Question about Meade Infinity 114EQ-DH Telescope
Meade telescope focuser missing - Meade Infinity 114EQ-DH Telescope
  • 3,186 Answers
Most of the large retailers sell replacement focusers-- try these.
http://www.telescope.com/control/main/
http://www.optcorp.com/
Posted on Dec 27, 2008
  • 67 Answers
Ebay, cloudy nights classifieds, are good places to look, i used an anteres crayford focuser for a 8" newtonian. this did require some modifications to the tube.
Posted on Dec 09, 2008
  • 44 Answers
SOURCE: Inoperative focus control
I'm assuming this is the Maksukov-Cassegrain telescope. Turning the focus knob CW should get you focus at infinity by moving the primary mirror away from the eyepiece. As you turn the knob it should move in and out relative to the real of the scope. If that's not happening the focus screw may have been turned CW too far and no longer be catching the threads in the rear plate of the scope.
You may be able to get it to rethread by holding the front of the scope toward the ceiling and turning the knob CCW. Attached is a photo of what the scope looks like under the rear housing. To prevent the focuer shaft from turning in too far the knob should be firmly seated agains the rear of the shaft. I think on this model this is a friction fit.
HTH, George
Posted on Mar 01, 2008
  • 1027 Answers
SOURCE: meade LX200GPS telescope
The front panel for the telescope has an internal fuse. Remove the screws and look at the circuit board for a fuse. Replace with the same type and rating. The telescope has a diode with the fuse that gives some protection against reverse polarity, and the telescope should function on this fix.
Posted on May 22, 2008
SOURCE: problem with lx200gps meade telescope
It might be a voltage or electrical current problem. Make sure your DC power supply is between 12 and 14 volts. Make sure all electrical connections are tight. Where the power cord plugs into the connection panel, make sure the center pin on the panel fits tightly into the plug. It is a Radio Shack type "N" plug. If tou still have a problem, remove the bottom plate from the scope base and make sure all the connectors are properly seated on the circuit board. Check the connector on the end where the black and red wires are. That is a main power connector and if it is too loose it will not conduct enough current. There can be enough voltage drop that the drive motors won't operate, or they will and the scope will slew uncontrollaby. Be careful handling the wires so that you don't damage them. Good luck, Dave
Posted on Sep 26, 2008
  • 67 Answers
SOURCE: Meade DS-2000 Manual Doesn't have info. about Meade Ds-2130
ds-2000 refers to the model line of the scope. ds-2130 the 130 refers to the diameter of the objective lens in mm. I have a ds-2114. Where the objective lens is 114 mm in diameter. as far as the manual goes everything else should be the same.
Posted on Dec 08, 2008
SOURCE: I bought a used meade polaris 60az-m telescope and
Here is the Meade manual web site. Find your telescope and see if a part is missing.
http://www.meade.com/manuals/index.html
and here is their customer service phone number:
http://www.meade.com/support/index.html
Posted on Aug 30, 2009
.comMy Meade Polaris Telescope is
go to your local hardware store and find one that fits!
Sep 07, 2010 | Meade Polaris 114EQ-D (36 x 114mm)...
I got a Meade Model 4600 at a yard sale with no info on it. I think it is missing a lens. Is there any way I can find out. Also, is there any written material or directions I can get for it? Thanks. K
This is a reflector style telescope on an Equatorial mount.
The mount must be polar aligned in order to use it. Read my TIPS on equatorial mounts on my profile page.
The eyepieces slip right into the focuser. The LARGER the number written on the eyepice the LOWER the magnification.
Here are all the Meade manuals, find your telescope near the REFLECTOR topic header:
Aug 20, 2010 | Meade Infinity 114EQ-DH Telescope
The rack and pinion gear on the focuser for a meade ds 2000 telescope got stripped. I can't find replacement focuser .
You can possibly buy another focuser from Meade here:
Orion Telescopes also sell focusers here:
http://www.telescope.com/control/telescope-focusers
Jul 21, 2010 | Meade DS-2130ATS (250 x 127mm) Telescope
Need a focus knob for a MEADE ETX-70 TELESCOPE
You can try calling Meade here:
Apr 15, 2010 | Meade ETX-70 (240 x 70mm) Telescope
Broken focus tube hreads
Meade may sell you another focuser, contact them here:
You can also buy a replacement focuser from several on line retailers-
Here is one-
Mar 29, 2010 | Meade DS-2114 ATS (325 x 114mm) Telescope
I recently aquired the bottom part of a Meade Lightbridge 10" Truss Dobsonian Telescope. This includes the Primary Mirror & tube that contains it plus the 3 Struts and not much else. I think I can make...
Try posting this question on the www.cloudynights.com FORUM, either in the REFLECTORS topic, and or ATM, Optics Topic.
Someone will answer you with the exact dimensions You can also post a Free Classified ad there -- a WANTED ad looking for the entire missing top section, Meade "may" also be willing to sell you this.
www.meade.com.
Clear Skies
Mar 18, 2010 | Meade LightBridge 10 in. Standard (600 x...
The focal tube on my Meade DS 114 has several stripped teeth. The auto-focus skips and jumps! Where can I find a replacement part (Meade no longer carries them) OR how can I repair this; ie, create new...
You will need to buy another focuser like one of these.
http://www.telescope.com/control/accessories/telescope-focusers/1*25-inch-orion-basic-rack-and-pinion-focuser
http://www.telescope.com/control/accessories/telescope-focusers/2-inch-orion-crayford-style-telescope-focuser
Feb 21, 2010 | Meade DS114-EC Telescope
Cannot focus a Meade Refractor "Electronic Digital" series
All of Meade's manuals are listed here--
Take it outside during the day time-- put the eyepiece with the LARGEST number written on it into the telescope--- this is the LOWEST magnification.
Point it at a distant object and practice focusing-- the moon should be your first night time object.
Jun 13, 2009 | Meade Polaris 285 (225 x 60mm) Telescope
Meade DS2102 Telescope lost teeth for focusing in and out
It might be easiest to see if someone is selling one on Craig's list or ebay.  You might be able to find one used where the telescope is OK, but the motorized drive is broken and replace the telescope.
Here is the contact information for Meade:
Contacting the Customer Support Center     Customer Support representatives are available to handle your calls and letters regarding any Meade product 7:00am to 5:00pm Pacific Standard Time, Monday through Friday, excluding holidays. To contact the Meade Customer Support Center, please write, call, or fax. Our information is as follows:
Meade Instruments Corporation
27 Hubble
Irvine, CA 92618
(800) 626-3233 (U.S.A. Only)
You could try calling them and see if they will sell the part you need for the focuser.  The focuser is called a rack and pinion focuser.  From your description it is hard to know if it is the long linear gear on the draw-tube (the part that holds the eyepiece) or the gear on the shaft of the focusing knob.  You will need to be able to describe that to them.
I hope that helps.
May 05, 2009 | Meade Optics
Meade Infinity 114EQ-DH Telescope Logo
262 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
