LEXMARK C510 - 914 service fan error. Does anyone know what this means and how to fix it. Do I need an engineer or can I fix it myself?
  • teeny_bopper Sep 25, 2008
Inky
  • 691 Answers
SOURCE: Error "Service req E521"
Service Required E521 error: BTR 2 Error The input of 2nd BTR Retract Sensor does not change when 2nd BTR is initialized. There area couple of things that cause this problem. I would suggest you obtain a service manual from http://www.TheServiceManualShop.com If you don't see your manual listed, drop them a line to see if they can email it to you. Hope this helps
Posted on Apr 24, 2007
SOURCE: Lexmark C510 Code error: 995 Service Engine Error
I had the same problem, I changed the photo conductor and it was ok.
I disassemble that part, all the bottom, I clean it with air, they were a lot of ink in, and after that, it works correctly.
Be careful not to touch the photo conductor with your finger, and avoid having strong light on it
Posted on Oct 03, 2008
Hamedo
  • 57 Answers
SOURCE: errore code E 7
Hi p_brooks
E7:
01:DUPLWX MEMORY PROBLEMS
02:LASER PROBLEMS
03:LASER PROBLEMS
10:CCD BLACK CORRECTION SHADING PROBLEMS
11:CCD WHITE CORRECTION SHADING PROBLEMS
12:CCD WHITE SHADING PROBLEM
16:LASER PROBLEMS
thanks
Hamedo
Posted on Nov 22, 2008
  • 10 Answers
SOURCE: 123 Service Fuser Error - Lexmark C762 Colour Printer
This error refers to a thermistor error with your machine (assuming that you meant 923 error and not 123 error). Chances are that you will have to replace your fuser. Part number is: 56P2851.
To replace open the right side door (the one with the blue handle) and the lower door below it. Your fuser is the one with the 2 blue clips. Pull clips down and remove fuser. Replace fuser and push clips into locked (upright) position and that is it.
Hope that helps.
Posted on Mar 19, 2009
SOURCE: 900 Service RIP software error
a 900 rip error is the engine card. located behind the system board (formatter) if you can get the printer to a ready state you can phone 1800lexmark and get a pin code from them costs about 15 bucks. if this flash does not work you will likley need a new engine card.
Posted on May 04, 2009
How to fix Lexmark T632 924 service Fuser error
924 is an open thermister error. The thermistor controls when power is actually applied to the heating lamp on the fuser. I used to have this problem with other Lexmark models and was able to replace the thermister itself. The thermister is located on the top cover of the fuser. If you have a real Radio Shack near you they should have them. I believe that the temperature should be around 400F.
May 08, 2015 | Lexmark T632 Laser Printer
What does error code Err 09 for a Wolf oven mean?
Hello Joni;
My name is Peter. I am a retired field service appliance technician.
The error coded means: Short circuit in PT sensor or in its wiring.
Feb 03, 2015 | Wolf Range Kitchen Ranges
915 service motor error
The error means that the printer is detecting that there is Fuser cooling fan failure. Check if the fuser cooling fan is installed properly. If it is, check the fuser cooling fan for operation. Follow the steps below:
1. Enter Diagnostics mode.
2. Select MOTOR TESTS.
3. Select Fuser cooling fan.
Does the fuser cooling fan RPM increase? If yes, perform a print test, and if the error continue, replace the printer engine card assembly. If no, check the fuser cooling fan for proper connection.
Nov 30, 2012 | Lexmark W840 Printer
Xerox 7300 DN color printer, I am getting an error message "Fuser Fan Failure" reference code U32. What does this mean, How do I fix this? Do you know of any people who service printers in the...
It means you need to replace the fuser rear cooling fan the part number is 116-1024-00. New it is about 100 dollars you can find a refurbished one for 35 to 40 dollars. I am sorry i dont know anyone the the dc area that services printers.
Apr 19, 2011 | Xerox Phaser 7300DN Laser Printer
900 service rip software error on our Lexmark Optra S1855 what does it mean? How do I fix it?
These errors indicate an unrecoverable engine software
error. Replace the engine board is the only solution
Apr 07, 2010 | Lexmark Optra S 1855 Laser Printer
922 service error message, what does this mean? Can I fix it myself?
922 Fuser Error messages indicate that the fuser unit failed to reach the standby temperature.
If this is the first time you have seen the error, turn the printer off and on. Leave the printer off for at least 10 seconds before turning it back on. This gives the printer's engine board a chance to reset.
If this is an intermittent error, you may want to check how the printer is plugged in, even if it has worked on this surge device for months. Make sure the printer is plugged straight to the wall and not through a surge device or power strip. Power strips and uninterrupted power supplies can cause a low amperage problem in your printer which can trigger a false fuser error.
If this does not help or if this error appears every time the printer is powered on, you will probably need service on the machine.
Sep 29, 2009 | Lexmark Optra S 1255 Laser Printer
I have a Lexmark E450dn displaying a "935.15 Service Printhead" error message and will not print. Seeing as Laser Printers do not have printheads, instead they have Scanners and Fusers, which should I be...
a 935 printhead error is a fatal error which means the scanner motor has failed to initialize. the term printhead is short for printhead scanner. this error can be caused by either the engine board or the scanner % wise 40%engine board 60% scanner ive done 120 repairs on lexmark laser for the last 7 years trust me one of these is the problem
Jun 16, 2009 | Lexmark E450dn Laser Printer
Fujitsu error message
From service manual -
Error message condition one = fan protector operated.
Check:-
Fan,
Main Power pcb,
Main digital pcb.
Feb 21, 2009 | Fujitsu (pds42trs) Monitor
913 Service Fan Error
your printers power section does not work properly
Jan 25, 2008 | Lexmark C510 Laser Printer
355 people viewed this question
jasbo
jasbo
