Question about iiyama Pro Lite 38a Monitor
Iiyama Pro Lite E485S
I am unable to reset the factory settings or find a way of selecting English on the monitor. Each time I log on the screen is dull, then when the auto callibrage is on it is nice and bright, but when the callibrage window disappears the screen goes dull again.
  • 2 more comments
  • argyllbill Apr 17, 2008
    Sorry Mangate, being a Silver-Surfer it takes longer for technical jargon to penetrate. What is a EPRom Problem and how does one exchange or re-program it. Your assistance is appreciated. Thank you
    Mangate, I ment to mention that my problem relates to a iiyama ProLite E485E 19" Monitor and not the 38A mentioned above. For some reason FixYa doesn't recognise mine as a valid product.
    Bill.
  • horrah Nov 24, 2008
    Seen your answere but just dont understand this. can you id it a bit more in detail.
    I have the Iiyama Prolite E485s and it has gone green and light in the screen and dropped to chineese in the languaga and i can change any of this. What do i do ??
  • junkmailwill May 25, 2009
    Managed to get it into english but the screen is rotating between all colours and the menu will not stay on screen more than 1 second
  • 3 Answers
Do exactly this:
- power off monitor with the POWER button!
- unplug power cord
- hold -/+ and keep holding them when briefly pressing POWER to get the monitor back on
- press menu
You are now in the service menu. Adjust the settings as you like.
- press EXIT
- power off monitor with button
- power on monitor with button
- AUTO SETUP... will be performed
- re-adjust brightness/contrast
Done!
edwin (rdam nl)
Posted on Dec 02, 2008
  • edw1983 Dec 02, 2008
    do exactly this:
    - unplug power cord
    - wait a few seconds
    - connect monitor to mains again
    - press menu
    - press EXIT
    Done!
    edwin (rdam nl)
    BTW: EEPROM exchange was not necessary in the cases I saw...
  • edw1983 Oct 18, 2015
    You can also remove the EEPROM entirely if you are using DVI input. In that case you don't need to make any settings anyway.
Edw1983
Thank you
Posted on Dec 03, 2008
  • 88 Answers
It is The EPRom Problem Exchange it or re programm it will Solve your problem
Thank you
Take Care
Posted on Apr 17, 2008
    You can also remove (desolder) the EEPROM chip entirely if you are using DVI input only.
    Because in that case you don't need to make/save any settings anyway.
Is liyama pro-lite H380 is touch screen or not
it would say, and also does it have a usb connection? If it doesn't and it is just using vga then no
Mar 09, 2011 | iiyama ProLite H380-B 15 inch LCD Monitor...
Windows 7 doesn't recognize my iiyama Vision Master Pro 450 Monitor, what to do?
My Iiyama Vision Master Pro 450 works with Windows 7 when connected with a VGA video cable that has 5 BNC RGB connectors that attach to the back of the Iiyama monitor. No driver install was needed; Windows 7 shows my Iiyama monitor as a "Generic Non-PnP Monitor" with 1024x768 resolution.
Jan 13, 2011 | iiyama Vision Master Pro 450 Monitor
Iiyama prolite e1902wsv white screen , no picture
From time to time, I've the same white screen problem with my IIYAMA E1902WSV.
I can resolve that issue with a reset to factory settings.
1- Turn ON power (blue led)
2- Push on the MENU button and keep the button pushed while
pulling out the power cord.
3- Plug the power cord back while keeping the MENU button
pushed.
You should see the picture again.
Oct 18, 2010 | iiyama ProLite E481S-B 19" LCD Monitor
Screen fade to black after several minutes, problem has been getting worse
move the mouse u will get everything back plus right click on ur desktop go to properties and go to screen saver and change the mins so it don't switch after a couple of mins
Nov 03, 2009 | iiyama Pro Lite AS4636D (Black) 18.1 in....
DEAD IIYAMA AS4636D
Hi Sammy7!!
I have such iiyama AS4636D monitor. In this day purchase.
I have such problem with you.
My solution:
Desktop pc and lcd power off (230VAC or 110VAC)
Power on lcd, after early desktop pc.
This moment, when running the pc booting, press and hold you the " + " button.
In this moment come in one blue screen. May be running on the sreen short message: check or select input mode: VGA DVI 1 2 . Select your correct cable connection type.
Have a nice day! and happy new year!
Lajos from Hungary
Dec 13, 2008 | iiyama Pro Lite AS4636D (Black) 18.1 in....
PC monitor wont come on.
Check that the power cord is fully plugged in first.
It is probably the inverter board inside the monitor.
(if the screen does properly display ever then it is not the screen)
It CAN be fixed but I do not suggest anyone open up a monitor (LCD or CRT) who is not "technically inclined."
If you really want to fix this particular one then take it to a local tech and get an estimate first. If it's almost as much as a new monitor then buy a new one.
Mar 14, 2008 | iiyama ProLite E434S 17" LCD Monitor
Screen settings wont save
To solve the problem of left-alignment, try setting the output of your computer to 75Hz. See http://support.microsoft.com/kb/311403 for how to do this.
Nov 14, 2007 | iiyama Pro Lite 38a Monitor
iiyama Pro Lite 38a Monitor Logo
3,308 people viewed this question
Top iiyama Computers & Internet Experts
William Miller
William Miller
James
Are you an iiyama Computer and Internet Expert? Answer questions, earn points and help others
