Question about Sunbeam 5833 ExpressBake Bread Maker
My breadmaker is not turning properly.
When I place my breadmaker in, it doesn't seem to make good contact to the turnstile underneath. It makes a horrible racket as it sound likes the turning mechanicism is scrapping against the metal. I can't get it to go down and snap in place. Any advice?
Try either turning the paddle slightly until it aligns with the "gear" under the bottom of the pan.
I've also pressed the start button, and when the mixing process began, managed to push the pan down until it's engaged properly.
Posted on Jul 15, 2008
Need connect turnstile Perey to system Win7
Contact them:
308 Bishop Ave.
Bridgeport, CT06610
Toll Free 877-TURNSTILE
Tel. 203-333-9400
Fax 203-333-9410
May 05, 2014 | Office Equipment & Supplies
When I go to make the settings - as per manual it comes up P1 3:20, but when I press the 'menu' button nothing seems to happen. I expected to see P2, P3 etc so my white bread (P1) is terrific
Sometimes the little buttons underneath are not centered properly. Try pushing around the edges of the "menu" selector button your machine makes a "beep" sound" If you never feel the button move under your finger followed by the "beep" sound then your selector menu button may be broken.
Apr 16, 2013 | Russell Hobbs 18036 Breadmaker Fresh Bread...
Blade rotation
The loud noise you hear is the belt in the bottom of your machine slipping. You may need to replace the belt. If you are making 2 pound loaves you might want to try making the smaller loaves such as 1.5 or 1.0 pounds. What make and model number is your machine?
Dec 31, 2012 | Kitchen Appliances - Others
Pan will not click into place
Bread pan removal:
I am assuming you have the type of bread machine that has the little metal spring clips inside the oven compartment. Before inserting the pan always check on the bottom of the pan (underneath) to see how the impeller "T" is aligned and turn it with your fingers or turne the paddle with your fingers so the "T" will fit into the gaps of the impeller in the bottom of the oven. Once you have aligned them then place the pan in the oven and "pop" push the pan in place so the spring clips grab the matching clips on the sides of the pan. Also look to see if your pan has the word "front" stenciled in the lip edge of the pan. If so, be sure that edge is towards the front of the machine. If your pan still won't pop into place when you push down your spring clips may need to be gently pulled out because they can become "slack" over time. Take the pan out and reach in and pull each spring clip up until you start to feel it bend a little and bend them out. Pop your pan into place and if the clips don's start to grab your pan repeat the process of bending the clips out and repeat that until they do. Summary:
1) make sure if your pan is marked "front" that it is aligned properly
2) make sure the paddle and the T underneath the pan aren't in conflict with the matching drive impeller in the bottom of the oven. Just turn the paddle so they are opposite of each other and can engage
3) Restore the "springiness" to your clips by bending them out with your fingers. Be careful though because the spring edges are fine edges so get underneath them when you pull up
For bread machine parts, good used bread machines etc. visit breadmachineshelp.com
Dec 07, 2012 | West Bend Kitchen Appliances - Others
Needle holder cannot be turn to the highest point
it's possible that when the needles were broken that the overlocker
either jumped time or damaged a part.
it would be a good idea to have the machine checked.
Nov 09, 2012 | Sewing Machines
The Breadmaker is not working properly
If the finish is worn and damaged and rust is impeding turning of the spindle you may wish to consider replacing your breadpan.
try contacting the Toastmaster parts supplier to see if they have a breadpan for your model. You can make a web inquiry here:
http://www.partsourceplus.com/contact_us.php
The comnpany does have parts for many other models so there is some chance they may be able to provide a compatible breadpan. For reference:
http://www.partsourceplus.com/toastmaster-parts-accessories-bread-makers-c-51_1268_1277.html
Oct 23, 2011 | Toastmaster Breadmaker's Hearth 1193 Bread...
My bread pan doesn't sit correctly so the paddle doesn't move around well, especially when it kneads faster
First pull the springy steel clips out so they bend some and stick out a little further this will hold your pan in better. Before putting your pan in make sure the little ears on the underneath side of the pan are lined of roughly opposite of the pan ears in the bottom of the oven that push the paddle around. If that doesn't make sense contact me.
Oct 01, 2011 | Cuisinart CBK-200 Bread Maker
My breadmaker have two paddles,one seem like it doesnt have the power to turn porbable.what is wrong,i want to fit it myself.
Hi, This could be caused by 3 reasons. 1) The bearing on the paddle shaft is ready to fail and the paddle is sticking. Take the pan out of the machine and see if you can turn the paddle freely by hand. 2) The belt is slipping. Tighten up the belt in the machine. Belts and pulleys are in the base of the machine. Remember to unplug machine when you work on it. 3) Make sure the pan is seated properly in the machine. Good luck Hank
May 12, 2010 | Kitchen Appliances - Others
HP Compaq nc6220 shuts off
It sounds like something is dislodged or loose. When turned off, take a look at it and make sure that all screws are in properly and that all doors are closed properly. After the checkup, place your hands onto it to feel if anything is still loose. It might be best to look inside it but don't touch the insides if it's under warranty. If you have warranty, call Compaq for instructions. If not - and you can see something obvious that can be placed back, then do so. If it looks okay and seemingly there is no reason for the shut downs, then contact Compaq to see if there can be any possibility for replacement parts or further instructions. If this helps you, please do rate me. Thanks. Good luck.
Feb 13, 2010 | HP Compaq nc6220 Notebook
I have a panasonic breadmaker SD 207 and Icannot
I think the best place to try is Ebay.UK I found this one there...maybe it will fit. Seems they all look alike. Good Luck, Hank
http://cgi.ebay.com/PANASONIC-BREAD-MAKER-PAN-KNEADING-BLADE-SD206-SD200_W0QQitemZ310127333030QQcmdZViewItemQQptZUK_HGKitchen_SmallApp_RL?hash=item4835078ea6
Jan 28, 2010 | Panasonic Kitchen Appliances - Others
Sunbeam 5833 ExpressBake Bread Maker Logo
297 people viewed this question
Top Sunbeam Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
