Question about Vacuums
Cleaning brushes don't rotate during cleaning!
It might be a cloaged vacuum hose.  does anyone know its whereabouts?
  • mwhitman Sep 17, 2008
    yes I have same problem- brushes don't rotate. belts appear to be okay- but brushes don't move!!
  • Anonymous Dec 22, 2008
    Same problem. The "solution" below doesn't really apply to the brushed
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
It might be a clogged vacuum hose. Does anyone know its whereabouts?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
The best way to tell if the vacuum hose is clogged is to take a round ball, marble or steel ball or a nut & bolt assm that is about the same size as the vacuum hose opening & drop it or run it thru the vacuum hose and if it comes out the other end the hose is not clogged. If you have a braided hose (cloth on the outside and black rubber in the inside) the inside black rubber or inside of the hose brakes down and starts to leak and the air moving thru the hose will escape thru the hose and reduce suction. Also make sure the suction release valve is closed as well. There are some vacuums that use a braided hose and the only fix to that problem is to replace the hose. Feel free to check with you local vacuum dealer in the yellow pages or call the factory listed below:
If it is a braided hose from Electrolux the phone number is:
http://electrolux.com Customer Service
Electrolux Home Care Products – North America
PO Box 3900 Peoria, IL 61612
1-800-896-9756
Posted on Apr 17, 2008
Brush head will not spin. Canister is completely clean yet no rotation to be seen.
If cleaning the brush bar really well doesn't solve it you may want to replace the filters. If that doesn't work you may need to replace the brush head.
Feb 16, 2016 | Dyson DC05 Bagless Canister Cyclonic...
Why does the brush continue to rotate on bare floor setting as well as using hose attachments?
Hello! The brush roll shut-off feature is on select models. Your vacuum may or may not have this feature. If it does not, the brushes will continue to rotate while hose is removed or in use and at all times while cleaner is on. The vacuum must be in the upright position to lift rotation brush off the carpet when cleaning above the floor. Be sure the vacuum does not tilt forward when doing above floor cleaning. Hope this was helpful!
Aug 10, 2014 | Dirt Devil Vacuums
Spot bot leaking when using manual hose
This is an old post but I thought it might help anyone having this problem now to post the solution.
The internal water pump feeds two water delivery hoses on the Bissell Spot Bot. One goes to the spout located in the center of the rotating brushes.
The other feeds the spout located on the underside of the brush at the end of the hose.
There is a water shut off valve that is actuated when you pull the plastic tube at the end of the hose out of the plastic tube it is fitted into during storage.
When you pull the end of the hose out of this plastic fitting a button inside is no longer depressed and a valve shuts of the water flow to the rotating brushes. If this valve is clogged with gunk it will not release when the hose end is pulled out and water will still come out of the rotating brushes even in manual mode.
This is a mechanical fault not an electronic fault.
To resolve the issue you can mix a solution of vinegar and hot water and fill the water tank with it.
Put the rotating brushes over the sink. Remove the hose and fit the scrub brush to the end.
Start the machine in manual mode. The sink will catch the water coming from the rotating brushes area.
Now point the hose end at the sink to catch the water and pull the water release trigger. While holding the trigger press and release the black button inside the tube that holds the hose end during storage. This moves the internal workings of the valve.
Do this till all the water is gone.
At some point during this procedure you will notice that when you release the black button the water will stop coming from the rotating brushes.
You problem is now solved.
If this does not work after two tanks of hot water and vinegar then the valve would need to be removed and soaked in a solution or replaced.
This is a much more complex procedure that requires disassembly.
Maybe a youtube video is in order.
If your lucky the procedure above will solve the problem.
Nov 05, 2012 | Bissell SpotBot Robotic Wet/Dry Vacuum
Brushes don't rotate during floor cleaning
Check that no strings or other debris is clogging the brush wheels. If it isnt that check that the belt isnt broken connecting the brush to the motor. If that is ok, most likely the motor is blown and not turning the belt.
Sep 20, 2012 | Hoover F7425-900 SteamVac V2 Widepath...
This vacuum is not picking up anymore when used as an upright, however it does still work very well when using the hose and attachments, I have looked at the vacuum but I cannot figure out where the clog...
Is the brush rotating?
Have you turned it over, taken off the bottom plate and cleaned it out?
Is the belt in good shape or does it no longer rotate the brush?
Is it on the proper floor/carpet setting for the surface you are cleaning?
Try these as they usually repair most vacuum issues of this type.
Apr 15, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
The cleaning solution stopped coming out of the rotating brush but still comes out of the hand held vacuum hose.
If you can check where the vacuum hose where it is connected their might have dirt in the opening to the rotating brush,or it is glogged,clean with a wire and it will be ok
Oct 10, 2009 | Bissell SpotBot Robotic Wet/Dry Vacuum
Rotating head does not rotate
Check for broken belt in the brush roll compartment and replace
Sep 20, 2009 | Vacuums
DC07 bottom brush does not rotate.
I can not pinpoint what exactly solved the issue. I opened the bottom conver, cleaned any presence of hair, cleaned all hoses (yes hose was completely clogged), made sure that the brush bar was engaged by switching the selector back and forth few times from Carpet to Bare floor. (On bare floor setting, brush bar won't rotate).
Now I am happy that the vacuum is completely cleaned and back in operation!
Nov 05, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Brushes not spinning
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40473&thid=732696
Posted by mathis_23 on Jul 02, 2008
I cleaned filter and the brushes are still not rotating.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It probably is not the filter that will start the brushes turning again, it may be a few other things. There is a switch in the front that indicates brushes on and brushes off, and the switch could be broken, it could be that the brushes come in an assembly and the assm could be belt driven and you would have to replace the belt or the drive mechanism the turns the brushes is broken. These are just suggestions and you should check the schematic in your owner’s manual under trouble shooting. If you don’t have a owner’s manual, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 02, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Vacuums Logo
206 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
