Question about Cuisinart DLC-2011 PowerPrep Plus Food Processor
Appears to be locked but won't turn on - Cuisinart DLC-2011 PowerPrep Plus Food Processor
Perfect.....we had the handle facing backwards. Duh!
Posted on May 06, 2009
  • 8,596 Answers
Instructions only apply to Cuisinart DLC-2011 series:
Remove the work bowl and all other parts completely from base.
Plug the base in, and turn it on.
Use a pen to press in the dark grey or black button on top of the base.
If you hear a spinning or other noise, the motor is still good.
Now that you have verified that the motor is good:
Put each work bowl piece on one at a time - if you don't out it on one at a time, it will not lock in properly.
Put work bowl on with work bowl handle facing front, make sure bowl locks.
Put lid on with lid lined up with work bowl handle.
Put pusher sleeve into lid's feed tube, with metal element facing the front of the food processor.
You should now be good to go.
-Tha Mp3 Doctor
Posted on Apr 08, 2009
Black and decker fp2500 appears to be locked and
take it back to the store you bought it and they will give a new one and your money back
Aug 29, 2013 | Cuisinart DLC-10S Pro Classic Food...
Tip
The cusinart pro classic food processor is not working ?
Try this procedure:-- It usually goes something like this, with minor variations depending on model number:1.Remove the work bowl completely from the base
2.Plug the food processor in and turn it on
3.Use a pen to depress the dark grey/black button on the base – if it spins, proceed
4.Put the work bowl on the base with the handle facing the front of the food processor – slide the work bowl until it locks - the white tabs show in the openings on the bottom of either side of the work bowl
5.Place the lid on the work bowl with the tab slightly left of the center of the work bowl handle – slide the lid counterclockwise until it won’t slide any more
6.Place the pusher sleeve in the feeder tube of the lid with the lock facing the front of the food processor (may vary depending on model)
7.Slide the lock to the right into the locked position
The food processor should now work.
This will help.Good luck.
on Mar 08, 2010 | Food Processors
New magimix won't start
It is most likely the way the bowl and lid are set.
Facing the machine:
the bowl locks in, with the handle to your right directly above the switches. The lid has a double tab...see underside of the top of the lid. Place the lid on tightly with both tabs locked into bowls handle. It really clicks in.
Feb 01, 2013 | Magimix 4100 Cuisine Systeme 1268 Cups...
My brand new Cuisinart 14 cup food processor won't turn on. All the components are locked in place and it's plugged in. Help
First, do a motor test by removing the work bowl completely and using a pen to press in the grey button on top of the base (with the food processor turned on of course), toward the back. If the processor spins, the motor is still good. At that point, I would inspect the work bowl pieces, lid, pusher assembly, etc for cracks/damage. If all appears well, insert ALL the pieces back into place and try again. If even one piece is out of place, the processor will not spin.
If it no longer spins, the motor has a problem.
-Tha Mp3 Doctor
Nov 23, 2008 | Cuisinart DLC-5 Food Processor
Bowl handle doesn't make connection
I had this problem, I finally stuffed a tiny piece of tin foil into the hole the spring is supposed to go into to activate the machine. It works, but it is always on, even if the bowl is not locked into place so I have to be careful. I just store it unplugged.
Nov 16, 2008 | KitchenAid KFP750 Food Processor
I have a cusinart pro classic, went to use it yesterday, filled it and turned in on, got nothing. i tried a different plug and still nothing. it is not even making a sound.
1. Remove the work bowl completely from the base
2. Plug the food processor in and turn it on
3. Use a pen to depress the dark grey/black button on the base – if it spins, proceed
4. Put the work bowl on the base with the handle facing the front of the food processor – slide the work bowl until it locks - the white tabs show in the openings on the bottom of either side of the workbowl
5. Place the lid on the workbowl with the tab slightly left of the center of the workbowl handle – slide the lid counterclockwise until it won’t slide any more
6. Place the pusher sleeve in the feeder tube of the lid with the lock facing the front of the food processor (may vary depending on model)
7. Slide the lock to the right into the locked position
-Tha Mp3 Doctor
Oct 19, 2008 | Cuisinart DLC-10S Pro Classic Food...
Food processor
-Tha Mp3 Doctor
Apr 20, 2008 | Cuisinart DLC-10S Pro Classic Food...
ah! well my mother just tried using her DLC-10S 7 cup food processor and she also encountered the same problem. It worked perfectly fine when she first used it around Christmas time but not anymore.
After almost smacking the hell out of it we discovered that there is a plastic tab on the lid towards the handle side. This plastic tab actually pushes a lever through the cup and into the base of the food processor.
New Bee actually mentions this above. The problem is that the flimsy plastic tab in the handle isn't stiff enough to push the lever down anymore. I'm amazed it worked the first time.
This is very much a design flaw by Cuisinart as there's no way this plastic tab would ever last.
Now there is a small opening in the case right above the plastic tab. To get our food processor going we just pushed a chopstick down on the tab and held it in place while the food processor runs.
This is very much a temporary solution until we get a new food processor, obviously a different model.
Nov 22, 2007 | Cuisinart DLC-10S Pro Classic Food...
Product won't turn on - safety feature appears broken
I went through the same thing...as it turns out, everything was locked into place but I had the handle in the back rather than the front where the sensor is. Good luck. I hope that helps you.
Dec 17, 2006 | Cuisinart DLC-2011 PowerPrep Plus Food...
Cuisinart DLC-2011 PowerPrep Plus Food Processor Logo
1,000 people viewed this question
Top Cuisinart Food Processors Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Donni Steen
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
