Question about SanDisk Sansa e200 MP3 Player
HELP.asap. So i turn it on .. go to choose a song, and it turns itself off and back on. everytime!   anything i can do to fix it?
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
Song List Help
Alex, I'm going to attempt to help here.
After you select "All Songs" you're saying that it simply shows the previous song that was played and starts that one right?
A couple of things, normally the unit doesn't play anything by default when turned on. Usually it will allow you to select from the menu and if you don't make a selection at this point and attempt to back up, sometimes it will start playing the last song used.
Here's a couple of work arounds, first, you can try to use the smaller silver button (above left of large dial), press it and move the menu back to your options or choices such as Artists, Playlists, etc. and select something different that way (this is while the current song is playing).
Another possible solution is to select from the menu either "Artists" or "Browser" and choose another file.
This unit can demonstrate weird behavior at times and like anything else, the more you mess around with it, the more you'll figure out its quirks.
Hope this helps Alex.
May 24, 2010 | Coby MP-610 MP3 Player
Completely Wacky 'Sansa e260'
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer?s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings. That will be the only way
Sep 30, 2009 | SanDisk Sansa e260 MP3 Player
My media player wont open and everytime i try to listen to a song or watch a video it wont work. I can't even set the songs as ringtones. Can u help?
I work for AT&T and have seen this problem on a few BlackJack II's. The way to fix it is to do a master reset on the phone. This will allow it to play again...BE SURE TO BACK UP YOUR CONTACTS AND FILES BECAUSE THESE WILL BE DELETED!! Other than that, it will fix your problems!
You can reset your phone’s settings and clear all added
data from memory.
Resetting the Phone
1. On the Home screen, press the Start soft key
2. Select Settings > More… > Security > More… > Reset.
3. Enter the reset password and press the Done soft key. The default password is 0000.
4. Press the Yes soft key to confirm. The phone resets and reboots itself
Sep 20, 2009 | Samsung BlackJack II Smartphone
On/off button has a red light blinking everytime i turn on my ph
ive got the same problem but mines a w850 and it turned itself off now when i turn it on nothing does just the on/off button flashes red and im currently downloading some stuff to fix it so i will let you know asap
Aug 15, 2009 | Sony Ericsson W850i Cellular Phone
LInes on screen please help me
try reformatting it. but if you still want to save it everything in your ipod, try to check out your lcd.. its better to see just all the lines than having problems with the drive itself. but i hope it still works and can play your songs, because it's kinda more cheaper if the problem is only the lcd :)
Oct 25, 2008 | Apple iPod nano
IPod with multiple problems
It might need a new hard drive if it keeps doing that
Jul 26, 2008 | Apple iPod MA446LL/A MP3 Player
Recover lost space
Go to the Computer Drive Choose the component and Format it by right clicking. THIS WILL DELETE ANYTHING ON THE PLAYER!!!!!!!
May 27, 2008 | SanDisk Sansa e250 MP3 Player
Screen fades out whenever i choose a song
Software corrupt. Try finding out how to install it again or update firmware. If you cant, get another brand. THey like cheap, stop trying to ressurect the dead
Apr 11, 2008 | SanDisk Sansa e260 MP3 Player
It froze
Sansa Clip Player has some problem. I tried 4 sansa clip players (I purchased at Best Buy for Thanksgiving), and none of them work. Dont even try to exchange them, just return them back.
Oct 24, 2007 | SanDisk Sansa Clip MP3 Player
My Sansa turns off by itself...Help?
This happens to me to but only when Im listening to a long playlist and I haven't switched anything in a while, but if you go to "settings" and the to "auto shut-off" you can set the time you want it to auto shut off, usually it is on 5mins, so when the 5 minutes are up that you haven't touched it, it will shut off, i belive you sett it all the way up to 125 minutes, hope this helps!
Jun 13, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
14 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
