when doing so. The hose is not clogged or kinked. Tried unplugging unit and replugging it into outlet but no success--same code.
Please help. Service call alone is $75 just to walk in the door and give an estimate.
-   kel_mar10
May 08, 2008
-   hi .. i am getting the same code f02, and when it is getting ready to rinse, the water continues loading water and the water wont stop, and the machine will not start. plz help. thankx-   chrisknrick
Apr 29, 2008
-   f02 and f03 error codes
-   Guest
Best Solution
posted on Apr 16, 2008
Very Helpful)
dutchman05
Rank: Guru
Rating: 88%, 341 votes
please give me machine number
Was this helpful?
Yes
No
Solution #2
posted on Nov 13, 2008
Somewhat Helpful)
stopgo
Rank: Apprentice
Rating: 92%, 43 votes
We had this problem after our baby's socks started going missing in the wash cycle. We found them in two places: 1. Underneath the rubber gasket of the front-loading drum, and, 2. In the drain line, but not in the hose that comes out of the back of the machine. The manual and website make no mention of the three torx screws on the front, lower panel that can be removed, exposing a drain that can then be unscrewed (be prepared for A LOT of water to come out of here if you haven't been able to get it to drain). Inside here we found the culprit baby socks, removed them, ran a fan on the exposed electronics over night to dry them out, and put it back together. Problem solved. It's unbelievable that this information is not in the manual but had to be googled from sites like this. Hope this helps someone else and prevents an expensive service call. Maytag, you s u c k!
Was this helpful?
Yes
No
11 people thought this was helpful
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
Whirlpool Cabrio WTW6300 worth the $$?
Answer
elite oasis is that a quaitly machine
Answer
washing machine fills up but will not turn to rinse
Answer
Code E20 comes up at final rinse stage and will not continue, water does not drain.
Answer
my washer does not want to spin out...it will wash but when i get to spin it stops...it also has a... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Washing Machines:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14889
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
