Question about Canon DR-7580
Duplex Scanning We do a lot of duplex scanning. We use a software called WYNN Wizard. The DR-7580 worked in duplex just fine for 2 years. For some reason it will now only scan one-sided documents. We have checked the settings, talked with the maker of the WYNN software, uninstalled and reinstalled all software and drivers...nothing! Anyone had anything like this happen before?
  • 490 Answers
I havent used WYNN wizard. I use Capture perfect ver 2.0 it is available free of cost. Try with it. If it is okay, then may be some setting is missing. If it remains same, then there be some hardware issue in the scanner.
S. Mohan
Posted on Mar 25, 2009
Will Only Scan Color and single sided
Once I had a similar problem with CapturePerfect 2.0. No amount of setting will change the scan output. I hit the default option and then changed to the setting I wanted. It worked. May be there is a bug in the Scanning software.
S. Mohan, India
Jan 09, 2014 | Canon DR-3080CII Path-Through Flatbed...
Color duplex doesn't work
The Canon DR-3080C is only color on the front side. The back side is monochrome only. The next model, which was the DR-3080CII will do double sided color scanning
Sep 13, 2012 | Canon DR 3080C Path-Through Scanner
My Canon DR 7580 has image void in the front image. Looks like two void columns. The Image reader is clean. Can the upper and lower imager be swapped to see if the problem is the upper imager?
You cannot swap upper and lower images. You can scan the page twice (in duplex mode) by reversing the same. Ensure which side is giving perfect output.
DR 7580 is a CONTACT scanner and hence the paper has to touch the glass surface properly. There are two full sized rollers, just above/below the scanning module, which does this job. Ensure that they are proper and there is enough pressure, press and release 3-4 times to check it is stuck.
S. Mohan, Chennai, India
May 19, 2011 | Canon DR-7580
Canon DR-9080C gives Low memory message
Duplex scanning, Color Scanning and high-density scanning (600 dpi) cannot go with long documents like 11x17. Change the scanning mode, try one side at a time or reduce the resolution.
Dec 11, 2010 | Canon DR-9080C Path-Through Scanner
Canon Dr-7580 not scanning two sided.
Check if you have chosen the 'duplex' option.
S. Mohan
Jan 11, 2010 | Canon DR-7580
Canon Dr2050C Duplex scanning reverse page all black
Check your brightness setting for backside. Ideally keep it automatic, else you can manually choose the right brightness.
S. Mohan
Sep 18, 2009 | Canon DR-2050C Path-Through Scanner
Scanner is not reading multiple pages...
Check your scanning software settings. If you are getting only one file output, then you must have chosen 'multipage' option.
S. Mohan
Jun 12, 2009 | Canon DR-2580C Path-Through Scanner
Canon Dr-2580C
Try and scan a white paper. If the output is black, then may be the LEDs are not glowing, likely the wire is loose. Actually it is not easily reacheable! Try duplex scanning to check if both scan modules are fine.
S. Mohan
Oct 14, 2008 | Canon DR-2580C Path-Through Scanner
How to Default Duplex Scanning
  1. Image Scan Can not be Found.
  2. please check and Cable connection
  3. and the scanner is not used by other application.(Code:DS42019)
THIS THREE ERROR WILL SHOW AT MY SCANNER.
AFTER PUT GHOST IT WIL SLOVE.OTHERWISE WIL NOT SLOVE.
COULD U PLS GIVE SOLUCATION
Jul 02, 2008 | Fujitsu fi-4120C Path-Through Scanner
Duplex Scanning
If the line appears in the same location, it is definitely dust sticking to the glass. How thick is it? If it is thick, it may be because of an LED failed to glow, but this is etremely rare. If you are getting line in Duplex mode and not in simplex mode, it is on the second scanning module! Try cleaning with Isopropyl Alcohol (IPA). If you have been scanning old documents which tend to break like biscuit or get powdery, a speck can enter into the scanning area and create trouble.
S. Mohan
Oct 26, 2007 | Canon DR-2050C Path-Through Scanner
199 people viewed this question
old marine
old marine
