Blown Compression Drivers
Hi. I have a Yamaha PAS500 rig with two blown HF compression drivers. I'd like to know the tech specifications of these drivers to source replacements but can't find anything on the Yamaha site. Any ideas?
    Sergeant:
    Champion:
  • 319 Answers
This unit features 2 -10" passive speakers and HF horn/driver. If you are blowing the HF driver, the problem is with overdriving the high range of EQ. At sustained high volumes, the voice coil of HF driver will overheat and open. If you still have effective warranty, ask Yamaha to replace drivers. Fixed,-- back off higher frequencies of EQ, turn down volume.
Posted on Apr 17, 2008
My 2006 ttr 230 lost all compression all at once and never smoked,is it just the timing chain or is it blew up?
Hi, Anonymous and the usual suspects are:
1. Broken or loose cam chain.
2. Loose or broken cam sprocket.
3. Bent, burnt or stuck valve.
4. Blown head gasket.
5. Piston failure.
6. Broken connecting rod.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
no start no compression
low compression and starts hard cold
Yamaha ttr230 Service Manual
OEM parts for Yamaha
Yamaha TT R230 Owner Manual
May 16, 2012 | 2007 Yamaha TTR 230
One cylinder is low in my 1998 Volvo s90 and the repair shops says the engine needs to be replaced. Is this true>
Not necessarily. I assume you mean that the compression on one cylinder is low? This is generally either the rings/cylinder, or valves. Sometimes a blown headgasket can drop compression, but will generally have other symptoms, ie., blown between one cylinder and another, blown between the cylinder and a cooling or oil passage, etc.
A GOOD shop will check more than compression, to determine where the exact problem is.
*A head gasket blown between 2 cylinders will have low compression on bothe affected cylinders.
*A head gasket blown into an oil or cooling passage will blow bubbles (gasses) into the affected area.
*To check the rings/cylinder, after running the first compression check, put a few ounces of oil into the cylinder through the spark plug hole. Re-run the compression check on that cylinder, and if the compression improves dramatically, you have bad rings on that cylinder.
*To check the valves, you need what is called a pressure differential guage. You place the affected cylinder at TDC (Top Dead Center) on the compression stroke. You then attach the guage, and apply a set amount of air pressure to the cylinder, usually about 100psi. One dial on the gauge reads input pressure (100psi), and the other reads how much the cylinder is actually holding. A drop of more than 10-15% generally indicates a bad valve in the head (as long as the prevoius checks came out OK). To determine which valve is bad, remove the intake ducting and listen for escaping air (Intake Valve) and listen at the tailpipe for the same (exhaust valve).
These are general procedures for tests so that you can see if your mechanic has actually performed them or not. If you want to run the tests yourself, I can give you more specific instructions.
Repairs:
Head Gasket - need to remove the head and check the head and block for cracks. Then replace the gasket and reinstall the head.
Bad Valve(s) - need to remove the head and have the bad valves reground or replaced by a machine shop and then reinstall the head.
Bad Rings/Cylinder - the engine will need to be removed and either machined and rebuilt or replaced.
Again, if you want any more specifics, please ask.
Hope this was helpful!
Sep 17, 2011 | 1998 Volvo S90
The car is overheating and loosing coolant from the drivers side it looks to be near the moter mount bracket and there is alot of white smoke coming out the tailpipe any ideas the person we bouht it from...
It sounds like your Water Pump is either leaking, you have a blown head gasket, or cracked block/head. Perform a cylinder compression check on each cylinder to check from a cracked head or blown head gasket. If the compression check turns out to be within specifications, you may just need a new water pump/seal.
Mar 16, 2011 | 2000 Oldsmobile Intrigue
What is the wattage capacity of Sound Tech CX4C PA Speaker? yeah! brand: Sound Tech/ model CX4C. thanks..
SOUNDTECH CX4C 2-way monitor wedges (2).
380 Watts Power / 190 Watts RMS, Full Range 2-way, 12" speaker, 1" Compression Driver(horn). Carpet Covered, Pole Mount capable, 8 ohm.
Impedance - 8 ohm
Woofer Size - 12"
Magnet Weight - .
Voice Coil Dia. -
H.F. Driver/Exit - 1"/Compression
RMS Power Rating - 190W RMS(8 Ohms)
Dimensions - 18.5"w x 16"d x 27"h
Weight - 52(lbs.)
Aug 31, 2010 | Sound Design Lifeworks Technology iHome...
Low compression in 2 cylinders
Are the two with low compression next to each other? If so that would indicate a blown head gasket. Cylinders that are not next to each other could be worn rings or bad valves.
Mar 26, 2010 | 1985 Yamaha XJ 700 X Maxim
Cant start my 2004 80 ws raptor
Most likely, the head gasket is blown.
Check the compression on all cylinders that you can reach.
Compare results. If 2 adjacent cylinders have low compression, then that's the head with the blown gasket.
Hope this helps!
Sep 08, 2009 | 2004 Dodge Ram 1500
Mazda b2200 compression specs
those are average numbers and they are a little on the low but that is typical considering the age of the vehicle the compression should be 115 -120 psi.. hope this helps please rate this...thanks
Sep 24, 2008 | 1988 Mazda B2200
PEAVEY djs4 speaker QUESTION
If a speaker is "blown", there is normally an open-circuit in the voice coil, therefore it emits no sound at all. Can't discount a loose wire, but blown HF drivers are very common.
Dec 31, 2007 | Audio Players & Recorders
168 people viewed this question
 Grubhead
Grubhead
