Question about Refrigerators
The Fan of my hotpoint ff175b got noisy becouse of ice deposition. Is that a common or serious problem? I have deiced it once - it was fine for a couple of weeks then it's same again. What shall I do with it?
    Genius:
  • 1,073 Answers
You have a defrost heater defrost bi-metal or the defrost timer bad one of theis is the problem need to isolate the problem with the wiring diagram
Posted on Apr 16, 2008
Hotpoint ffa90p noisy fan
it is ice build up around the fan....defrost it and will be okay...
Feb 26, 2013 | Hotpoint FFA90 Bottom Freezer Refrigerator
Tip
Deicing Your Windows
Summary: During the winter months, or even a freak spring storm, it isn't uncommon to find the windows of your car covered in ice. Deicing your windows can be a bitterly cold experience, so why not learn the best possible ways for both preventing ice from forming on your windows and removing it in a hurry when you need to. Here's how. I really don't like going outside every morning to deice my windows. If you live in cooler (or even colder) climates, then chances are pretty good that you know what I'm referring to.
Over the years I have tried many different methods for deicing windows. I discovered that some work (though at a risk) while others seem to work just fine at preventing ice from forming (what better way of deicing your windows-provided you remember to do it, and others work-but require you to get really cold. Here are some methods, and a brief description of what happened to me when I used them.
  • Defroster. Probably the most common method available. Unfortunately, this method also comes with risks. While a properly working defroster can quickly (no more than 20 minutes usually) remove icy build up, it can also worsen any preexisting cracks in your windshields if turned on too high. There is another drawback to this method, and that is its cost. You can't really run the defroster without turning on the engine, and that takes gasoline.
  • Scraper. The traditional method for removing ice from windshields, a scraper should be in every vehicle that is in a cold climate. In fact, many car rental companies include them in their cars when you rent a vehicle from them during the winter. On average, this method can take about as much time as the defroster method, and while you are not as likely to crack your windshield, you will most likely get cold.
  • Vinegar. One of the best ways for deicing your windshield and windows is to prevent the ice from forming at all. However, not everyone has a garage that they can store their car in. In those situations, it is best to use a 50/50 solution of vinegar and water. Use half vinegar (any kind, though I prefer white since it does not smell as much) and half water in a spray bottle and spray it on your windows at night. This helps prevent ice from forming. The only drawback is that you have to remember to use it at night, otherwise it doesn't do you very much good. Although you can still remove ice by spraying some on your windows in the morning, you'll just need a whole lot more.
  • Rubbing Alcohol. For those who really need to move, try putting about 5 tablespoons of rubbing alcohol into your windshield washer reservoir. This turns the regular windshield washer fluid into a deicing agent at a fraction of the cost, and works wonderfully. Simply spray and use your windshield wipers as normal.
  • Blanket. This is perhaps the easiest way to prevent ice build up on your windshield. Just place a blanket over your windshield at night, and remove it before driving anywhere.
on Feb 03, 2011 | Chevrolet Malibu Cars & Trucks
Myfridge/feezer ff175b makes a clicking noise from behind light and sometimes switchs off.
It might be overheating due to bad condenser fan motor and the compressor relay turns it off.
Jul 18, 2012 | Hotpoint Refrigerators
My Hotpoint FF175B is making a loud buzzing sound from behind the freezer thermostat panel, please help !
Sounds like a sticky relay on the board, but could be an alarm buzzer! Is the freezer working ok?
May 17, 2012 | Hotpoint Refrigerators
My Hotpoint RFA60 is displaying it's High Freezer Temp light. The freezer has become less efficient. How can I fix this
if the unit has iced up then the efficiency will drop considerably.do a 24hour total defrost and dry thoroughly.DO NOT use hairdryers/scrappers as they only deice the surface ice.....if that dont work get back, as its free.....
Sep 22, 2010 | Hotpoint RFA60 Bottom Freezer Refrigerator
Freezer fan keeps icing up
Sounds like the refrigerator is not defrosting Could be the defrost heater, defrost timer or the defrost thermostat.
Aug 21, 2009 | Refrigerators
Hotpoint ff175b fridge freezer. Freezer working but fridge is not. please help
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck! P.s Please don't forget to rate my solution Thanks! Mike
Jul 23, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint Fridge freezer FFA90 - Noisy fan top fridge
worthwhile checking closer. noisy fan can be due to fan blade hitting ice if there has been a build-up. otherwise needs replacing
May 07, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Refrigerators Logo
179 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
