Question about Jensen's VM9312 Car DVD Player
Jensen VM9312 Bypass Code
I have been trying the 543210 steps It does not work for me, I dont get a new menu, could you tell me whether I need to have the pink wire grounded or connected to the brake and if there is something I am not doing correctly?
  • kcrumpler Aug 27, 2008
    every time i start my truck the radio turns wide open on my 9312. And i was bypassed but the security has come back. no more camera on aux 1 to watch boat while in tow.
Trust me that works i just installed this deck in my truck today. And no you dont have to do anything with the ebrake wire at all just cut it off. Make sure you hear the beep sound when you hit 543210 you should hear it each time.
Posted on May 31, 2008
  • Steven Negron Feb 13, 2011
    I have the same problem Jbuendia has. I tried the code several times. I hear the beeps and nothing. I am not the original owner of the vehicle or radio. Could the original owner have changed the security code? It only has space for 4 numbers. Any help would be AWESOME.
    Thanks
How do i by pass parking brake wire for indash dvd jensen vm9312 i'm puting it in old car no p.b.
Hi jason
To answer your question;
You do not need to connect that wire but you need to bypass the parking brake function in the menu.
Here`s the parking brake bypass procedure:
1: Go into AM/FM mode
2: Hit "setup" on the remote control
3: Enter 543210 on the remote, listening for the beep for each number
entered
4: A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen.
5: Select Brake bypass to "ON" and hit the "X" near the bottom of the screen.
6: Use the unit wisely and above all safely. A ticket is one thing, causing a fatal accident due to negligence is another.
Hope this help Cheers
Apr 20, 2010 | Jensen's VM9312 Car DVD Player
Have a jensen linear phase car receiver , there is a light pink wire coming out of it what is it for ?
The pink wire is the safety wire so that you can not watch the screen (during a video) unless your car is in park. You can either connect it to a ground or completely bypass it by typing the code 543210 in the menu screen and turning the safety feature off.
Dec 12, 2009 | Jensen's VM9312 Car DVD Player
How do i get my dvd to play while i drive on a jensen vm9213
Go to the menu screen and use the code 543210 to turn the safety feature off.
Oct 25, 2009 | Jensen's VM9312 Car DVD Player
When I try to play a movie, I only see the warning sign on the screen. I can hear the movie playing, but the warning will not go away. This is even when the vehicle is in park. Any ideas what may be wrong?
Bypass Code
1. Go into Am/Fm mode
2. Hit "setup" on the remote control
3. Enter 543210 on the remote, listening for the beep for each number entered
4. A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen
5. Select Brake bypass to "ON" and hit the "X" near the bottom of the screen
Aug 18, 2009 | Jensen's VM9312 Car DVD Player
Emergency brake wire connection
Here's a Bypass to solve that. Turn your 9312 on and set to radio then Using your remote enter 543210 and make sure you hear a beep each time, a new menu screen will pop up, click the hammer and screwdriver on the upper left side,Next press the menu line for brake override, a sub menu will appear, select ON,Press the X at the lower left of the screen and you're done enjoy and be safe.
Apr 12, 2009 | Jensen's VM9312 Car DVD Player
Jensen vm 9312 region code
You can get into the master system by using your remote. 1.Make sure your Jenser VM9312 is on, and select AM/FM as your source. 2.On your remote, press the Setup button, located on the lower right of the remote, you should hear a beep from your VM9312 when you press the button. 3.Now, making sure you hear a beep after every key press, press, 543210. NB:If you did this correctly, a new menu screen will pop up. 4.On the display, press the hammer and screwdriver icon, located on the left hand side of the screen.
NB: Here you can bypass the break and regions etc. When done Press the X at the lower left of the screen and enjoy.
Feb 01, 2009 | Jensen's VM9312 Car DVD Player
JENSEN VM9312 CAR DVD PLAYER HOW
go to am/fm
then open the settings screen
next on your remote type 5,4,3,2,1,0 listening for each beep
a new screen should come up
after that look for brake override
Mar 19, 2008 | Jensen's VM9312 Car DVD Player
Jensen VM9412 Auti-theft lock password lost NEED HELP
Try entering the default Jensen passcode "012345". It may sound silly, but it'll work if the owner hasn't changed the password to their own personal code.
Jan 05, 2008 | Car Audio & Video
How do i do to bypass my jensen vm9312
go to www.ecoustics.com then click on forum at top click car audio then multimidea. and read Teir are bypass codes for several models here.just have to look for them.
Dec 18, 2007 | Jensen VM9510 Car DVD Player
Vm9312
That is the code for the older jensen's The parking brake bypass procedure is as follows: 1: Go into AM/FM mode 2: Hit "setup" on the remote control 3: Enter 543210 on the remote, listening for the beep for each number entered 4: A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen. 5: Select Brake bypass to "ON" and hit the "X" near the bottom of the screen.
May 25, 2007 | Jensen VM9510 Car DVD Player
Jensen's VM9312 Car DVD Player Logo
1,082 people viewed this question
Top Jensen's Car Audio & Video Experts
Richard Foster
Richard Foster
afairman1927
Are you a Jensen's Car Audio and Video Expert? Answer questions, earn points and help others
