Question about 2wire (1000-400108-001) Router
Win98, Linksys USB Adapter, 2wire router... no internet
I have a 2wire router which provides wireless access to my wife's G4 laptop. I have an old Win98 machine in the basement, with a Linksys USB Wireless-G Adapter. The Linksys application finds the 2wire router, but can not get to the internet.
How do I trouble shoot this? Do I need a 2wire driver in addition to the Linksys driver? Is there some way of logging into the router using a local IP via Internet Explorer? ex: 196.182.1.1 or something...?
  • 5 more comments
  • mlganser3 Apr 16, 2008
    Update: I found the router IP (192.168.0.1) which I access from the browser on the Mac G4, but I cannot open from the Win98 box. (The Wireless Adapter says 'connected', with very different IP's) Next steps?
  • mlganser3 Apr 21, 2008
    What the hell, does nobody post to this site? Or is this just a front to sell the "Premium Assistance Plan"?
  • mlganser3 May 06, 2008
    Thanks so far for the responses.
    One Piece: Infra mode, DHCP enabled, obtain IP auto enabled all OK.
    I am able to connect to the router via the linksys application.
    Serra Baby: IP addr of W98: 169.254.250.209 (sbnt mask 255.255.0.0)
    Distance to router approx 25 feet, one wall. Signal strength @ W98 = 45 - 53%
    WEP security is enabled on router and @ W98 machine, functioning OK
    I have not tried assigning static IP addr. What would I enter as the IP addr?
    My G4 is online wirelessly, from which I can access the 2wire:
    2wire IP addr = 192.168.0.1
    sbnt mask = 255.255.255.0
    DHCP range = 192.168.0.64 thru 254
    Broadband Network:
    63.231.168.36 / 255.255.255.248
    Primary DNS:
    205.171.3.65
    Secondary DNS:
    205.171.2.65
    I find it odd that the IP addr and sbnt msk on the W98 are so far out of whack, although DHCP is enabled , set to obtain IP automatically.
    I have not ever connected the w98 to the 2wire via ethernet. I assumed I wouldn't have to, since any laptop can get in without doing so. I will try that today and report back on the result.
    Update: via ethernet, works just fine, able to access internet on w98/2Wire. Assigned IP 192.168.0.67
    Shut down, remove ethernet, insert USB Linksys adapter, restart. No internet. Same as before.
    Opened Linksys application, profiles tab, clicked edit. Entered all data as above (IP...67, all else as in prior post). No internet.
    Aahhh!
  • Anonymous May 14, 2008
    I have Win2000 and Linksys USB wireless adapter. The wireless adapter says that I am connected to the router. I could not access the internet. Then I decided to install the 2wire modem to the pc that has the wireless adapter and it worked - for one day. Then it didn't recognize the 2wire. The 2wire and Linksys router is located on another pc and works just fine. Also have a laptop that connects to the internet wireless just fine. What is going on with the pc with the wireless adapter - why won't it recognize the 2wire and internet? Thanks for your help!
  • Anonymous May 03, 2009
    I have a problem where my Win98SE PC can surf the Internet via normal wired connection, but when I use wireless usb adapter my PC detects the hardware and it appear on taskbar.  Yet, the icon on taskbar give this error "WL230USB-L USB Wireless Adapter Not exist".
    But it does exist and in Control Panel | System under Network Adapters, my hardware is detected.
  • serra baby
    serra baby May 11, 2010
    hello!
    -- what is the ip address of the 98 computer?
    -- how far is it from the router?
    -- have you tried changing channels on the router?
    -- have you also tried enabling wireless security on the router and on the wireless pc?
    -- have you tried assigning static ip address on the 98 pc?
    Novelist:
  • 144 Answers
Hello!
try to uninstall/remove the old driver and reinstal the latest driver of your linksys usb adapter. you can download it from the linksys website.
check again if you can get a wireless connection from the router to your 98pc. if not try to change the wireless channel of the 2wire to channel 1 and configure the wireless security again using the linksys usb wireless utility
if you still cant get a connection try to manually assign this ip address on the 98pc then check connection afterward.
IP add: 192.168.0.5
subnet mask:255.255.255.0
gateway:192.168.0.1
dns: dns number of the 2wire router
if you still cant get a connection after this try to install the wireless usb adapter to a diff computer to further isolate the problem.
Posted on May 08, 2008
  • serra baby
    serra baby May 08, 2008
    i also happen to have a free promo code from the supportrix technical support. if you like, you can use the promo code which entitle you for 1 free tech support.
    promo code: SUPPORTCALL
    Scholar:
  • 53 Answers
Hi!
sorry if it took a while to get an answer to your question...
anyway, let's begin by ensuring that you have completed installing the drivers & software of your wireless adapter.
launch the linksys wireless program by clicking on the icon for the linksys on the system tray or generally, this can also be launched from the programs menu after clicking on the windows start button.
on the main screen for the linksys, there are 3 tabs: link information, site survey & profiles. select the profiles tab
on the profiles screen, click on the new button to create a new profile. name the profile with a customized ID & click ok.
under choose a net type, select infrastructure mode. enter the SSID (this is your customized ID created on the new profile) & click next.
under network setting select obtain an IP address automatically (DHCP) & click on next.
under security settings choose "disabled" for WEP and leave the rest of the fields blank.
confirm the settings by clicking on yes.
note: you don't need a driver for your 2wire router, ensuring that the 2wire is already working with the ethernet connection.
also make sure you are able to see your devices on the mdc page, go to homeportal/management, local network> device list.
i assume that the mac g4 is able to connect wirelessly to this 2wire modem, am i correct?
please let me know if you have any issues... we'll work this one out, ok?
Posted on Apr 25, 2008
I have a 2wire 802.11g usb wireless adapter. I
yes it would you just need to place the 2wire on a bridge mode then configure the linksys
Nov 22, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Trying to connect my ps3 to the internet but need wireless route
That won't work because your old sbc wireless router 2wire gateway is also a modem. You need a plain router for Time Warner. Try Linksys router.
Sep 08, 2009 | 2wire (1000-100052-000) 802.11g/b Wireless...
Wireless Devices won't connect to 2Wire Modem
change the channel. this is a common problem when wireless routers are broadcasting on the same channel and at times, some cordless phones will interfer as well.
good luck
Aug 06, 2009 | 2wire HomePortal® 1800HW Router...
Linksys wireless adapter won't auto connect to 2Wire router
Go into the wireless adapter settings and make your connection "default" and then it should connect automatically .. and if not then look for a "connect automatically setting
May 29, 2009 | 2wire HomePortal® 1800HW Router...
first of all let's start from the complete facts, does your 2wire router have built in wireless or no? how you did the the cable connections between tht routers?.
Apr 04, 2009 | 2wire HomePortal® 1800HW Router...
I have a desktop and laptop I want to know if I can use the Wire2 Wireless usb adapter to create a network that the laptop can access and how to do this
first of all u hav to get a internet connection in ur home,,ur internet provider will provide u with a modem,if tat modem has wireless capabilities then u dnt need to purchase a router otherwise u hav to do so.then u have to setup the wireless modem or the router and the 2wire wirelss USB adapter on the same wireless network.plz keep me posted for further issues
Feb 21, 2009 | 2wire (1000-100052-000) 802.11g/b Wireless...
2wire capacity for wireless connection
yes you can return the linksys.
the following link should help you setup the 2 wire for wireless conneciton.
Dec 03, 2008 | 2wire (1000-000057-000) Modem
Linksys Adapter and 2wire router
  1. ensure that a wireless connection is created in control panel on the pc, it may not even be attempting to connect
  2. ensure that the router wireless is turned ON, it may have been turned off as a security measure when no wireless pcs were used
  3. The security settings on the adaptor may be set to the office network and locked
    wep password at home is different or not enabled, so the secured adaptor will not connect.
make any changes from a cable connected pc (no chance of data loss)
access the routers settings page and check the settings,
then ensure the adaptor rom if present is set to the same settings
Jul 16, 2008 | 2wire 2700HG-B Router (2700HGB)
WUSB Linksys adapter connnection
check your dns value ,firwall,proxey server, ipaddress and router configuration also.
Jun 23, 2008 | 2wire 2700HG-B Router (2700HGB)
Linksey wireless-g usb adapter and router
lose internet connection from my second computer that is linked to main computer (main computer has internet connection). Tried to click repair and it said couldn't be repaired contact internet provider?
Nov 01, 2007 | Linksys Wireless-G WAP54G 802.11g/b...
2wire (1000-400108-001) Router Logo
1,269 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
