Question about Microsoft Xbox 360 Console
Regular xbox my xbox will only read audio cd's but not any xbox games or dvd's, how do i fix this problem?
  • 51 Answers
I kinda had the same problem what it is doing, is that the drive is not able to read those types of things anymore if you air dusted it out and everything and it still does not work, then you need a new drive.
Posted on Apr 16, 2008
Xbox 360 will not read games but plays DVD and CD
It would be best to take it to someone who mods them as they will know if it is the correct drive and if it is running modded firmware(as they are the guys who do this regularly) and if the drive has been set up correctly. They also may be able to extract the drive key and reflash the original(or modded if you preferred) firmware for the drive.
Apr 23, 2012 | Microsoft Xbox 360 Console
Xbox open tray problem can read cd`s but not games
The DVD reader portion of your CD drive has broken. This is a common problem, but an expensive fix. You can send it in to microsoft for a repair, or buy your own XBOX CD drive and replace it yourself. Alternatively, you can buy the HD DVD reader from Microsoft and play games that way.
Jul 11, 2011 | Video Game Consoles & Games
I put the disc in and it keeps saying open tray
The Console is not able To read The Disk.
First Try A DVD Movie ?
Then A Music/Audio CD ?
If it reads either Or Both Of These, the Dual-Layer Laser Has Failed, Which powers up with increase To read Dual-Layer ( X-Box 360 Games ) A New Or Replacement DVD Drive, Will Be Required.
Mike @ Compurepair.
Oct 16, 2009 | Microsoft Xbox 360 Console
My xbox wont play games. it just sits on the xbox dashboard.
Dirty Or Faulty Laser Head.
Try an Audio CD Or DVD Movie.
If none read at All, you Need A replacement DVD drive.
Mike @ Compurepair.
Aug 19, 2009 | Microsoft Xbox 360 Console
A Xbox Classic Problem
All you need to do is find an xbox dvd drive on the net (ebay trademe etc) and install it yourself. Very easy and in expensive. Or take it to an xbox modifier and he will fix it, but for around 50 dollars.
Jun 15, 2009 | Tecmo Inc. Classic Arcade for Xbox
My game wont read on my xbox 360
I believe you can use a DVD cleaner without voiding your warrenty. If you have a warrenty then call Xbox tech support to get it fixed. And if you don't buy an extended warrenty for $50 and then call them and tell them you need your Xbox fixed
steps to be followed.
  1. step 1 Purchase a DVD lens cleaning disc.
  2. Step 2 Turn on your television and Xbox just like you normally would to play a video game.
  3. Step 3 Open your Xbox's disc drive, placing the lens cleaning disc in the drive face-up. A lens cleaning disc works by sweeping small brushes over the laser lens surface. These brushes are located on the bottom of the disc; be careful not to touch the brushes---the microfiber brushes are delicate and can become damaged easily.
  4. Step 4 Close the Xbox and let the machine power up; make sure your television's volume is turned on. Your Xbox should automatically take you to the system's standard CD player menu. If this does not happen, select the menu manually using your Xbox controller.
  5. Step 5 Begin playing the first track of the cleaning disc. Listen carefully, because audio directions will play indicating the steps necessary for properly using your cleaning disc. Each brand of lens cleaning disc will have different steps, but they are typically very simple, involving tasks like skipping ahead to different tracks or briefly putting the CD in fast forward mode. If you cannot hear the audio directions, consult the written instructions packaged with the disc.
  6. Step 6 Remove the cleaning CD after you've followed the audio directions---a typical cleaning cycle only takes a few minutes, and the audio directions will tell you when cleaning is complete.
  7. Step 7 Carefully place the lens cleaning disc back in its case, avoiding damaging the brushes on the bottom. Lens cleaners can be used multiple times, so plan on using the cleaning disc regularly to help avoid future problems with your Xbox console.
Jun 13, 2009 | Microsoft Xbox 360 Console
Error Message
Be sure to wipe clean around inside hole on 360 game disk it has info laser scribed that tells the system what game it is.It might also need a laser adjustment.
Dec 26, 2007 | Microsoft Xbox 360 Console
360 game reading problem
ive got the problem to on some games eg. assassins creed just bought it, it keeps saying read disc error its not the disc its the xbox itself im gunna try and take it bk now.
p.s.the problem is with the memory unit on top.
Nov 17, 2007 | Microsoft Xbox 360 Console
Message "To play game put game in xbox 360 console"
Pick up in the DVD is bad or weak and will need replacing.
Or replace the whole DVD unit.
Make sure the disks are clean and not too scratched up
Check here for more things to try
Nov 07, 2007 | Microsoft Xbox 360 Console
Put this in an xbox 360 console
Did you try using a cd lens cleaner in the XBox 360 dvd drive? Check the cds that they are not scratched, and you could have your son try the discs in another XBox 360.
Nov 06, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
29 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
