Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
Replace color cartridge no ink
I ran out of ink I bought new ink cartridgess and put them in, but the machine still keeps on reading to insert the cartridges, it is not reading the ink cartridges.
  • 832 Answers
Could be because the generic cart is not of proper size. try to use some paper betneath the cart to lift it up.
some other is known about generic ink carts which have a tape that has to be lift off befor use:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002400/000087/faq002487_000.html?reg=us&c=us&lang=en&prod=mfc440cn_all
(read the info at bottom!)
Posted on Apr 16, 2008
My printer states "paper jam" although I don't see any paper. I bought new ink cartridges & it doesn't print the multi-color, only the black.
Paper jam means just that. Look for paper or a piece of paper jammed into a gear or stuck between a roller or even in your ink cartridge . When you put in your new ink did you take off the protective seal and run the HP software to check if it is reading the Cartridge ,You might want to read the instruction on how to install an ink cartridge. It might also help you ?
Nov 03, 2014 | HP Deskjet 3052A
Need to print using hp 6110 with only black ink cartridge
Try to reset color ink level ,see how in the following link
http://atta-metro.blogspot.com/2010/03/reset-ink-level-printer-hp.html
after you complete , reset make sure your file free form colors , other wise print will ask you for change color , hope this help you
Mohamed Hejazi
Afaqnama - Tripoli Libya
Ipg@hplibya.com
Mar 21, 2013 | HP OfficeJet 6110 All-In-One InkJet...
Keeps saying insert colour cartridge when we have just bought a new cartridge of correct spec. Says incorrect colour cartridge installed.Impossible to get past!!!
Hi,The most common reason for missing or incorrect colors is a print cartridge with one of the following problems:
  • One or more of the ink colors is empty. The black ink and all three colors of ink in the tri-color cartridge must be available or colors will be incorrect or missing. Under normal usage, the print cartridge will run low on one color of ink shortly before all ink colors are emptied.
  • The protective tape is not removed from a new cartridge.
  • Contacts on the cartridge are not making proper contact with the print carriage.
  • The cartridge is remanufactured or refilled.
  • The cartridge is defective.
Feb 14, 2010 | HP PSC 950 All-In-One InkJet Printer
I keep getting the message "remove and check cartridge on right. I do this, but it doesn't solve the problem. The printer worked fine until I installed a new black ink cartridge. After so many times of...
The cartridge on the right is the black ink cartridge. The one on the left is the color.
Make sure you have pushed the cartridge in all of the way and that you have removed the tape cover from the cartridge before you insert it.
If you bought aftermarker or third party cartridges, you have a cartridge that is not filled properly. If you purchased it from a local retailer, return it and try another cartridge.
The Hp reads the levels from the gold connectors on the cartridge. If they are blocked, or damaged or the cartridge is not full, you will get this message.
Jan 14, 2010 | HP Photosmart 4180 All-in-One Printer
Canon iP100 ink tank read error, put in new one and won't read
I am having the same issue with the black cartridge error light is on. Three new cartridges create the same issue.
Nov 30, 2009 | Canon iP100 Portable Printer
Put in new ink cartridge and get error black and color cartridges need replacing
"New" refilled cartdiges? Or new from the manufacturer? Some printers have chips in the cartridges that "know" when they ran out of ink, and they have to be reset. If the refiller didn't reset the chip, it still "thinks" that the cartridge is empty.
If they're new cartridges, bought from the same place at the same time, I'd suspect bad cartridges.
Jul 22, 2009 | Office Equipment & Supplies
Not printing after color cartridge ran out - new black cartridge installed.
Yes, this printer has fixed printheads and must have ink in each color to prevent damage to the printheads. Even when printing black only each color is spit in the servicing area to keep the printhead unclogged.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jul 18, 2008 | Epson Stylus C60 InkJet Printer
Error check ink cartridge
Hi ,
As per the information provided by you it seems to be a hardware issue however u cvan try these steps .
Steps >
Take out the ink cartridges from the printer > without turning off the printer unplug the power cord > press # and 6 key together , now without releasing the keys plug in the power cord .
keep on holding the keys down until the machine turns off automatically .
after the unit turns on again it would do the allignment give a msg for insert ink cartridges . insert the cartridges at that time . and see how it works out .
Thanks
MAC.
May 24, 2008 | HP OfficeJet 6210 All-In-One InkJet...
No ink display on brother mfc240c
First make sure that you are using Brother Cartridges, their machines are very sensitive to using generic ink. Put a brand new set of ink in the machine. Pull all the old cartridges out and put all new cartridges in. If this does not resolve the issue contact Brother, they are very good about helping their customers.
Jan 02, 2008 | Brother Multi-Function Center MFC-240C...
My Hp PSC 1350v
Hi, I really appericate all your efforts to fix the issue the issue usually occures if any one of the cartridge is defective or low in ink or both the cartridge are defective. We can isolate the issue only by removing the both the cartridges out of the printer and check for the expiry dates printed on the cartridges as if the cartridges are expired also leads to this message. If the cartridge are not expired and have minumial ink in it you can try the below procedure to isolate the defective cartridge Once the both the cartridges are out of the printer insert only the black cartridge in the printer and check for the message if the message is install color cartridge the black cartridge and printer is detecting fine. If the message is check right cartridge this shows that the black cartridge is defective. If the message is insert left cartridge or color cartridge remove the black cartridge out and insert only the color cartridge and check with the message if the message is insert the black cartridge the color cartridge is working fine. And when the color cartridge is in the printer and if the message prompts to check left or color cartridge the color cartridge seems to be defective so replace the defective one will fix the issue So in isolation we can find the defective cartridge and fix the issue by replacing the defective one.. Hope this will help you to fix the issue.. Wish you success. Regards, Barret.
Sep 12, 2007 | HP PSC 1350 All-In-One Thermal Printer
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
61 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
