My samsung dlp tv hl-s5687w tv turns off on it on.
  • amamike Jun 08, 2008
    My Samsung HLS5687W turns off about 60 seconds after start up with the
    green "lamp" and red "temp" light blinking. I inspected the bulb
    it appears ok but the reflector is dull and dirty.
  • Anonymous Jan 28, 2009
    I have the same problem. I'll try the fix tonight and see if the problem goes away.
I had the exact same problem with my TV turning off for no reason. If those two lights are blinking in the front it means your TV thinks the lamp door is open and shuts down. In my case i had to open the door and adjust the spring lever because it was not making good enough contact.
Hope that helps.
Posted on Dec 09, 2008
2 Suggested Answers
SAMUEL011
  • 39 Answers
SOURCE: samsung HL-S5687W dlp tv, the picture is darker
Hi
Well for what you describe it sounds like the symptoms of a worn out lamp giving you the last kicks,basically the the lamps are design to go for 6,000 to 8,000 lamp hours if they're Phillips and a generic lamp could give you 3500 to 4500 lamp hours so with this in mind you could search for a new lamp at Discount-merchant.com or you can go to Ebay also you can go to www.fixyourdlp.com for more troubelshooting
Please rate this if it was helpful.as I do this for free.
Regards
Posted on Jan 05, 2010
Testimonial: "Very prompt solution to my problem, thank you. "
Is there a manual for samsung dlp tv 5687- location of fan#2
http://www.manualslib.com/manual/510316/Samsung-Hl-S5687w.html
Oct 17, 2015 | Samsung Televison & Video
Samsung DLP has gone darker
The 60 K hours is bogus---Average life on a OEM lamp is 2,000 hours or two years average---if you got four or more years you were lucky.
To your problem---
Jun 13, 2012 | Samsung Hl-s5687w 56-inch 1080p Dlp Hdtv
My Samsung HL-s5687w turns on only for 3 minutes then turns off standby/temp timer lamp start blinking what dose it mean
Lamp and or ballast are most common BUT did you hear before a high pitched or fan like sound before this happened?
Apr 08, 2012 | Samsung HL-S5687W 56" HDTV
I am having problems with my Samsung HL-S5687W 56 in. HDTV Television It is turning on ok then shuts off after a minute or so.Do you have any recommendations
i have seen before that model have some problems with the lamp door switch. check the back of the tv and make sure that the lamp door is secure otherwise it can be possibly a color wheel or even lamp failure. if you have never replaced the lamp then i would lean more towards that as the root of your problems.
Jan 06, 2011 | Samsung HL-S5687W 56" HDTV
When we turn the TV on, a red light starts to blink but no image or sound is displayed. How can this be fixed?? And What is causing this? my TV model is HL-s5679w
The Blinking light is an error code, most likely you just need to replace the bulb which is fairly easy, there is an access panel on the back and you should be able to replace your self. A new bulb should include basic instructions here is a link price is $110
http://www.buy.com/prod/samsung-hl-s5687w-hls5687w-bare-lamp-bp96-01472a/q/sellerid/28565179/loc/111/215199305.html
Sep 14, 2010 | Samsung HL-S5687W 56" HDTV
Samsung HL-S5687W dlp tv, the picture is darker than usual and getting darker by the day
Hi
Regards
Jan 05, 2010 | Samsung HL-S5687W 56" HDTV
Changed my 2year old samsung dlp tv bulb but it is not as bright when i first bought it. Is there anything else I can do to make it brighter?
You need to go into setup and see what TV Mode you are in.
Movie is usually darker then normal. Do you still have the manual?
Apr 29, 2009 | Samsung HL-S5687W 56" HDTV
Samsung DLP
try this and see if it makes a difference
open the lamp door look for the blue switch(bottom left i think)
take the loose wire(blue and white) wrap it over the switch to hold it back
and while your back there make sure you dont have a lot of dust blocking the vent on the back cover
Mar 11, 2008 | Samsung HL-S5687W 56" HDTV
Televison & Video Logo
433 people viewed this question
Top Televison & Video Experts
Electro Med Services...
