Question about Video Cameras
Gone into safe mode cant change mode?
MODEL IS JVC GR-DVL-160EK it has gone into safe mode cant get it to change lost manaul derek
  • duffydog10 Apr 13, 2009
    Camcorder has gone into safe mode and i cannot get it from this mode
    Genius:
  • 1,142 Answers
1. Click Start, point to Find, and then click Files or Folders. 2. In the Named box, type msdos.sys. 3. In the Look In box, click the drive on which Windows is installed (usually drive C), and then click Find Now. 4. Right-click the Msdos.sys file, and then click Properties. 5. Click to clear the Read-Only and Hidden check boxes to remove these attributes from the Msdos.sys file, and then click OK. 6. Right-click the Msdos.sys file, and then click Open With. 7. In the Choose the program you want to use box, click WordPad, and then click OK. 8. Do one of the following: • Delete the BootSafe=1 line.
-or- • Change the value in the BootSafe=1 line to BootSafe=0. 9. On the File menu, click Save. 10. Right-click the Msdos.sys file, and then click Properties. 11. Click to select the Read-Only and Hidden check boxes to set the attributes for the file, and then click OK. 12. Restart your computer.
Posted on Apr 19, 2008
2 Suggested Answers
Maanita
  • 1142 Answers
SOURCE: my jvc GR-DVL-160EK HAS GONE INTO SAFE MODE I CANT CHANGE BACK TO NORMAL MODE
May i know the model/make and part # of the product
Posted on Apr 16, 2008
Jvc gr-dvl-305 eo4 error
Common problem and one that requires Professional service. There is cold solder on the cylinder drive PCB that needs to be re-flowed with solder. We can help:
Contact Us at AVRepair com
Jul 12, 2014 | Video Cameras
When I connect my JVC DVL 520 to the computer, my computer does not recognise it??
Hi
It will not detect the camera because you have not set the camera to Play mode or interface mode. Hence change the settings to play mode or USB mode and then try it will sure detect the camera.
Jul 17, 2011 | JVC Cybercam GR-DVL520 Mini DV Digital...
JVC gr dvl 500U E04...safe gaurd mode/ remove and
Poor contact of drum motor connection(flexi found at the upper part of the drum assy). Solution, disconnect this wire from the connector and cut 1mm from the end so that it will make a new contact. WIre will be shortened a little bit but it still can work this way since this flexi can not be ordered alone, it comes complete with the whole drum assy. Good Luck
Mar 14, 2010 | Video Cameras
Gr-dvl-520u trying to record or playback tape it goes into safeguard mode within 5 seconds. alternatly pressing play and still every 3 seconds advanced the playback without it going into safeguard mod
According to http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/,
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
If you are getting E03 or E04 errors on every tape you try, it sounds like a servicing is required.
Apr 17, 2009 | JVC Cybercam GR-DV500US Mini DV Digital...
Dont know how to take it off safe mode
Go Here download manual.
http://books.jvcservice.com/booklist.asp?Model=GR-D250
Not enough info to find complete solution for you hope this helps. Please rate.
Mar 12, 2009 | JVC GR-D250 Mini DV Digital Camcorder
I have a JVC mini dv camera model # GR-DVL 725U trying to find out how I transfer video to my PC any ideas?
Plug in yourcord to a usb port. go to my computer and select the drive that the camera is pluged into. Then highlight the picture files and right click. a pull dow will show you rhe other drives, select C drive and poof they are gone to c drive. If it asks you where on c drive select my pictures
Nov 29, 2008 | JVC Cybercam GR-DVL820 Mini DV Digital...
Cant get sound
With the s.video lead and another lead from the earphone socket to my sound card did the trick
Nov 17, 2008 | JVC GR-DVL9000 DV Digital Camcorder
JVC Camcorder Model # GR-D270U
I think youre talking about safeguard mode.
Here is the manual if you don't have one:
http://resources.jvc.com/Resources/00/00/94/LYT1354-001A.pdf
See page 51. There should be an error indication number as well.
Jun 19, 2008 | JVC GR-D290 Mini DV Digital Camcorder
JVC GR DVL-9800 Didital video camera
Go to
http://www.devicemanuals.com/
Enter JVC GR-DVL9800 in the top right search box, click on "device manuals search" and you'll get a list of user manuals JVC GR-DVL9800 manuals to choose from. Just download the manual that matches your JVC model number.
Dec 30, 2007 | Video Cameras
Video Cameras Logo
232 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
