Word 2007 keeps shutting down for no apparent reason and sometimes I can't even open or edit a file
  • Stefan Groevens May 11, 2010
    Please remember to always note Computer specifications and Operating system details when you post a problem and to explain your problem in more detail.
    Kind Regards,
    Stef
geminii_lady
  • 87 Answers
SOURCE: Office word 2007 installed on vista shuts down when I try to open a file
It could just be a bad install. Try doing a repair via windows 'add/remove hardware' and or a complete uninstall then reinstalling. Would be worth running a registry cleaner and defrag drive before reinstalling. Another thing to try if you haven't already done it is to close down all other programs first, just in case it's a memory issue. Good luck
Posted on Jan 25, 2008
chrischronic
  • 235 Answers
SOURCE: 2007 lincoln MKX - the gearshift stays locked in park. cause?
change the brakelight switch
Posted on Feb 19, 2009
  • 323 Answers
SOURCE: Corrupted Money backup files
There are a few things you can do. Manually open up the *.mbf file, does it open?
If it doesn't, the file type *.mbf may not be associated to Money 2007 anymore. Very common.
If the file becomes too large they also become corrupted. It may be possible to export the *.mbf file to Microsoft Excel. Make sure you create a copy of the file before manipulating it.
http://support.microsoft.com/kb/279274
Actually.... if you have a system administrator. They should have a back up tape, you should already have a path to the file you can give them. They can do a backup and restore of a day or two ago and see if that mbf file was not corrupted as well.
Let me know if I can be of anymore help =)
Posted on Jun 12, 2009
  • 3197 Answers
SOURCE: Craftsman garage door 1/2 hp opens. keeps open for
Most commonly this is caused by a bad wall control or the wiring going to it. The wall control goes bad from constant use and the problem with the wiring is caused by the staples most installers use. The staples cut through the insulation and cause intermittent shorts. I would remove the wall control and check it for a few days and if it happens again you can remove the wire going to terminal #1 on your motor unit. That will eliminate the wiring. Be sure to remember where the wires go on the back of the wall control as they are color coded. One is solid white and the other is white with a red stripe.
Posted on Aug 26, 2009
  • 4 Answers
SOURCE: mine just started this recently.
Sounds like the battery is not charging. My solution was to use a small screwdriver to move the charger pin in the power adapter hole in the under off center. That gave it better contact, it began to charge properly and fixed my issue.
Posted on Sep 14, 2009
Shuts down
This is a typical symptom of a failing power supply. Replace your power supply and see if the problem still persists.
Please notify me should you need any further assistance.
Best wishes,
Graemevm
Jan 06, 2012 | Intel DP55KG Motherboard
I want Microsoft Office Professional 2007 product key
Microsoft has ramped up their efforts to identify stolen software. Even if some unscrupulous person gives you a bogus key, it won't work for very long. Why not give Open Office a try? It is totally free and compatible with all of the entire Office suite. It has a counterpart for each Office program, and will open and edit Microsoft Office files. Go to openoffice.org and check it out. You won't have to worry about security and updates, or your programs getting shut down when you need them most. Good luck.
Apr 27, 2010 | Microsoft Office Professional 2007 Full...
My laptop shuts down for no apparent reason, I believe it may be overheating.
Abrupt shutdown commonly is caused by overheating. This is mostly caused by a faulty CPU fan. Check if the surface of your laptop gets warmer than usual. If so and if you are accustomed to disassembling electronic devices disassemble the laptop and clean the fan and heat sink. Otherwise visit a technician.
Does this occur when you open a specific program for eg. windows media player etc. Note that the application may open and run for a while or even run perfectly sometimes, but observe if the abrupt shut down has any relation to a specific program. If so checking you Ram or using an alternative software will resolve your issue.
NOTE: Some viruses may cause such actions. Scanning your computer with the latest virus definition updated anti virus may solve your problem.
Nov 28, 2009 | Computers & Internet
I'm having problems opening a .docx attachment I've
Try upgrading your MS-Office package to office 2000. in that you have to option to convert and you no need to convert as it opens directly.
You can try this http://www.docx2doc.com/converters/docx-to-doc Please rate this!!
Aug 16, 2009 | Microsoft Windows XP Professional SP3 Full...
Dell 1525 laptop keeps freezing
i am suspesioning on Rams. maybe overheating also does that.
May 30, 2009 | Dell Inspiron 1525 Laptop Jet Black
Jan 28, 2009 | Microsoft Money 2007 Home & Business for...
Acer Travelmate 8210 touchpad problem
Have you ran any spyware scans or antivirus scans? Check my (site) for this software. The Adaware 2007 is 2008 Link not 2007. Check the words files at the bottom of the page. I hope this helps. Spyware can do crazy things.
Jul 23, 2008 | Computers & Internet
Computer shutting down randomly in the middle of everything...even offline games
This can be the result of a virus infection or an infection of other malicious software such as spyware.
Run a thorough system scan.
If this doesn;t help, tell me and we'll go to the next thing to check/do for this kind of problem.
Greetings,
DarkNeogen
Jan 25, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
417 people viewed this question
David Payne
David Payne
