Question about Pioneer SD-P50A5-K 50" Rear Projection Television
Blurry double image on the edge of the tv...
I have the tv for almost 10 years now....and about a month ago...the image on the side or edge of the tv(left and right) started to have double image, any idea what might be the problem? and how much would it cost to fix?Thanks a lot!!!
    Filmmaker:
    Uploaded 5 video answers.
  • 41 Answers
If you have tried to adjust the convergence on your TV within the menu feature then typically you do have a convergence problem. Check out this video to be sure...
Posted on Oct 08, 2012
  • James Lynch Sr Oct 08, 2012
    www.youtube.com/watch?v=RGCEM5s5iCMThanks
  • 21 Answers
Sounds like convergence again.
Speakers near by?
Is the image a different color? Look closely at the screen. Could be a capacitor. Could also be a picture tube, but at this point one should rule out other possibilities. Dust on the lens?
Posted on Nov 03, 2008
KP-51WS500 it started a couple months ago the
Hi, that is look like ,,you have defective convergence module if it is a dlp it is probly the light bulb,
hope that will help you to find a good tech
to fix it.
have a nice day
May 05, 2010 | Sony KP-51WS500 51" Rear Projection...
Image shattered/double when moving.
check your antenna connection and auto-reprogram the channels.
Apr 27, 2010 | LG 42LC2D 42 in. LCD HDTV
Blue images on lcd tv
optical block failure
Feb 22, 2010 | Televison & Video
Blurry picture on left side double image right side is ok....
Ur convergence is dead,need convergence kit.
U know how to solder right?Tries these websites for convergence kit.Tv Repair World.com,Shopjimmy.com,Ebay.com or Partstore.com
Sep 25, 2009 | Zenith IQB50M90W 50" Rear Projection...
Tv shows double images
Look for the convergence menu in the manual and try to align it.
Apr 02, 2009 | Toshiba TP55H60 55" Rear Projection...
I have a Samsung CRT slimfit that I bought in 2006. It has worked splendidly until about 4 months ago and suddenly I have started to notice the edges of the screen about 2-3 inches on both sides have...
In my experience from doing Samsung's warranty work on slimfit sets, they have issues with picture tubes causing problems on the circuit boards. Many times I would replace a board only to have it fail a short time later. The wide crt draws a large amount of current and many have purity (discoloration around edges) problems. I would suggest you try contacting samsung to see if any recall exhists on these and if that doesn't work I wish you luck having it repaired properly for under 275.00
May 21, 2008 | Samsung Televison & Video
Distorted picture
On the middle circuit board towards rear is a metal wavy plate.On the back side(actually towards screen when looking from rear of unit),the middle screw has a ground wire(light brown) that is loose.
Apr 08, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Blurry edges
I own the same model of tv and have owned it for over 1.5 years. I moved with it twice. I had this problem about a month ago. On both vertical sides the screen became very fuzzy, yet the center remained clear. When turning the tv off and on I also noticed very wierd red, green, and blue lines streaming across the screen before the picture comes up or after it fades. I found no solution or cause to the problem. But I had two "long-boy" speakers from my panisonic 5.1 surround sound system setup right next the tv on either side. I set the center channel on top of the tv with the receiver on the shelf below. I thought well maybe some how the speakers were cause some sort problem in the tv. I moved the side "long-boy" speakers from directly next to the tv to about 6" away and removed the center speaker from the top of the tv. After several days of normal use of this configuration, the tv turned like normal and the fuzzy edges were gone. The symptoms lasted for around two weeks, and the several days after I moved my speakers. My only guess is that without a deguassing feature, it took several days for the magnitism to return to normal after repositioning my speakers.
Mar 17, 2008 | Samsung SlimFit TX-S3082WH 30" TV
Picture shadow on rear projection Sony big screen TV
OUR TOSHIBA HAS A DOUBLE VISION/BLURRIE PICTURE. THIS PROBLEM IS ALWAYS THERE. SOMETIMES THE PICTURE IS GREAT, BUT MOST OF THE TIME ITS BLURRIE/DOUBLE. LOOKS AS IF IT ALWAYS ON 3D!! ANY SUGGESTIONS? WE WOULD REALLY APPRECIATE ANY HELP WE CAN GET FROM ANYONE. THANK YOU!
Mar 03, 2007 | Toshiba 55H70 55" Rear Projection...
Pioneer SD-P50A5-K 50" Rear Projection Television Logo
122 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
