Need help keeps saing protector
  • 2 more comments
  • LewisG Oct 19, 2008
    The GX700ES system was working until I moved. Then when I connected it again, it powers up, plays (static when set to FM at least) for about 1-2 seconds, and then says "protector". I thought it had to deal with a short on the speakers, or that no speakers wer connected, but even when I switch speakers to off, and just a headphone, it does the same thing. It's a great stereo, and I'd hate to have to buy a new amp just because of this.
  • Anonymous Dec 14, 2008
    I can't listen to anything , if I have the volume over 2 , if I turn it up , it shuts down , and the word protector , flashes in the window . I have to turn the power off , then back on , to listen , but not over 2 on the volume ?
  • mhazenjr Dec 23, 2008
    I turn the power on and after about 10 seconds the screen says protector mode and locks up. Any solutions?
  • saramago Jan 02, 2009
    HK 3380 keeps saying "protect" after seconds or minutes of playing and then turns itself off. sometimes lower volume makes it stay on for longer.
    Problem Solver:
  • 5 Answers
This receiver is very sensitive to heat. Make sure that receiver has it's own outlet and that it is properly getting ventilation. Unplug receiver for 1 to 2 hrs... Also make sure the impedance (using A & B ) for front are correct...
Posted on May 01, 2009
Why do I need a mattress protector?
If you want to keep your mattress clean for a long time and want it to prevent from damage, you should use a mattress protector or you can say mattress toppers.
These toppers would help you to protect your mattress dirt free and keep it away from damage caused by wear and tear.
If you want to have a best high-quality mattress topper to make your bed more attractive, you can prefer Top Rated Mattresses.
They would provide you an amazing collection of mattress toppers made up of high quality materials at best offers.
Feb 08, 2016 | Furniture
My Kenmore elite microwave is plugged into a surge protector and keep tripping the surge protector. I cannot use the microwave for more then a minute before it trips. Can you help
Your microwave is pulling more amps than the surge protector can handle. Remove the surge protector from the circuit and plug oven into wall outlet. Preferrably a GFCI circuit. Or you could puchase a surge protector with a higher amp tolerance.
Sep 04, 2011 | Microwave Ovens
Panasonic sa-ak630. i turn it on an display said f 61 an turns back off all in a matter of a second or two... wires are all good.. and even just left everything unhooked an still no help... manual said...
F61 is the shorthand for Panasonic machines to mean protect mode. See the link below for a generic explanation of protector. Specifically, in your machine, either the regulator IC has failed or the output amp IC has failed. In any case, the repair will not be cheap. The output IC costs between $75-$125 depending upon the specific IC.
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
Sep 06, 2010 | Panasonic SA-HE100 Receiver
PANASONIC SA-HT830V EVERYTHING SEEMS TO WORK
Try shorting across this fuse protector IP1280 (looks like a resistor) on the power board. See more detailed solution I posted in this forum for a similar question.4a63623.jpg
May 18, 2010 | Panasonic SC-HT830V System
Bose SA-3 amp and a non bose sub.. I keep blowing the amp..
How many ohms is your sub? The SA 3 Amp can only handle speaker(s) 6 ohms and greater. A lot of subs, as I understand, are 2 and 4 ohms typically. If yours is 2 or 4 ohms, then that explains it. The speaker would be "straining" your amplifier and blowing it.
Oct 02, 2009 | Bose Lifestyle SA-2 2-Channel Amplifier
HSM25GFTA SA Side by Side
Thank you... I have replaced the motor and will see how long this one lasts.
Tim
Jun 11, 2009 | Hotpoint HSM25GFRSA
I have a Crosley dryer and I need to know the size of overheat protector for model number CDE22B7BC. The dryer had a faulty overheat protector as I had it checked by a serviceman but he thinks it may need...
The electric heater fuse takes a 300 degree limit. Pink dot6885cfc.jpgThe kit comes with a 250 degree for gas and a 300 for electric. many people have told me either one would work and many folks have said when the 300 degree poped they have used the 250 till it too dies.Keep the dryer clear of lint and regularly checked for lint balls and striped blowers to keep this problem at bay.
Jan 12, 2009 | Crosley CDE6000 Electric Dryer
NEED NOZZEL PROTECTORS
go to any service shop for air gund they have them in stock- most are generic
Oct 11, 2008 | Tools & Hardware - Others
Panasonic SA VK550 - F61 eror
Hi, i had the same problem with a panasonic player, when you see the code F61 in the screen it is because the audio output IC is defective,change that and the set will work perfectly. hope it work.
Feb 05, 2008 | Panasonic SC-AK33 CD Shelf System
Screen Protectors
When you apply the screen protector, try to flatten it out with a CC as you apply it.
Sep 13, 2005 | Dell Axim X5 Pocket PC
585 people viewed this question
 Grubhead
Grubhead
