My maytag gas range have a error message 5a6 after I tryed to reset the clock. and now I can not turn on my overI can not turn on my over
The error your range is displaying is actually "SABBATH", which is Sabbath Mode. This enables the consumer to disable certain features of the range in order to honor the sabbath. Usually this disables the oven, but allows the consumer to still use the surface burners. You cannot defeat it by unplugging the range or turning off the breaker either. You will either have to wait 72 hours for the mode to clear, or figure out how to turn it off.
Somewhere in the owner/operator's manual is a section that refers to "Sabbath Mode". Since all ranges differ in features, you need to refer to the operation section of your owner's manual to find out how to shut the feature off.
If the model number you listed this question under is correct, this range is equipped with a Control Lock-Out feature, rather than a Sabbath Mode. To cancel the Control Lock, you need to press and hold the STOP/TIME and CANCEL pads down at the same time for 3 seconds.
If you can't find this information, or no longer have an owner's manual, you can download or print a copy for FREE at managemylife.com. Just enter your model number under the "Manuals" link and you will find it listed in .pdf (Adobe) format.
If you have questions, please post back with your correct MODEL NUMBER (if different from the one I provided) and let me know. I hope this helps you.
Hello &
Welcome to FixYa
5A6 is not a
error code and is displayed when the unit is set up to Sabbath mode. To reset
this error code you can press and hould the CLOCK pad which is located below
the display for around 15 seconds. If the problem returns then it is
recommended to leave the unit unplugged for 72 hrs so that the problem is
solved. Please get back to me if you have any other questions.
Kevin
