Based on experience with MTD and AYP products: 1) remove mower to deck belt, 2) remove deck, 3) have helper press brake pedal down which puts slack in drive belt, 4) pull drive belt first from front engine pulley or rear transmission pulley then remove entirely. Reinstall in reverse order.
CAVEATS 1) If a pulley is grooved then the narrow part of the belt goes into it, if the pulley is flat then most likely the back of the belt goes against it in a tensioning function. 2) There are often guides or keepers which hold the belt in place, these can be hard to see and if the belt is not routed inside them it may well not work or hop out under load.
