Colors are not lined up on a phillips 60" - Televison & Video
  • Fsnook138 Apr 16, 2008
    Hey Dan Thanks it is a phillips 60pp93 5217 converge is definitly out of alignment. the converge setup in the tv programs will not align anymore and the red slopes in the corners and is off everywhere else
  • 4,234 Answers
This is a problem with convergence and depending upon what model you have, the fix will be slightly different. Can you please update this with the model number.
Thanks,
Dan
Posted on Apr 16, 2008
  • ABRsvcs Apr 17, 2008
    OK. There are two things you can do. First locate the convergence ICs. There should be 2 of them and they should be marked STKxxx. Try resoldering the pins on these first. Bad connections can change the circuit enough to cause a problem. If that fails, replace the ICs.
    Keep us posted.
    Dan
I have a Phillips 60" rear projection TV. recently
Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture are R,G,B colors lines mis alignments,have colors shadows picture or 3D picture lood alike?The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 01, 2011 | Philips Televison & Video
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
My color wont line up it shows all 3 colors at once on the screen
Replce IC of convergance and check pheriparal componets on the convergence board
Sep 28, 2009 | Philips Magnavox 9P6034C 60" Rear...
My phillips tv has a green line at the bottom
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 26, 2009 | Philips 60PW9363 60" Rear Projection...
My phillips 60 in projection tv is showing to
The two convergence ICs and 12 feed resistors are the most likliest cause. Whats your model number as you can get convergence repair kits which have parts and CD with instructions at www.tvrepairworld.com
Jul 16, 2009 | Televison & Video
I have a Phillips rear projection 60 color lamps off focus
You can't adjust this. Your convergence amplifiers are bad and must be replaced. $250-$350 by repair shop.
Jul 08, 2009 | Televison & Video
Phillips 60pp9202
Did you replace the Convergence Resistors at the same time?
If not you need to replace them also.
Nov 16, 2008 | Philips 60PP9202 60" Rear Projection...
Color fading in picture
you need to replace the coolant in thr CRTs( picture tubes) Vert common problem in phillips. You can get the enitre repair kit at the following link which has the coolant and instruction CD for phillips coolanrt change. Heres the link its under the repair kit section.
http://servicemanuals.vstore.ca/
Jul 21, 2008 | Philips Magnavox 9P6034C 60" Rear...
Color Problems 60PP9352 60" Rear Projection
Check to make sure the green is lit up! You will need to remove back and look inside to tell.
Jan 06, 2008 | Philips 60PP9352 60" Rear Projection...
Blue Color spots on all pictures
Call a technician, sounds like an Integrated Circuit problem and would cost you about $250.
May 07, 2007 | Philips 60PP9202 60" Rear Projection...
Open Questions:
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
Electro Med Services...
