Question about Kitchen Ranges
I have an older Jenn-Air Gas-electric grill-range Model SEG196-C and it came with a care manual but without an installation guide. Jenn-Air was not able to supply one. Anyone know how to install the venting system? The gas connection and the electric connection seem pretty straight forward (I have a licensed gas fitter to do that)
  • 3 more comments
  • doritavv Apr 16, 2008
    I already have the owner's manual, which does not include an installation guide. I need information on how to install the venting system on this model; it is an under-the floor exhaust.
    THank you. Now how do you attach the blower to the range, put it through the floor and exhaust the air out of the building?
    The blow-up photos of the fan exhaust are helpful but give me little information on how it attaches to the range and how to exhaust it through the floor and out the basement wall.
  • doritavv Apr 17, 2008
    Thank you. I have the manual but it doesn't include the installation instructions. The Jennair people do not have an installation guide for this model so their site has not been of any help to me.
    I am still missing instructions for installing the exhaust system.
    Master:
  • 788 Answers
This was in the manual linked by Scott201201 :
Ducting Information
Jenn-Air's ventilation system is designed to capture both cooking fumes and smoke
from any place on the grill surface. If the system does not, these are some ducting installation situations to check:
• 6" diameter round or 31/4'' x 10" rectangular ducting should be used for duct
lengths 10'-60'. 5" diameter round ducting must be used if the duct length is
10' or less.
• No more than three 90 ° elbows should be used. Distance between elbows should be at least 18".
• Recommended Jenn-Air wall cap should be used. Make sure damper moves
freely when ventilation system is operating.
• There should be a minimum clearance of 6" for cooktop installed near a side
wall. If there is not an obvious improper installation, there may be a concealed problem such as a pinched joint, obstruction in the pipe, etc. Installation is the responsibility of the installer and questions should be addressed first by the installer. The installer should very carefully check the ducting installation instructions.
Here is a link to some suitable ducting and hose clamps: http://www.partselect.com/PartSearchResults.aspx?ModelNum=SEG196&mfgModelNum=&fkMfgID=1&Hint=duct
But you should be able to use any mettalic ducting you can find at a hardware store.
Installing the duct should be a lot like ducting a clothes dryer. You will need a suitable cap with a damper, same as used for a clothes dryer. Goto Home Depot or a similar store and they will have everything you need.
Good Luck!
Posted on Apr 17, 2008
  • 563 Answers
Hi there
Visit www.whirpool.com , they have a couple of instructions on PDF.
    Scholar:
  • 170 Answers
Here is the manual
http://shared.whirlpoolcorp.com/assets/pdfs/literature/SEG196B.pdf
here is the link to anything else you may want.
http://www.jennair.com/home.jsp
  • Scott Henderson
    Scott Henderson Apr 17, 2008
    you will need to contact Jenn-Air and let them know they left this info out, there are prob several people out there with the same problem as you. they prob already have the info waiting on you. all you have to do is call them.
  • 19,396 Answers
  • 4,889 Answers
Oh my! I had seen this model long back! About 10 years i guess.. I think i have a manual somewhere will look for it and post it if i have.
Posted on Apr 16, 2008
We purchased an older house that has a Jenn Air D120 Electric Range but no manual to tell me how to use it. Does anyone have one they could scan and send me?
Hello Barbara,
Simple search online will get you to jennair.com
or
You can search within
Guides & Manuals, or call a Customer Care Specialist at 1-800-JENN-AIR (536-6247).
or
kitchen.manualsonline.com
Good luck and all the best in your new home.
Nov 14, 2015 | Jenn Air Kitchen Ranges
Jenn aire oven no power.
go to jenn air web site -find your stove model number and find user & care guide that should help you
Mar 20, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Ignitor not working
Check the ignitor, Make sure that the connection are good and tight. If they are then look at your control board which is located behind your clock. Then check your relay also.
Feb 20, 2009 | Jenn-Air JGW8130A Electric Single Oven
How to replace spark igniter - Jenn-Air SEG196 gas-electric range
took off the knob to the ignition system to clean and spray got onto the ignition under the dial and now the two front burners won't ignite unless I turn on one of the functional back burners then turn on the front burner. How do I repair this?
Jan 22, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Oven door will not unlock.
You will not be able to open the door if you turn off temp gage. Return the temp gage only to clean and door should open.
Dec 13, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
Jenn-air gas electric grill range
This is not a problem. The cleaning cycle goes on for approximately 4 hours as I recall. it will unlock by itself when done. Read your user guide for troubleshooting tips. if you can't locate your copy, one is available on line at the Jenn-Air site
Nov 24, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Kitchen Ranges Logo
289 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
